[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
:+1:
[/quote]
You make it sound like they just put fish in your underpants.
[/quote]
Why is this so stinking funny. I just keep laughing, than reading again, then laughing some more. I’m so immature.
As someone not familiar with Oslons how do they compare to say XPL HI? Lumens?
Throw? Heat? Thanks!
[Quote=mildlyangryjohnny]you make it sound like they just put fish in your underpants.
[/quote]
Youre not immature
Because it -is funny. I laughed too, as i thought of it…As i was typing rational thoughts and common sense into my phone…
—i pictured a wild haired crazy man, in a dark smokey room, banging away hate and fear and desperation into his computer with reckless abandon, and the guys from fireflies were there with a bucket of sardines just slipping them into his skivvies one by one as he grumbled and banged away on the keys. Shaking his head violently. Raising a fist every now and again and shaking it all about, as he beat the hell out of his poor keyboard. As if to say, “YOU SHALL NOT PASS!!!”
And i did it again. Well maybe i am immature as well.
I am already using just that - 23 mm would be a better fit but this works well enough.
That feels a wee bit perjorative. Almost like you are insulting me. Kind of a wee bit richard-ish, no? It feels like we are no longer friends the way you said that with a sneer—and exclamation. Dont like it bub. Not one bit.
Therefore,
I think you also have fish in your underpants.
My batteries fit fine. You might also consider in the spirit of objective analysis to preface your comments with, “i am also fussy with undiagnosed aspergers, and my social graces are shall we say lacking.”
Leafeye, I’m with you. There’s a lot of unknowns. It’s not perfect, but I broke the rule, it worked with the awesome Q8. I’ll wait on mine there still on New Jersey!
The 50E wasnt even available when this light was being designed IIRC. I think some fault falls on battery producers if the dimensions of cells that should be identical in size are different enough for some to barely fit.
Tue 50e was well released bro. Go back to bed.
Can someone please answer this fine gentleman. I don’t know the answer. I just know the Oslon is a SUPER THROWER!
Youre not immature
[/quote]
Bro, we could be good friends. You are my kind of funny. Thanks for the comic relief. :laughing:
You are wrong about many things. And there have been alot of people who seem to have bought the right batteries, so not a “got mine” scenario.
It is obvious to me you should not have purchased this light until after it has had some bugs worked out. You are to excitable.
As i have mentioned before in all of my apologizing: They have one battery listed on the website under pl47. An lg i think. That one is the one you should have bought—if you needed the light right away. As i have mentioned zebralight only lists under the light they sell the batteries guaranteed to fit. Mtn electronics also lists batteries guaranteed to fit.
Only 1 battery is listed under the pl47. Just the one. Caveat emptor. This is true with all non-walmart flashlights. Derp.
I have alot of flashlights in the 18650 format. I also have alot of 18650 batteries and none of those batteries are the exact same size. Should be 18mmx65mm. Do you think even one of them is that actual size? A 21700 should be 21mmx70mm. I would not expect this to be the case, especially as this appears to be a new format on the heels of tesla packs.
‘Freedom’ went on and on about battery fitment. He was obsessed earlier in this thread—wouldnt stop talking about it—but no one had an answer because no one had a light tj measure. He was right to have concerns, but he needed to wait until we could measure the battery tube. Then you measure the batteries or take a battery manufaturers word or their vendors word that that is the precise size. Assuming every battery made by a manufacturer will also be identical is silly, and to think across brands? There are what 5 major manufacturers and the rest are rewraps. So lg, panasonic, sony, sanyo and samsung are originals any other name is going to be fatter because they rewrapped.
As for your gas nozzle analogy i agree a gas nozzle should fit. It is national/ global infrastructure the whole planet falls apart if it doesnt. Thats why it has a weights and measures sticker on the pump.
You are comparing apples to penguins. Flashlights are not standardized, the batteries most certainly are not stadardized. If you want any battery to fit you should stick with alkaleaks and nimh. I suspect they have to meet certain criteria.
But to take it a step further even within a set cell size you have considerable variance just with chemistry those that require protection Circuits and those that dont. Flat tops button tops and weld tops. Just look at the 18650 cell, look at your own batteries biggest to shortest. Fattest to skinniest. This format has been around and still wildly fluxuates. 21700 only seems to have come to the fore about a year ago. How the hell do you think that will all of a sudden have a weights and measures standardization. Thats just silly.
Then if you are a flashloght maker. Do you pick the longest cell? Shortest cell? To base your tube on? Like my zebras they picked the tiniest cell they could find that pushed at least 10a. To keep those buggers small. So this means bigger batteries may be problematic. This is logic working. You cannot make a standard tube for a battery that does not have a standard size. Too big wont fit in, too small wont engage contacts.
IF THERE WAS NO INFO ON BATTERY SIZE THEN IT WAS NOT YET ESTABLISHED AND IT IS ON YOU TO BUY LIGHT THEN MEASURE LIGHT THEN BUY BATTERY.
this really is simple. You bought your batteries first just like i did—and hoped for the best. But that was a silly and uninformed decision. Now you want fireflies to make you a new battery tube to fit your favorite battery.
Thats absurd. Buy the battery they sell. Or wait too see what people say will fit. Period.
Easy peasy. This is the same throughout the industry.
Not dor nothing, but there was an episode of southpark not to long ago where they poked fun at yelp reviewers. This reminds me of that. In fact i have been singing about boogers and gum as i typed.
Another thought.
They only have to have 1 battery fit. If other batteries fit that is just swell.
Look at battery operated power tools. Lets take a dewalt 18v li-ion drill. Should makita batteries be expected to fit this drill? OF COURSE NOT. That would be considered silly and rediculous.
Oh no my milwaukee battery wont fit in my bosch drill. And my bosch battery wont fit in metabo. And metabo isnt interchangeable with festool, and kobalt doesnt like ridgid….
Another analogy might be comparing pcs with macs. Everything apple is licensed, software peripherals etc. Designed and licensed to work together. Pc not so much, the advantage of apple is whatever you are able to find branded apple will work together, but not all manufacturers will develop products for your system because of the hoops. Alternatively, pc has all kinds of products made for it but it is an utter jungle of chaos. Driver this compatibility that. More choices but more difficulty getting it to jive.
I just got my pl47 xpl hi 5000k today. The beam looks great on the white wall and outdoor… all the 21700 batteries fits perfectly and no rattle…
3930 lumen …
Magnetic tailcap is weak… it will not stick.
screen capture windows
Well now i’m a bit miffed.
I highly doubt this is your primary desire.
Because when providing critical feedback it is necessary to provide negative “and” positive analysis. You have with others zeroed in on a series of subjective faults and dug a foxhole around it.
How about the candle. The thunderstorm effect.
The coolest feature i have ever seen in a flashlight. If your claimed want is to have fireflies succeed you did not sing praise on what has actually been a good thing, or a bonus feature or anything that will get the rotten taste of leaftye out of their collective minds or the minds of readers of this thread. If your supposed want is to see them succeed you have pooped all over their product publically. And maybe some have decided that this is the venue for that. BUT that is not wanting to see someone succeed that is peeing in their cheerios.
This makes you a narcissist and a liar. If you wanted to focus on fixing their design you should have reached out to them privately. You tom tom and lohtse should have all reached out privately to one another and or fireflies to discuss the problems. Instead of soiling the opinions of people just learning about this company or light.
You chose to stink it up with math and nuanced language to clearly influence people/noobs who may have taken an interest with the light/ company.
you made it about you
I got to be honest with you, i hold people like this in the lowest regard. I make things. I guess i identify with the makers more than the whiny crabby spoiled consumer types. So there is your apologist.
If you wish for them to do well you say the sorts of things you said in this public forum in a private message.
In public, if what you say is true you provide balanced criticism. You preface your arguments properly. There are alot of people who peruse these posts, certainly many do not require the level of specificity, and precision that you do—do not use technical specs the way you do, which would be swayed quite easily by someone who seems expert on the subject. You did nothing to help fireflies. In fact i submit that you did everything in your power to put a boot on their throat.
You can use words to say both sides of the argument without sh!++ng all over them or their product.
So, [for example] if you were looking for them to succeed, you could say it this way:
… for 50$ it is a sound light, the battery i chose to use does not fit well, the manufacturer provides a battery that i chose not to use. I did not design the light so i did not get a vote on which battery will fit, i am diasappointed that not all 21700 batteries will fit this light, it does seem like their aim was to make the light as small as possible though. However i should mention as we know there isnt a standard in place to keep cells a consistent size with a variance as much as 5mm+! Within the same format, at this early date we know of only a few proven to fit and this may be due to a production flaw and sizing of the battery tube. We are looking into it. Keep in mind the 21700 battery is a bit heavier than an 18650—DONOT drop battery into tube as the weight may dent your batteries positive contact if it drops down onto the spring. Instead slide flashlight onto battery. I really like the quality of the beam, although there is an artifact in the lens on my sample and at least 2 others, probably a machining issue (you did say this part!) But it does not affect beam in practice. The color of the beam on my sample is flat out marvelous. I could not test actual lumens but texastoast measured 1800 at turn on. This is to be expected with a 219b 9080 emitter, although it falls short of the 2500lumen listed on their site. In fact some were expecting 1400output based on the s41 so to get to 1800 lumens with this ancient diode is an outstanding accomplishment. It does get hot quick though as expected.the sst20 4000k was tested and shows 2520 lumens at turn on. /edit/: these mentijned are both listed as high 95cri emitters and komekos test of the sst 4000k shows below the bbl line so no green! Also newlumen reports for xpl 5000k at 3930 lumen at turn in which is a little less than advertised but 4000 lumens aint too shabby for a 3.5 inch lite. The size and shape of this diminutive light itself is fun, but i found the “pocket” clip too small to clip over my belt. the color of my sample is consistent but there is some evidence of rough handling that should get ironed out in later production. As this is early into the run. The user interface is simply aces. It does require a bit of commitment though due to the sheer number of things you can tweak. I particularly like the candle effect and thunderstorm, and being able to set floor and ceiling on the ramp function. Word of caution 2 clicks from off gets ramp ceiling. 2 clicks from on gets turbo. Kind of like a high and turbo. Manufacturer ships in muggle mode which is a safety feature you would let a child use—no turbo, so read your manual. Make sure you are using turbo for reals. Hats off to toykeeper, lexel, tom e and fireflies for putting together what has the potential to be a really nifty little light with expected astounding runtimes due largely in part to the new 21700 format batteries, we will try to iron out just what sizes will fit and have been in discussion with ff to provide rhis information on their site. If they get their production issues sorted out this might be one of my favorite picks for 2018, maybe even 2019.
Said all the negative crap with some positive crap. Balanced criticism. No wierd taste in my mouth, now.
I completely agree… This is advertised as a 21700 flashlight not a suitable for some 21700 batteries flashligh!!! I feels like FF just tested with what he had to had and they fit ok so thats fine. Never taking into account slight differences… When I crushed two of my 18650’s people was quite happy to point out the differences based on this, that and the other and then to point out it is a 21700 flashlight after all type comments. SO now another issue comes up relating to 21700 batteries and thats ok… No it’s not. How many in this thread purchased batteries based on othe BLFer’s advise ? and how many will possible find they don’t fit? STOP defending a rather huge mistake that shouldn’t have happened.
I normally don’t jump in to the middle of keyboard squabbles, but imma take one for the team here.
It’s apparent to me that a couple of you gentlemen need to step away from the thread for a while. Your conversation is getting personal and it’s clogging up the thread with bickering back and fourth. Each of you are warranted your own opinion, no need to continue this rubbish of trying to prove who’s right and who’s wrong.
It’s time to shake hands, drink a beer, and act like men, not girls.
:+1: :beer: I want to be a girl they have more fun :smiley:
[quote=leaftye]
I don’t disagree with a lot of what you’re saying, but I think those analogies are pretty ridiculous. Very different tolerances, ESTABLISHED standards, and the manufacturers of the “male” components follow the standard. For li-ion batteries - especially 21700/20700 from what I’ve seen - none of those are the case.
Yeah, the tube should be bored a bit larger most likely, but if 21700 batteries stuck to what they are supposed to be by name that wouldn’t be an issue.
I’ll hold off any discussion of the actual build quality until mine (ordered the first couple hours of the GB… hopefully no magnet in the tailcap :weary: ) shows up.
I’d say it’s a wise comment but you had to make it sexist and parochial in the very last sentence.
I’d say act a little bit less like a man and more like a human being.
You sound like a reasonable guy, try to rethink that. There’s nothing to be afraid of in women! They do drink beer and even have hands where I come from.
