Test/review of Vapcell INR21700 5000mAh (Purple) 2018
41 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 days 18 hours ago
DSC_3726
Official specifications:
  • Model: INR21700
  • Size: 21.1*70.1mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4900mAh (0.2C discharge)
  • Weight Max: 72g
  • Internal resistance: Max:14mOhm AC 1kHz
  • Standard Charge:1500mA,CCCV 100mA cut-off
  • Charging Time: 5 hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 15000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage Temperature: -5°C~35°C
  • Storage Humidity:
  • Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH, Atmospheric Pressure: 86-106KPA
Vapcell%20INR21700%205000mAh%20(Purple)%202018-info
This is a very high capacity 21700 cell, it can deliver a some current, but is not a high current cell.
DSC_3724 DSC_3725
DSC_3727 DSC_3728
Notice the top, it is very recessed.
DSC_3729
DSC_3730
DSC_3731
Vapcell%20INR21700%205000mAh%20(Purple)%202018-Capacity
The cells tracks very nicely and can deliver the rated 15A. I do not get 5000mAh, but I only discharge to 2.8V, the last discharge down ti 2.5V will probably give very close to 5000mAh
Vapcell%20INR21700%205000mAh%20(Purple)%202018-Temp-7.0
Vapcell%20INR21700%205000mAh%20(Purple)%202018-Temp-10.0
Vapcell%20INR21700%205000mAh%20(Purple)%202018-Temp-15.0
Vapcell%20INR21700%205000mAh%20(Purple)%202018-CapacityTimeHours
Vapcell%20INR21700%205000mAh%20(Purple)%202018-Energy
Vapcell%20INR21700%205000mAh%20(Purple)%202018-PowerLoadTime
Vapcell%20INR21700%205000mAh%20(Purple)%202018-TripCurrent
Vapcell%20INR21700%205000mAh%20(Purple)%202018-Charge
Conclusion
This cell is a good cell for large capacity and can deliver a fair amount of current without being a high current cell.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
SKV89
Last seen: 1 hour 6 min ago
Thanks HKJ. I was waiting to see this one in your comparator! Now just waiting for you to add the Samsung, LG, Sony 5000mah 21700 cells LOL
cclight
This is one I was really curious about. Thanks HKJ!!!
HKJ
HKJ's picture
They will be added when I can get them or when somebody give me a pair (Somebody has promised my a pair from LG).
wolfdog1226
wolfdog1226's picture
Last seen: 1 year 3 months ago
Thanks for the review. The comparator shows exactly what you described this cell as,,,,,,,,,,,good capacity and fair current.
As expected my Samsung 40T has MUCH less voltage sag. Especially at 10/15 and 20amps.,,,,and less capacity.
The 40T is much better for my application.,,,,,,,,,,modded T27 Big Smile
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
lionheart_2281
lionheart_2281's picture
Last seen: 14 hours 16 min ago
That’s a cool story
shadockan
shadockan's picture
Last seen: 4 days 3 hours ago
SKV89 …….
….. but it would be quite interesting to see a comparison between Vapcell 21700 5000 ….. and ….. Panasonic NCR 21700 A 5000 ……
I’m right Vapcell Dennis ?
Cool Cool Cool Big Smile Big Smile Big Smile
Tom E
Tom E's picture
Last seen: 36 min 19 sec ago
Thanks HKJ! This cell is a strange one - it does under perform, as expected, compared to the high amp cells. But I'm seeing some odd behavior in the charger. I set my SkyRC MC3000 to charge to 4.22V, so when I take the cells off, usually they read at 4.21 or 4.20V. For this VapCell 5000, it takes a long time to get to the 4.22V level, longer than any other new 18650 or 21700 cell I have, but some old cells behave this way. Then once fully charged, it drops fast - luckily if I can get it off the charger above 4.18V. In fact the first time, I pulled it off, measured at 4.18V, then the next day just sitting on the bench, it measured 4.13V. I have to see if this droppage is consistent - maybe it's a first time issue.
It's weird you measured such a low resistance - usually low resistance and high amps go together. Also capacity is lower than the rating even at a 0.2 amp draw.
So far to me, mine has characteristics of an old cell - hope I didn't get a bad one. I only bought one as well so can't compare it.
BlueSwordM
BlueSwordM's picture
Last seen: 1 day 22 hours ago
There is a chance you got a low binned old cell that sat in a warehouse perhaps fully charge for a long time.
While the internal resistance of a cell during discharge does not go up much with age with modern chemistries, acceptability of charge during the CV phase is affected by cycle life/age.
There is a possibility your cell was not 100% fully charge in the CV phase, so, when left to rest, the resting voltage goes down to around 4,10V-4,15V.
However, when tested, almost all the capacity is retained, so it’s only a problem with max SOC.
ZoomieFan
ZoomieFan's picture
Last seen: 8 hours 9 min ago
Great review as usual. Only your numbers I use as official specs when buying!
Good to see more 21700’s are tested. I hope you will make a special 21700 section in your comparator.
Now all I need is a good 21700 light Smile
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
HKJ
HKJ's picture
For now they are included both in the 18650 and 26650 comparator. The 26650 do not have as many cells as the 18650, this makes it easier to find the 21700 cells.
ZoomieFan
ZoomieFan's picture
Also in the 26650 list… that’s good.
Don’t get me wrong, I’m happy with the wealth of test results in your comparator; but if you decide on a redesign…
It may be nice to have all tests of all sizes in one huge comparator.
Then the user can filter of type, drain and capacity.
For my use that would be great. For example I use the highest capacity 18650 found in your tests. The only 21700’s I’m interested are the ones above that capacity. I don’t need very high drain cells so I would for example filter 21700, 4200 mAh @5A
People that love extreme lights likely will use a far higher drain setting.
Maybe I’m asking/suggesting way too much, but I think it would a very useful upgrade of your site for many.
HKJ
HKJ's picture
It may be, but it is not easy for me to do.
One reason for multiple comparators is that they use different scales.
To really make searching flexible I would have to use a data base and do some programming in PHP or JavaScript, this would be a lot of serious work/learning, because I am not very good at these programming languages.
I may add a text based filter function, that could filter on the battery title, i.e. brand, capacity and size. But this is not something I will be doing just now.
ZoomieFan
ZoomieFan's picture
Maybe a webdesign ace on this forum is willing to help you.
Another nice thing, without graphs, would be a huge downloadable spreadsheet.
Add a few filters.
The user can then filter, sort, delete, add personal notes, etc
HKJ
HKJ's picture
ZoomieFan wrote:
Another nice thing, without graphs, would be a huge downloadable spreadsheet. Add a few filters. The user can then filter, sort, delete, add personal notes, etc
What I might be able to do is a online table (Like my chargers and multimeter tables), but with filters instead of sorting, but what to include in this type of table?
Battery name, battery size, date tested, button top, capacity at 0.2A, capacity at 3A, capacity at 10A, capacity at 20A
Enderman
Enderman's picture
Last seen: 2 days 19 hours ago
Yeah that would be sweet.
I’m sure you can easily embed a google spreadsheet or something like that with little effort, and people could download the whole sheet if they wanted.
ZoomieFan
ZoomieFan's picture
If you also make the spreadsheet downloadble the possibilities are only limited by the users Excel skills.
I think most people are after: Size and capacity at a certain drain.
Personally I have zero interest in:
- 18650’s below 3200 mAh regardless of the max drain.
- 21700’s below 4500 mAh regardless of the max drain.
Likewise high-drain fanatics filter away everything below 30A.
So a fully set filter could look like:
Flat top, 21700, >4500mAh @5A
Using filters that way would greatly reduce the list the user has to research by reading the reviews.
Very often you give cells some sort of rating in your reviews. You could add a score field. But perhaps that’s not needed because junk cells won’t pass a filter anyway.
HKJ
HKJ's picture
What I am talking about is something like this: http://lygte-info.dk/info/TableSample.html
That table is not official and will not be update (it will probably be removed soon).
It is easy enough to mark the table and copy it to a local spreadsheet.
ZoomieFan
ZoomieFan's picture
Something like that would be a huge step forward!
shadockan
shadockan's picture
vapcell Dennis wrote:
shadockan wrote:
SKV89 …….
vapcell 21700 5000mah 10A ,sanyo NCR21700A rewarpped, the same battery Smile
I know Dennis.
That’s why I wrote it this way.
It is very good for a company to tell the truth.
It is not a bad idea for the company to say which battery it uses under its cover.
On the contrary.
This makes consumers show confidence in this company.
Bravo Vapcell Dennis and thank you.
Go on like this …
For those who do not know, Panasonic and Sanyo are the same company.
Panasonic bought Sanyo a few years ago.
I wrote this so as not to confuse someone watching me I was going to mention it
Panasonic NCR21700A
and Dennis to write about
Sanyo NCR21700A
It’s the same battery.
ZoomieFan
ZoomieFan's picture
On the contrary.
And… less sales.
Rewraps are for generating extra cash.
Manual:
“Just buy something that fits.”
versus
“Bad cells may damage your vap, cause injury or even death. See below for a list of approved vapcell dealers”
shadockan
shadockan's picture
True ZoomieFan.
But think about this:
- A company that does not say what battery it uses can cause a serious accident to the user who will rely on what the cover says.
Even more Amperes are listed on the cover that can discharge a battery if I know what the manufacturer says, I will use the battery with the data reported by the manufacturer.
I do not need to mention older bad situations that we all have seen on a video or even a personal level …..
JasonWW
JasonWW's picture
Last seen: 13 sec ago
ZoomieFan wrote:
And… less sales.
What? You make no sense.
ZoomieFan
ZoomieFan's picture
JasonWW wrote:
ZoomieFan wrote:
And… less sales. Rewraps are for generating extra cash.
Not? I think it’s easy to understand.
If everyone buys the Sanyo, Vapcell would make no $ on battery sales.
If everyone buys rewraps then capcell does make some extra $ on battery sales.
Really it’s that easy.
shadockan
shadockan's picture
I think ZoomieFan means … less revenue for the rewrap company.
If I know which battery is, why should I get the rewrap?
That’s what I think it means.
He’s right … if he means that …
But it’s rare to copy a rewrap company …
I do not see a gain as opposed to the profit it will have if I copied an authentic battery …
…… as a cover I mean of course …..
(ZoomieFan ….. you are fast … hahaha)
ZoomieFan
ZoomieFan's picture
shadockan wrote:
True ZoomieFan.
Sure. My post was just a short statement. No in depth discussion.
I 100% agree there are very bad cells that are not even worth looking at. Everyone reading HKJ’s tests know that.
My point is/was: Sanyo, Samsung, and a few others make very good cells.
The company could have advised those cells.
Rewarpping a Sanyo doesn’t improve its quality somehow.
shadockan
shadockan's picture
ZoomieFan wrote:
shadockan wrote:
True ZoomieFan.
Exactly my friend …
ZoomieFan
ZoomieFan's picture
Exactly. More brands means a bigger chance to find a good deal
He does.
Not copying the rewrap (Vapcell) company.
Just Vapcell rewrapping Sanyo and then sell it as their own. That way they make some cash instead of only Sanyo.
I can imagine there is a profit in it. Numbers as a way of explanation.
Sanyo sells cells for $2/each.
A famous company rewarps them, adds some marketing claims and sells then for $10/each.
Then a copycat rewraps the Sanyo’s with the same wrap and sells them for $5/each.
Or even more illegal, buy junk batteries at $0.50/each and then rewrap and cell as something good and famous.
shadockan
shadockan's picture
Dennis I have experience similar to what you wrote.
I bought authentic batteries … and it was only authentic as a name.
This is the problem.
I use long enough authentic … but also rewrap batteries.
Many times I buy rewrap to avoid monkey batteries …, knowing of course exactly what battery I buy …..
That’s why I do not mind if she writes Sanyo or Vapcell the cover …
ZoomieFan …
I do not disagree with you …
Just copy a copy, I do not think it’s the best if you want to sell ….
Vapcell, Enercig, Keeppower, Orbtronic, Fenix, AW, Redilast ….. and others are all companies that put different batteries under their covers …
Mostly from good battery manufacturers.
These companies do not consider them the same value as some others … that we all know …. No need for names I believe …
Vapcell, for some time now, seems to want to show the world her good face.
For me, this is absolutely positive.
In the past I have been fighting with some company rewrap here.
The reason was that he tried to fool us that he was making batteries, and many people from here in our hands had our batteries, we opened them and we mentioned that it is the Samsung 25R.
How can I now trust such a company?
On Enercig, I will give confidence because on top of her covers or even on the company’s website if you get in, you will see that in many batteries it has original covers and has just placed a card in the battery with its name.
So I know from the beginning what I will buy …
That’s what I liked and what Dennis wrote ….
The truth …
shadockan
shadockan's picture
He does.
Haha, this is too exaggerated.
Distributors know what batteries are made and can only operate at a small profit.
The market is transparent.
As a result, fewer and fewer rewarp batteries will appear in the market in the future.
After all, reprocessing also consumes processing costs.
In a transparent market, it is not dominant. Facepalm
Dennis …..
Remember the Gearbest rewrap batteries of the AWT ….
There were AWT batteries and AWT rewrap rewrap batteries.
There are many more ………….
Pajda cz
I am quite sure that Dennis means vapcell 21700 5000mah 15A = sanyo NCR21700A rewrapped. Vapcell 21700 5000mAh 10A are based on LG or Samsung cells.
