[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Another thought.
They only have to have 1 battery fit. If other batteries fit that is just swell.
Look at battery operated power tools. Lets take a dewalt 18v li-ion drill. Should makita batteries be expected to fit this drill? OF COURSE NOT. That would be considered silly and rediculous.
Oh no my milwaukee battery wont fit in my bosch drill. And my bosch battery wont fit in metabo. And metabo isnt interchangeable with festool, and kobalt doesnt like ridgid….
Another analogy might be comparing pcs with macs. Everything apple is licensed, software peripherals etc. Designed and licensed to work together. Pc not so much, the advantage of apple is whatever you are able to find branded apple will work together, but not all manufacturers will develop products for your system because of the hoops. Alternatively, pc has all kinds of products made for it but it is an utter jungle of chaos. Driver this compatibility that. More choices but more difficulty getting it to jive.
I just got my pl47 xpl hi 5000k today. The beam looks great on the white wall and outdoor… all the 21700 batteries fits perfectly and no rattle…
3930 lumen …
Magnetic tailcap is weak… it will not stick.
screen capture windows
Well now i’m a bit miffed.
I highly doubt this is your primary desire.
Because when providing critical feedback it is necessary to provide negative “and” positive analysis. You have with others zeroed in on a series of subjective faults and dug a foxhole around it.
How about the candle. The thunderstorm effect.
The coolest feature i have ever seen in a flashlight. If your claimed want is to have fireflies succeed you did not sing praise on what has actually been a good thing, or a bonus feature or anything that will get the rotten taste of leaftye out of their collective minds or the minds of readers of this thread. If your supposed want is to see them succeed you have pooped all over their product publically. And maybe some have decided that this is the venue for that. BUT that is not wanting to see someone succeed that is peeing in their cheerios.
This makes you a narcissist and a liar. If you wanted to focus on fixing their design you should have reached out to them privately. You tom tom and lohtse should have all reached out privately to one another and or fireflies to discuss the problems. Instead of soiling the opinions of people just learning about this company or light.
You chose to stink it up with math and nuanced language to clearly influence people/noobs who may have taken an interest with the light/ company.
you made it about you
I got to be honest with you, i hold people like this in the lowest regard. I make things. I guess i identify with the makers more than the whiny crabby spoiled consumer types. So there is your apologist.
If you wish for them to do well you say the sorts of things you said in this public forum in a private message.
In public, if what you say is true you provide balanced criticism. You preface your arguments properly. There are alot of people who peruse these posts, certainly many do not require the level of specificity, and precision that you do—do not use technical specs the way you do, which would be swayed quite easily by someone who seems expert on the subject. You did nothing to help fireflies. In fact i submit that you did everything in your power to put a boot on their throat.
You can use words to say both sides of the argument without sh!++ng all over them or their product.
So, [for example] if you were looking for them to succeed, you could say it this way:
… for 50$ it is a sound light, the battery i chose to use does not fit well, the manufacturer provides a battery that i chose not to use. I did not design the light so i did not get a vote on which battery will fit, i am diasappointed that not all 21700 batteries will fit this light, it does seem like their aim was to make the light as small as possible though. However i should mention as we know there isnt a standard in place to keep cells a consistent size with a variance as much as 5mm+! Within the same format, at this early date we know of only a few proven to fit and this may be due to a production flaw and sizing of the battery tube. We are looking into it. Keep in mind the 21700 battery is a bit heavier than an 18650—DONOT drop battery into tube as the weight may dent your batteries positive contact if it drops down onto the spring. Instead slide flashlight onto battery. I really like the quality of the beam, although there is an artifact in the lens on my sample and at least 2 others, probably a machining issue (you did say this part!) But it does not affect beam in practice. The color of the beam on my sample is flat out marvelous. I could not test actual lumens but texastoast measured 1800 at turn on. This is to be expected with a 219b 9080 emitter, although it falls short of the 2500lumen listed on their site. In fact some were expecting 1400output based on the s41 so to get to 1800 lumens with this ancient diode is an outstanding accomplishment. It does get hot quick though as expected.the sst20 4000k was tested and shows 2520 lumens at turn on. /edit/: these mentijned are both listed as high 95cri emitters and komekos test of the sst 4000k shows below the bbl line so no green! Also newlumen reports for xpl 5000k at 3930 lumen at turn in which is a little less than advertised but 4000 lumens aint too shabby for a 3.5 inch lite. The size and shape of this diminutive light itself is fun, but i found the “pocket” clip too small to clip over my belt. the color of my sample is consistent but there is some evidence of rough handling that should get ironed out in later production. As this is early into the run. The user interface is simply aces. It does require a bit of commitment though due to the sheer number of things you can tweak. I particularly like the candle effect and thunderstorm, and being able to set floor and ceiling on the ramp function. Word of caution 2 clicks from off gets ramp ceiling. 2 clicks from on gets turbo. Kind of like a high and turbo. Manufacturer ships in muggle mode which is a safety feature you would let a child use—no turbo, so read your manual. Make sure you are using turbo for reals. Hats off to toykeeper, lexel, tom e and fireflies for putting together what has the potential to be a really nifty little light with expected astounding runtimes due largely in part to the new 21700 format batteries, we will try to iron out just what sizes will fit and have been in discussion with ff to provide rhis information on their site. If they get their production issues sorted out this might be one of my favorite picks for 2018, maybe even 2019.
Said all the negative crap with some positive crap. Balanced criticism. No wierd taste in my mouth, now.
I completely agree… This is advertised as a 21700 flashlight not a suitable for some 21700 batteries flashligh!!! I feels like FF just tested with what he had to had and they fit ok so thats fine. Never taking into account slight differences… When I crushed two of my 18650’s people was quite happy to point out the differences based on this, that and the other and then to point out it is a 21700 flashlight after all type comments. SO now another issue comes up relating to 21700 batteries and thats ok… No it’s not. How many in this thread purchased batteries based on othe BLFer’s advise ? and how many will possible find they don’t fit? STOP defending a rather huge mistake that shouldn’t have happened.
I normally don’t jump in to the middle of keyboard squabbles, but imma take one for the team here.
It’s apparent to me that a couple of you gentlemen need to step away from the thread for a while. Your conversation is getting personal and it’s clogging up the thread with bickering back and fourth. Each of you are warranted your own opinion, no need to continue this rubbish of trying to prove who’s right and who’s wrong.
It’s time to shake hands, drink a beer, and act like men, not girls.
:+1: :beer: I want to be a girl they have more fun :smiley:
[quote=leaftye]
I don’t disagree with a lot of what you’re saying, but I think those analogies are pretty ridiculous. Very different tolerances, ESTABLISHED standards, and the manufacturers of the “male” components follow the standard. For li-ion batteries - especially 21700/20700 from what I’ve seen - none of those are the case.
Yeah, the tube should be bored a bit larger most likely, but if 21700 batteries stuck to what they are supposed to be by name that wouldn’t be an issue.
I’ll hold off any discussion of the actual build quality until mine (ordered the first couple hours of the GB… hopefully no magnet in the tailcap :weary: ) shows up.
I’d say it’s a wise comment but you had to make it sexist and parochial in the very last sentence.
I’d say act a little bit less like a man and more like a human being.
You sound like a reasonable guy, try to rethink that. There’s nothing to be afraid of in women! They do drink beer and even have hands where I come from.
FWIW, they are acting like men, not women. Aggression is one of the most sexually-dimorphic behavioral / psychological traits, with men having much higher rates of aggression than women.
Yeah, people keep escalating conflicts and it kinda turns the whole thread into trash. :frowning:
It’d help if people would avoid adding fuel to the fire — avoid insults, avoid emotional and moral-emotional language, avoid speculation, and generally try to ignore flame bait instead of responding to it.
As a general guideline, if there’s an argument and we feel like it’s our duty to reply, or if the reply feels satisfying, it’s probably a sign that the reply will only make things worse. De-escalating conflicts is not a satisfying activity.
(before anyone asks, yes, I recognize the irony above)
I finally recieved my two PL47 ordered on day 1 of the GB. Tracking number never worked and I was going to ask FF in another week why tracking number cant be found.
The PL47 is much smaller than I thought. It is shorter than about every single 18650 lights on the market. I tried over half a dozen 21700 cells and they all fit without any problems except for the Acebeam protected which is too long. But dont think the FET driver would work with protected cells anyways so no point to size the light for something that is not compatible.
The XP-L Hi version is brighter than the D4S. I’m still testing them out while charging up a bunch of cells. Will post more data tomorrow. So far they are real fun to play with and pretty to look at.
I wonder if they accidentally sent you one of the lights that had the magnet removed? My magnet works fine.
The magnet in mine works well. It’s not as strong as the one in my Emisar D4S, but that light has a ridiculously strong magnet- I love it :smiley:
ToyKeeper
You’re only saying that because there are NO women in the NFL :smiley: :beer:
Mine works OK. Would like if it was a bit stronger.
Great to hear, i ordered a D4S sst20 4000k with magnet in tailcap… :smiley:
Hope it beats the chinese holiday so i get it this year.
My PL47 is still zig zagging around through the US. Maybe it’ll get here some day. Last seen in Lubbock TX by way of Chicago and Denver. I’ve got friends that have been having all sorts of issues with the USPS lately, with lights running around in the delivery truck but never showing up. Hope this all get’s sorted out, welcome to the Holidays huh? :wink:
Maybe your light is taking it upon itself to avoid its final destination because of your track record of supercharging nearly every light you get your hands on!
What? Supercharge? Me? You have GOT to be kidding! I don’t even know how to hook up a supercharger to a flashlight.
Much prefer Nitrous….
:smiley:
DB Custom
I just saw your PL 47 in that Idaho Potato commercial. You know the one, with the bloodhound in the hopped up Studebaker pickup. :person_facepalming:
Dangit! I told Fred to leave my stuff alone! Thanks for the heads-up…
I am eager though, to see how the SST-20’s perform. I have experience with the 40’s of course but these will be my first look at the baby brother. Hoping they aren’t too warm for my liking, if so, I’ll have to gift it. (Or bore it, stroke it, supercharge and twin turbo it before adding the NO2.)
DB Custom
Why do I get the feeling that when your done with that light it’s gonna start singing Johnny Cash’s “I’ve been everywhere man”
