If everyone buys the Sanyo, Vapcell would make no $ on battery sales.
If everyone buys rewraps then capcell does make some extra $ on battery sales.
Really it’s that easy.
I think ZoomieFan means … less revenue for the rewrap company.
If I know which battery is, why should I get the rewrap?
That’s what I think it means.
He’s right … if he means that …
But it’s rare to copy a rewrap company …
I do not see a gain as opposed to the profit it will have if I copied an authentic battery …
…… as a cover I mean of course ……
Sure. My post was just a short statement. No in depth discussion.
I 100% agree there are very bad cells that are not even worth looking at. Everyone reading HKJ’s tests know that.
My point is/was: Sanyo, Samsung, and a few others make very good cells.
The company could have advised those cells.
Rewarpping a Sanyo doesn’t improve its quality somehow.
Exactly. More brands means a bigger chance to find a good deal
He does.
Not copying the rewrap (Vapcell) company.
Just Vapcell rewrapping Sanyo and then sell it as their own. That way they make some cash instead of only Sanyo.
I can imagine there is a profit in it. Numbers as a way of explanation.
Sanyo sells cells for $2/each.
A famous company rewarps them, adds some marketing claims and sells then for $10/each.
Then a copycat rewraps the Sanyo’s with the same wrap and sells them for $5/each.
Or even more illegal, buy junk batteries at $0.50/each and then rewrap and cell as something good and famous.
Dennis I have experience similar to what you wrote.
I bought authentic batteries … and it was only authentic as a name.
This is the problem.
I use long enough authentic … but also rewrap batteries.
Many times I buy rewrap to avoid monkey batteries …, knowing of course exactly what battery I buy ……
That’s why I do not mind if she writes Sanyo or Vapcell the cover …
ZoomieFan …
I do not disagree with you …
Just copy a copy, I do not think it’s the best if you want to sell ….
Vapcell, Enercig, Keeppower, Orbtronic, Fenix, AW, Redilast …… and others are all companies that put different batteries under their covers …
Mostly from good battery manufacturers.
These companies do not consider them the same value as some others … that we all know …. No need for names I believe …
Vapcell, for some time now, seems to want to show the world her good face.
For me, this is absolutely positive.
In the past I have been fighting with some company rewrap here.
The reason was that he tried to fool us that he was making batteries, and many people from here in our hands had our batteries, we opened them and we mentioned that it is the Samsung 25R.
How can I now trust such a company?
On Enercig, I will give confidence because on top of her covers or even on the company’s website if you get in, you will see that in many batteries it has original covers and has just placed a card in the battery with its name.
So I know from the beginning what I will buy …
That’s what I liked and what Dennis wrote ….
The truth …
Ok, I certainly understand better why rewraps are important. For example SONY does not like their cells being sold individually, outside a complete pack.
And I guess Dennis has to be as clear as mud about what this cell is a rewrap of. But no matter how you rewrap it, it's barely 15A, probably rated lower by the original manufacturer, and certainly never meets it's rated capacity. The droppage of capacity between 0.2A and 5A has me a little concerned, but for a lower performing cell, maybe it's more common.
At this point, I regret buying this one piece and won't be buying again. It won't keep me from buying Vapcells though, because I'm very pleased with many of their other offerings, like the rewrapped VTC5D. Bottom line though through testing like what HKJ does here, we can positively identify the good rewraps if all variants are tested.
Except that you still risk that at the time of your purchase the wrapped cell is different from the one reviewed. And even if its not…how can you know if the next batch the rewrapper got was of the same grade?
Well the best thing to do is buy from a known good reseller like Liionwholesale.com - his support is phenomenal, and tests every batch that he gets in. I always will prefer buying cells from him based on availability and price (reasonable that is). imrbatteries.com is also good, personally don't know if their support is as good though.
But as mentioned before, you could be at as much risk buying a rewrap or branded cell - dunno if the branded cell is a fake or recycled as well.
He discharges to 2.8V, not 3.2V, and the difference between 2.5V and 2.8V is typically very small. His conclusion is: "This cell is a good cell for large capacity and can deliver a fair amount of current without being a high current cell."
You call it high-power, he calls it not a high current cell. Again, the way my Vapcell 21700 performs, where it drops voltage immediately off the charger implies there's a problem with the cell. If this was a heavily used cell, I'd get rid of it. Again, I have no other Vapcell 21700 to compare it with and I won't spend the money on any more to find out.
I'm hoping if any other owners can report if there's behaves the same or not - does it drop well below 4.20V after a charge, in a few minutes, next day?
I also own two of this cell (I think this should be Sanyo NCR21700A, the 21700 cell used by Tesla). My answer is, yes, the voltage of this cell does drop below 4.20V within 1 hour, especially after a few cycles of use. But I also found similar drops on Sanyo NCR18650GA, so I regard this as a normal phenomenon.
This cell performs noticeably better than its competitors (5000mAh 21700 cells, Samsung 50E and LG M50), even when all of them have been cycled for a few times.
But, I don’t like the recessed top of this cell, because that introduces quite some more resistance in flashlights since the springs cannot be fully compressed. I must add a 2mm thick copper pillar to compensate this, otherwise its performance in some flashlights will be even worse than Samsung 50E, LG M50, while it should be better. With that copper pillar, it indeed performs better than the other 5000mAh 21700 cells. However, adding that copper pillar can be dangerous in some flashlights — it can cause short circuit! One of my cell died immediately because of that. Vapcell really should add a new top to this cell, otherwise, it is not that useful.
True, I do see this behavior with my GA's but not as pronounced. I'll need to try it for a couple more cycles. Thanx though! good to hear other experiences.
I stopped buying GA's though because of this. The 35E's seem to do better, but may be because they are newer now, not sure.
I am thinking of making a bulk order of these from Vapcell. Just wondering what thoughts are with rewraps and if I will get cells remotely the same since the review is over 2 years old?
