About the weak clip, we talked with the supplier who told clips are from the same mould, so it might be different material. The QC workmake will talk with the supplier seriously today and resolve this issue.
You have done a fantastic job of building a high CRI light, with a choice of two color temperatures, and for a
very low price.
Thank You!
thanks for the link to the Yuji LEDs, it gives lumen values
existing C01 LED: 6.1-8.8 lm
alternative LED: 18-22 lm
suggestion:
The 18 lumen version would be really cool with a QTC, like the Eiger uses .
But skip the LiIon compatibility, to keep the cost downā¦ I dont need 100 lumens from AAAā¦ 20 is plenty for what that little light needs to do.
I wonder if there is interest in a Special BLF group buy for a Copper Sofirn C18 with QTC?
Infinitely variable from 0-20 lumens, at the twist of your fingersā¦ whats not to Love?
Depends on the material. Thereās a good chance it only gets very brittle and snaps at first use.
It is for a reason that the Dutch version of the expression āthe tricks of the tradeā is āhet geheim van de smidā (the secret of the blacksmith).
Doesnāt look too bad to be honest. One is on my way anyway but I was just wondering if Iām not gonna be embarassed if I give it as a gift to someone
Thank you for the photos
The EDC01 w XP-G3 has Green Tint, and is Not High CRI, so not the same Quality of Light, as the Sofirn CO1 w Yuji
For people that want to go beyond the single mode Sofirn C01, but still with High CRI in AAA size, I highly recommend Clemenceās latest offering, a High CRI 3 mode AAA light
So i threw the clip in my fireplace. The black paint was gone real fast. Waited till red hot and dipped it in olive oil(extra virgin lol). Then i tempered it by hanging it on the metal fireshield(around 200c) for 2 hours. Its much harder now but can still be bend.
I would say definitely yes, that the artifact in the Sofirn C01 is caused by the shiny cone.
My Utorch S1 Mini with shiny bezel, has a round artifact in the center of the beam, on right.
l-r 2000k E21a, 4500k N219b, 6500k XP-L
the light on the left has black magic marker on the bezel, the center light has black paint, on the right shiny
Note the three lights pictured, Utorch S1 Mini, have Aspheric Lenses, same as the Yuji LED. They are NOT supposed to have a hotspot.
conclusion
Shiny bezel causes hotspot artifacts in Sofirn C01
Thatās good info polarweis, thank you. :+1:
You said you went to āred hotā & got some results.
When mine get here I think I am going to try going a bit hotter, into the āOrange hotā range; temper a bit hotter too & see what happens.
It would sure help if we knew what metal the clip was made of.
ā¦ā¦. Edit: It would seem to indicate, since you were able to achieve some degree of hardness; it is not āmild steelā at least.
[quote=teacher
[/quote]
[/quote]
Yeah i think with more heat it will get a little bit harder. It will get a strange blue color tho.
They say its hot enough when its not magnetic any more. Mine was still magnetic. I think you really need a torch to get enough heat.
Yep, you are correct about the ānot magneticā. :+1:
A torch will work just fine or a āheat treat ovenā if one has access to it. Fortunately I do.
It will be a ācrap shootā getting it right on this unknown metalā¦ but if we can figure it out by trial & errorā¦ we can share it for anyone interested.
Just want to say that I received mine 3 days ago. I bought it 10th November, so it took 32 days to get to the UK. I like the 5600K tint alot, it's the best cool tint I've seen so far. Great job to everyone who was involved to get this light into production!
