Hey, that part isn’t on me… the Post Office can’t figure out where to send it I guess. Crazy. And still it sit’s in Lubbock, beats me why, it sure isn’t a route any of my other 200 lights have taken…
[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
MWS, too big in what way? Too big around? Can you take the wrapper off and fit them in? Can you tell if there may be TWO wrappers? I don’t have those cells but it may be worth trying to get a good measurement on the tube and then contacting IMR battery or Li-ion Wholesale and ask them what 21700’s they have will fit. Stay with the high capacity versions rather than the high discharge.
Fireflies curse continues.
Please see post 1512. Batteries were purchased from illumn.
A ton of arguments are happening in this thread and I just want beamshots :(. It seems like it’s because Fireflies fricked up, rushed everything and was overall very non-communicative leading to people being angry and taking it out on each other. This being my first group buy it left a bad taste in my mouth and I’m not sure if I’ll participate in another one for a while. My light is supposed to arrive today and I’m pretty pessimistic so if it turns out better than I expect I’ll be happy. This should be a learning experience for everyone involved, especially me since I’m in college, broke and I just dropped 60 bucks on a headlamp that I could’ve spent on weed.
Dude, watch the language… good way to get offed the forum.
Didn’t know that was a thing, changed it. Thanks for letting me know.
It’s in the rules that you just recently supposedly read.
Thank you.
So has anyone with cell fitment issues considered the Sanyo 20700 cells? Or the 20650’s? There are options…
For battery length issues a copper washer in the tail cap works just fine. If you don’t want to go looking for them you can just order from walmart. I’m using 22 mm OD at the moment but 24 mm will probably fit without sanding down. No need for all the hand wringing
Doesn’t the copper washer need to have a large enough ID for the cell to fit through for it to work? How easy is it to find those? If the cell hits the washer, well it seems like there would still be a fitment issue.
Buy the right cell, much easier, no washer to fall out at every cell change. (or put the spacer on the driver then change the cell from the tail all the time)
FWIW, the inside of my PL47 measures 21.8 mm in diameter. The cell I’m using measures 21.3 mm by 70.5 to 70.1 mm depending on where I measure it. 70.5 mm including the wrapper, or about 70.1 mm between + and - contacts.
Some other things which may be worth noting:
- On the 219B version, a high-amp cell could actually result in fewer lumens than a lower-amp cell. It could easily drive the emitters on the wrong (overheated) side of their output curve, overshooting the peak. So… use the recommended cells.
- Apparently the light ships in muggle mode by default, so output may seem pretty unimpressive until it’s put back into regular modes.
- Double-click from off does not go to turbo by default. To get to full power, turn the light on and then double click.
Easy to find 22 mm OD here - 22mm
24 mm here - 24 mm
As I said they work fine - using them now in 2 lights - already had batteries- people are complaining that the batteries they already purchased are too long - problem solved
USPS hasn’t got mine yet. I do have a tracking number though. Guess I’m looking at January before I will see my SST-20 version. You would think they would give us some sort of information such as “delays in production” or something. Good thing I am patient. My XPL-Hi version seems good though. The head wasn’t tightened all the way and when I put the battery in it acted weird, coming on in one mode and not ramping. A quick twist of the head to tighten it fixed the issue.
I’m running Samsung 40T with no issues. The 30T is a bit higher rated for amps but I’m not sure if that will generate too much heat in the XPL HI, can anyone chime in?
Shirnask, if the copper washer doesn’t fit down over the cell then your light should work just as well without the copper washer. Rare to find a washer that has an ID that will slip over the 21700 cell, it has to be as thin as the battery tube itself almost. Please check your washer, see if it fits over the cell. If it doesn’t, the cell hits the washer and leaves the tail cap offset by the thickness of the washer and is actually adding to the length of the cell.
I know Fireflies asks us not to use the 30T in the Nichia version, not sure about the others. I had planned to use the 30T, but will be changing that plan until I know the emitters can handle it, or until I change the emitters. Since I had ordered the Luminus SST-20 emitters, which are totally new to me, I’ll have some testing to do. May end up using a 20650 cell, don’t know at this time. Have some, may as well use them if everything else is ruled out.
From my previous posts in this thread-
My champagne Tube is 21.4 mm.
Sofirn 4000mAh= 21.7mm.
Shockli 4000mAh=21.7mm.
Samsung INR21700-50E= 21.1mm.
Samsung IMR21700-30T=21.2mm.
Rofis RF21700=21.8mm.
Dale, it does not have to fit over the cell, the washer is there to make contact with the tube, the spring makes contact with the battery
Texas Toasted, can you tell if the Sofirn, Shockli, and Rofis cells are double wrapped? Might it be sufficient to pull the wrapper, or both, and rewrap?
Shirnask, please, look at it… if the cell is protruding from the tube then the washer will stack on the cell and make the entire assembly that much longer. Humor me. This is the first time I’ve done this….
