Doesn’t the copper washer need to have a large enough ID for the cell to fit through for it to work? How easy is it to find those? If the cell hits the washer, well it seems like there would still be a fitment issue.
Buy the right cell, much easier, no washer to fall out at every cell change. (or put the spacer on the driver then change the cell from the tail all the time)
FWIW, the inside of my PL47 measures 21.8 mm in diameter. The cell I’m using measures 21.3 mm by 70.5 to 70.1 mm depending on where I measure it. 70.5 mm including the wrapper, or about 70.1 mm between + and - contacts.
Some other things which may be worth noting:
On the 219B version, a high-amp cell could actually result in fewer lumens than a lower-amp cell. It could easily drive the emitters on the wrong (overheated) side of their output curve, overshooting the peak. So… use the recommended cells.
Apparently the light ships in muggle mode by default, so output may seem pretty unimpressive until it’s put back into regular modes.
Double-click from off does not go to turbo by default. To get to full power, turn the light on and then double click.
As I said they work fine - using them now in 2 lights - already had batteries- people are complaining that the batteries they already purchased are too long - problem solved
USPS hasn’t got mine yet. I do have a tracking number though. Guess I’m looking at January before I will see my SST-20 version. You would think they would give us some sort of information such as “delays in production” or something. Good thing I am patient. My XPL-Hi version seems good though. The head wasn’t tightened all the way and when I put the battery in it acted weird, coming on in one mode and not ramping. A quick twist of the head to tighten it fixed the issue.
I’m running Samsung 40T with no issues. The 30T is a bit higher rated for amps but I’m not sure if that will generate too much heat in the XPL HI, can anyone chime in?
Shirnask, if the copper washer doesn’t fit down over the cell then your light should work just as well without the copper washer. Rare to find a washer that has an ID that will slip over the 21700 cell, it has to be as thin as the battery tube itself almost. Please check your washer, see if it fits over the cell. If it doesn’t, the cell hits the washer and leaves the tail cap offset by the thickness of the washer and is actually adding to the length of the cell.
I know Fireflies asks us not to use the 30T in the Nichia version, not sure about the others. I had planned to use the 30T, but will be changing that plan until I know the emitters can handle it, or until I change the emitters. Since I had ordered the Luminus SST-20 emitters, which are totally new to me, I’ll have some testing to do. May end up using a 20650 cell, don’t know at this time. Have some, may as well use them if everything else is ruled out.
From my previous posts in this thread-
My champagne Tube is 21.4 mm.
Sofirn 4000mAh= 21.7mm.
Shockli 4000mAh=21.7mm.
Samsung INR21700-50E= 21.1mm.
Samsung IMR21700-30T=21.2mm.
Rofis RF21700=21.8mm.
Texas Toasted, can you tell if the Sofirn, Shockli, and Rofis cells are double wrapped? Might it be sufficient to pull the wrapper, or both, and rewrap?
Shirnask, please, look at it… if the cell is protruding from the tube then the washer will stack on the cell and make the entire assembly that much longer. Humor me. This is the first time I’ve done this….
Dale, the difference it makes is that you no longer have to compress the spring in the tail cap completely just to have the tube make contact - the difference between grinding the cap on as hard as you can just to make contact and a gentle 2 finger twist. I can make it work without them but I destroyed one o-ring getting the SST20 tight enough on a 30T without them. I agree that if you don’t already have batteries get ones that fit without this, but other wise this is much better than destroying o-rings and crushing springs
I never crank down on threads, it shows something is amiss. Remove the spring in the tail cap if necessary, put a small dab of solder in it’s place, but never crank down a threaded cap on a cell to gain contact that isn’t there. Dangerous on the cell, at the very least you cause damage that can’t be repaired.
So, Shirnask, from what you’re saying you’re using the copper washer to compress the driver spring and make contact to the tube, why not just ream the ID of the washer so it clears the cell then it’d be an easy fit, solder the washer to the tail PCB ground and be done with it.
MWS, I can’t tell from their pictures but I get the impression they just put their black wrap over the existing cell. At the corners it seems almost “padded” as though this is the case (a factory wrapper inside the Sofirn wrapper) If not, I would strip the wrapper and leave the bare metal can, then wrap that in the ultra thin Kapton tape to prevent it grounding inside the tube. I’d use the cell, wouldn’t be a waste of money. Ultimately I’d keep an eye on it of course and when a proven better cell came along I’d retire the Sofirn cell. But I’d get some use out of it first.
Me? If that still wouldn’t work I’d bore the tube.
Yeah Yeah Yeah, everybody doesn’t have a lathe. But you don’t have to have a lathe, a wooden dowel and sandpaper can get it done. Where there’s a will, there’s a way. (Old Lumens would be proud! )
actually I believe he means that the washer makes contact to the tube sooner and he doesn’t have to compress the spring near as much?
the washer just needs to clear the spring.
I suspect that the copper washer mod is only working because the washer is contacting the -Ve of the cell and the outer trace of the tail PCB, acting a bit like a retaining ring by providing a continuity path from end of the tube to the tail PCB, that isn’t there in the original design, and bypassing the tail spring.
Meanwhile the tailcap will be hanging on by a few threads less (depending on thickness of the washer), and the o-ring in a different position than designed.
You could also try something different such as a circle of solid copper wire at the head, to effectively lengthen the tube. Anneal it first to dead-soft (just get it red hot, and pickle off the scale in some acid, or polish it). If the o-ring ends up displaced from the sealing surface in the head (I didn’t see any such thing on the photos, just seemed like rough threading all the way), PTFE tape around the threads might solve that.
