[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
[quote=teacher]
Depends on the material. There’s a good chance it only gets very brittle and snaps at first use.
It is for a reason that the Dutch version of the expression “the tricks of the trade” is “het geheim van de smid” (the secret of the blacksmith). :wink:
[quote=iamlucky13]
Beamshot required!
[quote=polarweis]
BLF GT nano edition :wink:
1m to white door. the bright white ball is the reflection. pretty nice throw :smiley:
[quote=Henk4U2]
Very true Henk4U2. :+1: …. But it is worthless as it is, so on the offhand chance it might work, it won’t hurt to try.
Tempering after this makeshift ‘heat treating’ attempt might well relieve some of the brittleness.
If you do try it polarweis, let us know the outcome please.
There are 2 more SC01 in Germany.
Must be from the first batch. The clip fits tight. Seems good quality :+1:
Knurling is definitely not on the aggressive Side. The Threads are really smooth. Turning on and off works very well
I´m very happy both with the Light intensity (between the low and the Mid of a Lumintop EDC01) and the Light colour
I would say the BLF Team that realized this Light and Sofirn did a very good Job :+1:
Thank´s a lot for this
and Greetings from Germany
Lumintop tint doesn’t look too bad on these pictures either. What would you say?
both are sofirn i think.
:person_facepalming:
I thought I’m expecting too much from XP-G3…
Oh, Sorry for not clarifying :blush:
Yes both are Sofirn C01, 5600K and 3200K
Here is a direct comparison with the Lumintop EDC01 on low and Med
Without direct comparison it appears to be a pure white :+1:
Doesn’t look too bad to be honest. One is on my way anyway but I was just wondering if I’m not gonna be embarassed if I give it as a gift to someone :wink:
Thank you for the photos
The EDC01 w XP-G3 has Green Tint, and is Not High CRI, so not the same Quality of Light, as the Sofirn CO1 w Yuji
For people that want to go beyond the single mode Sofirn C01, but still with High CRI in AAA size, I highly recommend Clemence’s latest offering, a High CRI 3 mode AAA light
So i threw the clip in my fireplace. The black paint was gone real fast. Waited till red hot and dipped it in olive oil(extra virgin lol). Then i tempered it by hanging it on the metal fireshield(around 200c) for 2 hours. Its much harder now but can still be bend.
I would say definitely yes, that the artifact in the Sofirn C01 is caused by the shiny cone.
My Utorch S1 Mini with shiny bezel, has a round artifact in the center of the beam, on right.
l-r 2000k E21a, 4500k N219b, 6500k XP-L
the light on the left has black magic marker on the bezel, the center light has black paint, on the right shiny
Note the three lights pictured, Utorch S1 Mini, have Aspheric Lenses, same as the Yuji LED. They are NOT supposed to have a hotspot.
conclusion
Shiny bezel causes hotspot artifacts in Sofirn C01 :wink:
That’s good info polarweis, thank you. :+1:
You said you went to “red hot” & got some results.
When mine get here I think I am going to try going a bit hotter, into the ‘Orange hot’ range; temper a bit hotter too & see what happens.
It would sure help if we knew what metal the clip was made of.
Edit: It would seem to indicate, since you were able to achieve some degree of hardness; it is not ‘mild steel’ at least.
[quote=polarweis]
Perhaps not quite as throwy as the initial GT, but thanks for indulging my curiosity about how it would look with that big reflector. :smiley:
[quote=teacher
[/quote]
[/quote]
Yeah i think with more heat it will get a little bit harder. It will get a strange blue color tho.
They say its hot enough when its not magnetic any more. Mine was still magnetic. I think you really need a torch to get enough heat.
Yep, you are correct about the “not magnetic”. :+1:
A torch will work just fine or a ‘heat treat oven’ if one has access to it. Fortunately I do.
It will be a ‘crap shoot’ getting it right on this unknown metal… but if we can figure it out by trial & error… we can share it for anyone interested.
The info you shared is a great start… :+1:
Just want to say that I received mine 3 days ago. I bought it 10th November, so it took 32 days to get to the UK. I like the 5600K tint alot, it's the best cool tint I've seen so far. Great job to everyone who was involved to get this light into production!
Thanks John, good to know. I ordered mine a day after you, so hopefully they’ll be here soon!
Mine are in US last week, but damn, once in ISC cutoms in New York OR Chicago….it can be another 2 weeks to get to me in southern US….I’m used to it after so many years, so I’ve learned to just wait and wait and wait……. :innocent: :smiling_imp: :person_facepalming:
When I saw the top picture, I first thought it looked like that itty bitty animal they’ve found that apparently can’t be killed! Facepalm
