Looking forward to the final options!
Perfectly regulated, efficient, and best Tint and CRI, what is there not to love??
Superb! Can’t wait to get one of those Optisolis EDCs. Or maybe a 2000K E21A, or both…
Below is the runtime test with stock plain optics except for the Optisolis which used 30° peebled TIR optic. The E21A still needs some refinement as it’s so thin and sunk 0,7mm below the optic’s holder (centering ring). This make it outputs less than it supposed.
The Optisolis as expected, with it’s higher Vf has the lowest runtime. The warmer Optisolis will have longer runtime for their lower Vf.
This new generation Jet-μ is very good at maintaning almost flat regulated output. Although measured less than advertised 135lm, it’s still very good at 94lm for almost an hour! E21A with it’s lower voltage gives ~2,5 more minutes. With D320 E21A (R70 unfortunately) we can get the same output.
Beamshots (1 meter from the dirty wall, each marker are 10cm apart, 5600K WB):
- Clemence
Gadzooks!
The Jetbeam bosses must be wondering how to put Mr. Wizard on their payroll !
Another run time test. This time uncooled (previously was fully submerged in a room temperature water bucket). Started in an air conditioned room at 24°C - 25°C. The light temperature only reached feverishly warm (I just made up this term… ).
Higher die temperature lowers the required forward voltage. Here we can see less than 5 lumens output decrease and ~7,5 minutes longer regulated run time. I spoke to Maukka, about the possibility to make me another standard measuring lights with several CCTs using this Jet-solis.
Next: Optic improvement for E17A/E21A version. I need to bring the LED 0,7mm higher to at least level with the plastic centering piece. Not just the centering peace block the light, I also suspect the photon bounced between the LED and the optic centering piece was heating the LED, reduced the output.
- Clemence
This is amazing!
Great work! I’m looking forward to an E21A for sure, maybe even both.
I will surely take 3 different CCTs of Optisolis (6500K, 5000K and 4000K or 3500K).
Again, I am too weak to resist.
Hard to go wrong with Clemence.
My most used lights:
l-r E21A, N219b 4500k, N219b 4500k
Yes, a Slow Green campsite beacon in Rural Jungle seems fine.
As a pedestrian, or cyclist, in the Urban Jungle, I would want Fast Red or Fast White flashes.
Lovely work Clemence. I’m starting to love my Sofirn C01 and I’d definitely get this. E21A 2000K and optisolis 5000K would be my first choices for this light.
For a better idea of what has been accomplished, comparisons can be made with the review UPz provided.
Optisolis 5K 9080 output similar to a Nichia 219B sw45 92+ Cri …but with better runtime and final slope.
Truly a well executed labor of love from our Mr. Wizard !
Thanks Tjohn =)
BTW, I made some optic refinement for the JetE21A and still doing a runtime tests between packing the orders. The beam pattern is now looks almost similar to stock Cree XPE2 and the output increased to about ~10ish lm (will measure it again). The LED also runs cooler now. Will report back soon.
Happy saturday night guys
Where did you get those nice little LED boards?
I grow them in my backyard :laughing:
No, I made them of course. But this only designed for up to 350mA. Just normal good copper MCPCB. At this power level even the stock aluminum non DTP MCPCB already more than enough. I made them with copper because I am pretty sure you guys will question me if it’s only aluminum . In my test, it’s shows no measurable difference at all (Cree XPE2 250mA current).
- Clemence
I hope you will ‘harvest’ enough of them so i can buy a few too with my next order.
Thanks Tjohn, that really puts it in perspective. The 219B used in the Eagtac judging from the Eagtacs I own, are not even 9050 because I have real 219B 9050 to compare with. I think those are just 219B 9000, which is usually much more efficient than the better color rendering, better tint versions. What Clemence is making is absolutely amazing since the 9080 or more like 9090+ Nichias will look FAARRR better and still offer about the same or better efficiency as the 219B Eagtac.
So far I recorded 74lm (79,11lm at start) for 1hour 3minutes uncooled for the Jeteria (JetE21A)
- Clemence
……to further your point even more, I used to think my Eagtac MX25L3C Nichia had much better tint, until Clemence drop shipped the first Group Buy of sw45 9080 Nichia leds via Texas Ace, before his Bali store opened.
Those jewels make my D25aaa and Eagtac Nichia 6 led thrower look mucous yellow-green in side-by-side comparisons.
Indications are Eagtac looked for above the ANSI BBL stock for more lumen output, since according to Clemence, above or below was formerly the typical manner in which Nichia offered their sw bins.
I just found this thread & happy I did. I love this little AAA light, & have one in my pocket all the time.
Looking forward to this one……
Still testing the runtime for the third time. There’s something weird going on here.
The JetE21A output vary between 74lm - 79lm between lights. This is OK because I measured the current output vary from 230mA to 245mA, and each LED’s output also slightly different. In theory and observations, hotter LED will have lower forward voltage, correct? This usually results in longer regulated runtime albeit reduced brightness. This apply to either boos or buck driver. But in JetE21A the case it’s the other way around: uncooled (much hotter body temp) results in LESS reduced output over time and LONGER runtime! This is weird
Can someone help me explain this?
- Clemence
