So i threw the clip in my fireplace. The black paint was gone real fast. Waited till red hot and dipped it in olive oil(extra virgin lol). Then i tempered it by hanging it on the metal fireshield(around 200c) for 2 hours. Its much harder now but can still be bend.
I would say definitely yes, that the artifact in the Sofirn C01 is caused by the shiny cone.
My Utorch S1 Mini with shiny bezel, has a round artifact in the center of the beam, on right.
l-r 2000k E21a, 4500k N219b, 6500k XP-L
the light on the left has black magic marker on the bezel, the center light has black paint, on the right shiny
Note the three lights pictured, Utorch S1 Mini, have Aspheric Lenses, same as the Yuji LED. They are NOT supposed to have a hotspot.
conclusion
Shiny bezel causes hotspot artifacts in Sofirn C01
That’s good info polarweis, thank you. :+1:
You said you went to “red hot” & got some results.
When mine get here I think I am going to try going a bit hotter, into the ‘Orange hot’ range; temper a bit hotter too & see what happens.
It would sure help if we knew what metal the clip was made of.
……. Edit: It would seem to indicate, since you were able to achieve some degree of hardness; it is not ‘mild steel’ at least.
[quote=teacher
[/quote]
[/quote]
Yeah i think with more heat it will get a little bit harder. It will get a strange blue color tho.
They say its hot enough when its not magnetic any more. Mine was still magnetic. I think you really need a torch to get enough heat.
Just want to say that I received mine 3 days ago. I bought it 10th November, so it took 32 days to get to the UK. I like the 5600K tint alot, it's the best cool tint I've seen so far. Great job to everyone who was involved to get this light into production!
Mine are in US last week, but damn, once in ISC cutoms in New York OR Chicago….it can be another 2 weeks to get to me in southern US….I’m used to it after so many years, so I’ve learned to just wait and wait and wait…….
Perhaps this is good info who receives a C01 with bending clip that does not have any springiness to it.
Btw, I managed to convince Sofirn that their clips are faulty, they admit that the heating process was wrong and they sent what is left of the batch back to the manufacturer for improvement.
Inspired by polarweiss I tried his method of hardening the clip, warmed up to orange, quencing in vegetable oil, keeping it at 200 degrees for 2 hours. Nothing happened, fail, no springiness at all was achieved.
Then I did not care about the clip becoming brittle anymore, blowtorched it to almost yellow, next to the fast running tap, and while orange/yellow dunked it under the stream and presto: perfect springiness without being too brittle it seems sofar.
Lithium primary batteries (Energizer Ultimate Lithium L92) are completely fine to use, Li-Ion on the other hand should not be use in the C01 (bad things will happen if you do).
I received my light yesterday, delivered to Florida. Ordered on November 10 and delivered on December 15, so 35 days. Just passing along this info for those still waiting on delivery in the US.
I would like to order one of each tint. I see there are some issues with weak pocket clips.
Is there a good aftermarket clip I can buy separately that fits the light?
Or is there expected to be a new batch rolled in soon that addresses the issues? I don’t want to be too demanding for $6.
