Table of tested chargers, comments?
If you have a wheel try clicking on it.
You can also right-click and select open in a new window.
Ah yeah, this works beautifully! Thanks!
First, allow me to thank you for making those comprehensive charger reviews, despite the fact that sometimes, there may be new revisions that may warrant a re-test of that specific charger (only functions that changed, but may not be easy to identify without a complete test…).
I would like to mention there seems to be an inaccuracy in the table — the Miboxer C4-12 is listed as an “analyzer” — AFAIK, it does not do discharge testing, so it’s not an “analyzer”.
Thanks, I have fixed it (Website may update a bit later).
am trying to find a charger for my 18650’s using your “table of tested chargers” but am having a problem using it.
Under the “select index”…… I can NOT remove a search option, once I click on it.
For example, say I click ‘LiIon only’. It (the text) turns red. But then if I want to search ‘NIMH only’ I try to get rid of the ‘LiIon only’ by clicking on it but it just stays red and is still included in search.
The only browser I have is Firefox. Does the page only work on IE?
It works with Firefox (I am am using Firefox).
I do not know why it turns red, each index is a separate page and when you click on it you simple changes to that page. The title shows what page you are on.
I now see how it works , Thanks
OK, so a nice feature would be for it would be:
Able to search multiple features at one time. In other words…. (as in my case on the “search index/options”), I would press the LiION ONLY, DISPLAY V and mAh, 12v Power Imput, 2 slots, (options) and the resulting page would only show chargers that have all of these features…since those are the features I must have in a charger.
That is the way I was trying to use your informative index (my bad) since most search charts work this way. (Parametrek Batteries)
Just a thought, thanks for all your hard work and info !!!
You can search on two parameters, the first is select the best table, the next is sorting a column. If you select the right parameters the remaining list will be fairly short.
Parametrek is something else, is uses a database, my list is just a html page. I have found a script that can filter on each column (tablefilter.js), but it cannot sort. If anybody knows a free javascript library that can do both, please say.
[quote=HKJ]
“You can search on two parameters, the first is select the best table, the next is sorting a column. If you select the right parameters the remaining list will be fairly short.”
OK…I am an idiot……How do you “sort a column”?
Click on the title, once or twice depending on sort direction.
HKJ, what’s your favourite charger in 2019? I would like to test mAh, charge 2/4 cell, display.
I have single cell tp4056 charger, 4 wire battery holder, skyrc b6 mini, zb206 battery tester, but all these can charge/test only one cell. I am looking for a decent charger in the price range of 20-30usd.
I have only published 7 charger reviews in 2019 and only two of them are 4 slot with mAh display and only one of these has adjustable current, that is the Nitecore UM4.
If you want to discharge batteries to measure them, the Lii-500 and BT-C3100 are still good cheap chargers.
You can also check my analyzer list: Round cell charger index (Analyzer)
HKJ, can you update review of ISDT C4 with current updated firmware, i need your feedback especially for NIMH battery,
I do not have time for that at the moment.
Why did you not add to the table ISDT N8?
I did add it, but I forgot to upload the new page, making it rather difficult to see :laughing:
It is fixed now.
Thank you, waiting for the test Xtar VC4S!
Coming soon.
:+1:
Are the new Liitokala Lii-500S also queued up for testing?
How about the “upgraded” Miboxer C4-12 (v2) ?
500S is planned, but the first one I got died during the first charge and I have not received another one yet.
I do not have any plans for the Miboxer.
