As a first measure, do you have another type of USB port to test? Preferred USB 3.0 directly on your Mainboard.
I tried both USB 2.0 and 3.0 on my laptop and on a desktop. I’ve tried both Windows and Linux as well. https://www.amazon.com/gp/product/B00AX4WQ00/ is the programmer I’m using.
try this command format…worked on mine…same usb programmer
avrdude -p attiny85 -c usbasp -Uflash:w:anduril.2018-09-07.EMISAR_D4S.hex:a
put your correct file name in of course…
not sure why it would matter, but safemode not disabled on the above command (-u)
let us know!
I’m not even getting a connection now, I’ve checked all the wires too.
avrdude: error: program enable: target doesn’t answer. 1
avrdude: initialization failed, rc=–1
Double check connections and try again, or use -F to override
this check.
What gauge wire are you using from the programmer to your D4S? I tried using these Amazon.com wires but the pins were too big to fit into the holes on the light, the pins kept bending when I tried. Then I found some small solid wires around the house, they fit in the holes but they move around a bit. I’m not sure if I’m not getting a good connection, if I bricked the chip on the light or if this programmer is just bad.
I found some old telephone wire (solid core) from an old land line in the house.
Toykeeper: I’m guessing 26 gauge. Maybe 24.
Look here for a setup pic (not mine, but same as what I did)
I will look for some other wire to test with. What part of the holes actually make the connection, do the wires need to touch the bottom of each hole or is the metal around the outside of the holes? It looks like most of the metal is off the SC and V+ holes, so maybe that's my issue.
Uncertain its the sides or in the holes. I just had the tiny wire put in there until i felt resistance. I found it fiddly to be sure, put a wire in, wire pops out, put it back, put in a wire, pops out…etc…
My wires just shoved in…they were “loose ish” so assuming it was more of a connection IN the holes than just from touching the holes.
If I got lucky and every wire touched the sides of the holes and THAT is what made the connection I got lucky then…cuz that wasn’t what I was going for…
I suspect the wires pass through the holes to the chip legs…
When I flash a D4S, I make sure the wires are sticking through the holes, and there is some sideways pressure on them to keep them in contact. I set it up so I don’t have to touch it during the flashing process, to make sure it won’t move and break contact. Then when it’s physically stable, I run the flashing command.
driver size?
I use some 5amp fuse wire to finish the connection, to flash the D4S
The wire tips were well into the holes, but probably also had a decent touch to the top edge.
Been testing some cells and found that a Gold Golisi 26650 at 4300mAh capacity yields 19.22A in my D4S equipped with LH351D W6 5000K emitters. This is better than the 15.06A from a Shockli 5500mAh 26650 and a pair of new Sony’s I just received (one cell at a time of course in the D4S), which make 15.46A although they are only 2600mAh cells and considered to be “vintage”.
HKJ’s tests show that the Golisi 4300 has signficantly higher current than any other 26650 cell and VTC5A.
Is there a reliable source for the Golisi IMR26650 4300mAh (Gold)? NKON and Akkuteile.de don't have these.
I just read on a German website that Golisi uses different cells, i.e. you'll never know what you gonna get.
https://www.dampfer-magazin.de/golisi-akkuhaertetest-im-rmr-testverfahren/
Use efest instead ? probably better then any golisi or is there something special about them? im gonna use efest or liitokala when i get my grey Warm White - SST20 3000K 95CRI on my way now, very excited to have a warm white d4s tint.
Thanks to Alchemi who sent me the Ledil-Angie 2287 optic for my testing, I tried using the optic on the D4S Nichia 219C and D4S XPL-Hi 5000K, these are the beamshots:
Left: frosty Ledil-Angie 2287 optic (25-degree beam) ; Right: (from stock) throwy Ledil-Angie 2285 optic (12-degree beam)
Emisar D4S (quad Nichia 219C, stock optic: Ledil-Angie 2285)
Emisar D4S (quad Nichia 219C, frosty optic: Ledil-Angie 2287)
Emisar D4S (quad XPL-Hi 5000K neutral-white, stock optic: Ledil-Angie 2285)
Emisar D4S (quad XPL-Hi 5000K neutral-white, frosty optic: Ledil-Angie 2287)
I like the original, but Im digging the slightly smoother 2286 too. 2287 might be too floody for my tastes unless dedicated for indoors. It would be great on a dedicated candle/night D4S.
Arrived in Sweden last week, looks good and feels just fine. I like the amber leds mucho.
No complains, included was the black version of the battery, and the magnet is so strong.
Yes, im a noob that (yet) do not now how to insert the picture. https://ibb.co/QKBssNn
To be, continued.
Green with Amber looks good together. Thanks for the photo!
“frosty Ledil-Angie 2287 optic” sweeeeet. Where does one acquire this ?
Fan så fint !
I ordered a black with sst20 4000k with amber aux.
The Amber aux looks awesome seems that the amber is the least popular?
To be, continued.
