Yep, weāre neighbors. :+1: . I ordered 22 November & got a ā6 January extension emailā today also. Iām betting we will both have them before Christmas or shortly thereafter.
Time will tell if that prediction is correct or not.
Looking forward to receiving this light, hopefully by the end of this year. I signed up for USPS email notifications since I was tired of checking on my USPS bookmark
Oh yeah, I remember now that you mentioned it!! I feel the same way, the EA45S is a great light. In fact, if I was forced to choose 1 lightā¦. I think the EA45S would be it.
I did not realize there was a ānew versionāā¦. Iāll have to check it out. Thanks for the heads up.
Yep, EA42ā¦. you thought right. :+1:
It looks interesting, but it will have to be extraordinary to top the EA45Sā¦. even if it does have 1800 lumens.
I do not know how he knows, well, actually Sofirn folks tend to talk all the time about their new projects
But yes, there will be a C01 pro, but it may get a different name in the end. No idea if it will get a TIR optic or a reflector, but the led will very probably be SST-20 95CRI (4000K and/or 3000K), and there will be two or three simple modes (it being a twisty). I have not seen a design yet so I would not expect this light within the next few months.
Hmm, I was very proud to have succesfully hardened my C01 clip, but I should have known that the rough way I did that was an insult to the noble art of hardening. Next iteration (I have one more bendy clip leftover) will be waiting 1 second longer before quenching under the tap.
crap haha. If you temper it after the hardening it should be better. and tempering doesnt take away any of the hardness if im correct. It just realines the carbon atoms.
Yes, quench hot and fast - you want a 100% transformation from austenite to martensite, and slow cooling will result in retained austenite or pearlite at room temperature. The tempering will lower the hardness, but if done right not below the properties of a proper spring. Not knowing the steel, I would try tempering at 500 - 600 degrees Farenheit, or perhaps as much as your oven can reach. Let it cool slowly after reaching full temperature. The structure will still be martensitic, but it will relax the carbon and iron matrix adding ductility, as in making it less brittle, which is your problem after the quench.
Is that an assumption, that it was the heating process?
I think I recall someone suggested earlier that the sub-contractorās sub-contractor had substituted the wrong metal to make the clips?
Sofirn needs to somehow extricate their company from the usual corner-cutting approach.
Sofirn needs to decide to work, as the saying goes, in the early years of a better nation ā in which no party in the chain of supply is trusted without QA and QC being done routinely.
