Like the Jetbeam FL-12? It essentially ramps the two different LEDs up/down inversely to control output from 3000k to 5500k.
FWIW, the Viltrox L116T is a nice high-CRI light panel which can be powered by a wall adapter and mounted on a gooseneck thingy or tripod. It adjusts from 3300K to 5600K in 100K increments, and stays below the BBL the entire time.
Can also be battery powered, but I don’t use it that way.
I’m already on the list but should I clarify which emitter now that there’s two choices?
If so I’d like one of the LH351D 4000K 90CRI please.
Patiently excited!!
I’m also already on the list and would like to have one of each emitter.
This looks nice. Put me down for 1 please.
Ah, I saw that when it came out. I could definitely use a light like that for soldering and making videos.
I’m in for one. Please add me to the list.
I believe the solution is standardization. If there’s common BT API that’s used by many different lights and any app can control any light - the problems with manufacturer stopping updates is gone.
Now…maybe there is such standard already, just designed for a different class of lights? Smart light bulbs for example?
Standardization such as all flashlights use one UI? Not likely to happen.
No. No one UI. Use one way to talk with Bluetooth controllers, so any compatible controller knows how to turn on any compatible light. Or how to dim it down etc. The light can have any UI. So can the controller.
And not all of them - just enough to not have to fear about the standard dying out.
If you want a standardized bluetooth interface which isn’t likely to die out, about the only way that can happen is to make an open-source driver with open-source firmware, get a couple brands to use it, and find someone willing to keep companion apps updated on several platforms. It might be doable within a year or two if someone was motivated enough to do it.
For now though, I’m mostly just trying to get companies on board with the idea of working with the community, and building a common firmware platform which supports a variety of hardware and a variety of user interfaces. Basically, trying to make it possible to do with flashlights what we do with computers — let the users mix and match hardware and software as desired.
Nothing to say about Bluetooth.
How’s the FW3A ?
I have started ordering extras
Can I be added to the list for 1 with the LH351D emitters please?
Absolutely interested. Two, please. (One of each emitter)
Can I be added to the list for an Hi CRI version
Ty Geoff
That’s really cool. A working prototype is a big step forward. There’s still a lot more to the process for making a widely-used standard, though. With the code and schematics and stuff, and some motivated people, we could probably find ways to fit it into smaller hosts and extend the functionality and get it into lights by multiple companies.
Something I’d personally love to see is a USB-capable or bluetooth-capable bootloader which can be used to flash firmware over a fast and universal connection. This would enable all sorts of fun things.
For a little while, I toyed with the idea of flashing over the “optic nerve”, but it would take a couple hours and the link only goes one direction, so it wouldn’t be able to correct errors. Very inconvenient and risky. Bluetooth or USB would be a lot faster and safer.
Manker once told me that Nextorch has some kind of patent on the "programming via USB" thing
Yes, it isn’t the end, but I think it’s a good beginning. With, as you said before, some open source hardware and firmware, it could grow bigger, faster. What do you mean about the bootloader? Are you talking about a bootloader in the flashlight?
