Yes, quench hot and fast - you want a 100% transformation from austenite to martensite, and slow cooling will result in retained austenite or pearlite at room temperature. The tempering will lower the hardness, but if done right not below the properties of a proper spring. Not knowing the steel, I would try tempering at 500 - 600 degrees Farenheit, or perhaps as much as your oven can reach. Let it cool slowly after reaching full temperature. The structure will still be martensitic, but it will relax the carbon and iron matrix adding ductility, as in making it less brittle, which is your problem after the quench.
Is that an assumption, that it was the heating process?
I think I recall someone suggested earlier that the sub-contractor’s sub-contractor had substituted the wrong metal to make the clips?
Sofirn needs to somehow extricate their company from the usual corner-cutting approach.
Sofirn needs to decide to work, as the saying goes, in the early years of a better nation — in which no party in the chain of supply is trusted without QA and QC being done routinely.
Since a couple of people have been able to heat treat their clips …. it stands to reason it was the heat treat that was woefully lacking. Whether is was wrong or did not happen… who knows.
But from the look of djozz’s clip that was bent… it looks like heat the treat process was skipped altogether by the supplier.
My reasoning differs, I can’t rule out the possibility the sub-subcontractor supplied the wrong alloy.
You can heat treat any alloy and get some improvement, but you can’t get the desired results from every alloy.
If their subcontractor supplied the wrong metal then they’d get an unexpected result, and leave the metal in an unanticipated condition so another heat treatment cycle would give an unwanted result. It doesn’t appear easy to undo then redo heat treatment to get it right the second time, even starting with the right steel.
No, I’m not a materials scientist, I’m just reading what I can find online. As with most tech stuff, I find that it’s far more complicated than I’d have thought.
Could very well be, either way the heat treat was:
[1]not done at all
[2]not done properly for the steel used
[3]the steel was a wildcard from the supplier.
In case #3 there would be no way to heat treat it properly because the steel is not what it is supposed to be.
No matter which it was, a crappy clip was the result for some of the CO1’s.
As far as heat treating a second time or even a third. It can be done with no problem at all if the steel has not been super heated past it’s limit on the first heat treat & ‘burned’ the Carbon out of it. So… if you ’miss it’ on the first go around, try again.
Tempering after heat treat is very important…. otherwise you just have a hard, brittle piece of steel. :person_facepalming:
Heat treating is a science. There are standard formulas for known steels that give optimum results if followed.
If you’ve never heard of Paul Bos (Buck Knives) & are interested in heat treating, do some reading… he was & is a master at it.
Just received my first 2 of 4 and want to commend all parties for the hard work.
These would have remained an idea but for the passion of BLF leaders and a company like Sofirn who listens to and (more or less) delivers exactly what we want.
I’m really impressed with the quality. I’ll have to snag a couple more of these little gems for friends. I think mine will pull double duty as an EDC and a bug-out bag/emergency light.
You are actually the first to come up with that. Twisties in titanium tend to suffer from gritty threads, but I have a ITP i3 in titanium that works very well. Does Sofirn do titanium editions at all? What would be nice is if the “pro” edition is there, to have that one in titanium
How drastic is the difference? I think the E01 with the Nichia GS was a good balance with a nod towards throw making it useful for maneuvering. Is the C01 THAT much floodier? Hoping it will make a good emergency neck light or backup light for camping.
You should probably keep an eye on Clemence’s Jetbeam modded with an Optisolis/E21A if you want an ultra high CRI AAA light with some output/throw. Of course it will be much more expensive than the C01.
C01 has no hotspot. To me, it’s like a zoomie on flood. If you want to use it as a tent light; it’s fine. But if you want to walk around or look for things; I find it harder than using the E01. Using indoor to walk around is fine as well because of reflections from walls.
I was thinking exactly what you’re thinking about neck light or camping light last night when comparing the 2 lights. I would put the E01 around my neck, not the C01.
