Indeed. You can immediately see a Zebralight begin to ramp back up, if you grab a “hot” one that has been tail-standing awhile.
When cycling, I can keep the SC600w MkIV Plus operating at it’s full 2300 lumen output, as long as the air is coolish and I’m cycling at a reasonable speed. It only lasts about 30 minutes at that output, though.
I still haven’t convinced Hank to update it to RampingIOS V3 or Anduril, which both make it a lot easier to hit specific output levels. Updates also make it a lot easier to calibrate lights to have nearly the same thermal response. Even on the old version though, the thermal behavior can be calibrated… just not as quickly or precisely as the new version.
It would also help to use a 3-channel driver instead of 2, like use a FET+N+1 instead of FET+1. That makes the middle modes a lot more stable, more efficient, and less hot.
I fail to understand this too.
Sure, regulated buck/ boost drivers have many components, and buck or boost drivers have more components than regulated FET drivers, and FET DD drivers have very few components, but i can’t see why they can’t put nice drivers in budget lights for 2 or 3 $ more either.
I guess it’s not a selling point for the targeted buyers…
It would increase the price by 25% sometimes…
It would be great if more brands sold their drivers separately, like Sofirn and Convoy do.
Skilhunt and Nitecore have nice buck and boost drivers too.
As for Zebralights, i think some of them look really nice, and the quality must be great too, judging by the price…
But too expensive for me to try if i like them…
One of these days. I keep reading how everyone that owns one loves it. I don’t think I can recall a bad review or experience with the company. I am slowly seeing price creep in my purchases.
I have own several in the past. I sold them all.
I did not like the UI. The tint was a lottery, I did get a sc62 with nice WW tint.
Now you have read how someone that owned several didn’t love them.
Wait, I still have a H50 in my foot locker. Its 3 speed twisty.
I didn’t know Skilhunt uses buck boost drivers. Do you know which models?
I’ve been trying to figure out what kind of driver the H03 uses but its not clear to me.
IMHO, the admiration and cult following towards Zebralight is legendary and well deserved. I just wish they were easier to disassemble… so reverse engineering could be better facilitated!
I still own a nice reliable S6330 (3 x XM-L with 3 x 18650) that I break out from time to time to admire its design perfection and efficient independent 3 channel boost driver with thermal throttle. It was way ahead of its time and still far better built than most other lights in its price range. Now if I could just remove the driver without destroying the entire light so I could re-flow new emitters. The driver is double sided with integral emitters on a single mcpcb. Great for efficiency and compact size, but not so good for mod junkies.
Similar as chadvone. I have bought zebralight headlight, because all the praises I’ve heard. It’s well made, light output is good, I like the low lumen modes, but that UI is terrible and unintuitive (for me). Because of that, I don’t plan to buy any other zebralights.
The driver efficiency is great. The host / build quality is good. Ergonomics are usually pretty decent. Overall size is usually quite compact. Output is generally pretty good, and spans a wide range from super-low to reasonably high. A variety of emitters are available.
However, the UI isn’t great, the tint is usually not very white or very consistent, it’s extremely mod-unfriendly, many of the emitter choices aren’t great, the lens coating tends to make the beam green, recent models crush batteries, and the prices tend to be relatively high.
It’s a mixed bag, so it really depends on what you value in a light.
I use a H52Fw for headlamp purposes, though I’ve been meaning to make a nicer custom one sometime. Otherwise my only ZebraLight use these days is to occasionally pull out a SC52 as a lumen measurement reference.
The mode memory, if it can be called that, remembers six things in the default mode group, and nine things in each of the two extra mode groups, plus one more thing in the strobe group. So if viewed from a certain angle, it has 25 mode memories.
But if you want it to automatically come on in whatever mode you were last using, no. It doesn’t have that.
Well, sort of. In G6 or G7, it can be programmed to use the 1-click slot in a manner similar to mode memory… but it takes a minimum of 15 clicks to change the level, so I don’t think that really “counts”.
No, those are buck drivers.
Buck / boost drivers are rare.
But the H15 probably has one because it is dual chemistry (NiMH and LiIon)
It seems the Klarus Ci1C has a buck / boost driver too, to boost for CR123A and to buck for LiIon, als depending on the modes.
I feel your pain. I purchased that light twice…unseen…once was from a reputable dealer around here that I will not mention. He even said it wasn’t green…when I got it I wanted to puke. Drove me away from ZL. Guess it was the luck of the draw coz others swore there was NO GREEN…. :smiling_imp: :confounded:
That said, ZLis one light I would have to purchase in person.
Older Zebralights (a few years ago) tended to be somewhat green, and the tint lottery could be pretty wild. But my last few Zebralights (SC5w, SC600w HI, SC600w Plus, and SC64w HI) are all very nice.
The greenest one I have is the SC600w MkIV Plus, which uses a domed Cree XHP50.2 emitter. Overall, it’s a decent tint, but white-wall hunting will show a bit of green/yellow in the corona, typical of domed Crees. Here’s my white-wall shot of the beam (auto-exposure, auto white-balance):
IMO, it’s not too bad, and it’s my worst one in the past few years. (SC52’s are worse, but they are several years old.) The ones I like best are the ones with the XHP35 HI emitter, that is, the SC600w MkIV HI and the SC64w HI. Those are very nice tints, clean and even beam, no hint of green.
Basically, if you want to avoid tint shifts in the beam of any light, stay away from domed Cree emitters. The XHP35 HI gives very nice beams.
As for the user interface, that is totally subjective. IMO, it’s the best thing about Zebralights, and I love the programability they added last year. It makes me dislike the user interface on all my other lights, even though many do have decent interfaces.
