This 2200mA buck driver (just new from KD, I bought 2 of these) claims a total height of 8mm. For a D4 type of light you want at least 6A to drive 4 SST-20 leds to a decent output, so a bigger coil is probably needed, adding thickness.
That's great news! Thank you Jay! Does he also offer different optics installed upon request? I only know about the 10622 as the standard optic for the D4.
He also offers the 10623 floody optic for the D4, which you can find in the regular options when ordering. Throw is reduced, but it makes for a smooth floody beam that’s great for indoor/close range use. For general purpose/edc, I’d stick with the 10622.
TK measured the driver cavity previously. It’s only about 2.5mm deep:
With a 4.5mm thick shelf, however, careful machining could hypothetically make a pocket for an inductor. I think even machining all the way through the shelf, as long as you kept the pocket no larger than necessary, would have a reasonably small effect on the heat transfer from the MCPCB to the rest of the body, especially for a 5.5A driver.
Has anyone ever figured out what the “grainy” finish is on the D4 and D1S lights? Its very unique and I can find no explanation of it anywhere, I have the white D4 and the grey D1S. I guess I want to know out of curiosity.
It’s just anodizing like on pretty much every aluminum light. However, there are different ways of doing anodizing, and the anodizing finish chosen on these lights results in a grainy unpolished finish, rather than the much more common smooth finish.
I have a few lights with a grainy finish like this:
White Emisar D4 (quite grainy)
Blue Emisar D4 (grainy, but not so much as the white)
Sunwayman T26C with tan finish (quite grainy)
Yellow Fireflies E07 (quite grainy).
Olight S10 Ti bead blasted. It’s not grainy anodizing like the others but has that same grainy chalky feel as the other lights.
Overall, I’m not a fan of the grainy finishes. Feels like I’m holding a stick of chalk. The texture just doesn’t feel good in the hands even though it does noticeably increase grip. I’d much rather have smooth anodizing with knurling for increased grip.
I didn’t realize that other brands were using that finish. It does make sense that it would be annodized, especially seeing that the inside of the battery tube is smooth anodize. I’m kind of with you, it looks nice but it’s not nice to feel with dry hands. If my hands are greasy/oily like with lotion or actual grease/oil it feels a lot better, but dry hands it feels chalky. If it is anno over media blast then it seems both together make it chalky.
This would be cool, but isn’t the FET more efficient on turbo then any buck/boost driver because in those all that current would have to pass through the inductor unless there was a bypass. I don’t know why the FET isn’t run in the transistion zone as a voltage controlled resistor which is essentially what the 7135 chip is. Obviously the FET would be using power so it needs to be cooled, and you probably would need a current sense resistor to keep the light regulated. This isn’t the most efficient but it could be more efficient in the 300-2000 lumen range then current PWM. I don’t find myself burning through 18650s like I was burning through single rcr123a and AA lights so maximum efficiency isn’t that important to me as the overall size of the light.
I would think that FET is most efficient if compared to a different driver pushing current at an equivalent value. Problem with FET is that the LED is running at a very inneficient point on it’s watt to lumen ratio. The other problem with FET is that it’s not regulated so output will steadily drop as battery voltage diminishes.
For those interested in sustained regulated outputs at various levels, buck or boost drivers are able to deliver the constant current and also drive the LED at a much more efficient level. It will also benefit from the low VF LED unlike a linear driver.
If peak output at turn on is your thing, FET makes total sense.
If you want to run the light at a constant 1000 lumen level (heat dissipation and PID aside) buck and boost drivers are fantastic. I love being able to turn on my dqg tiny 7 x 219c at medium or high and know I can rely on a consistent output over a very long duration of time without worrying if my battery is full enough.
I think FET lights are successful in the emisar lights because of the peak lumens and genius pwm programming of the driver.
I think if Hank releases another line not focused on winning the lumen war but on efficiency more similar to Zebralight, he will have another wave of success… Fingers crossed.
A FET can be run as a regulator instead of PWM, that’s basically what is inside a 7135. You could drive the LED at a constant current and therefore the LED would be high eff but theoretical downside is you are burning voltage with the FET. Basically a FET run this way would be the same as infinityx7135 lights.
