I've found that a good test for laptop cells is to test the voltage during salvage. Anything under 2.8 gets gone. Those that make the cut get charged to 4.20 and then set aside for 2 weeks. If they don't hold a charge when measured at 2 weeks out, they go in the junk bucket with those below 2.8. Generally, I find that if they hold 4.2-4.1 for two weeks they will likely be usable in single cell lights. I'll occasionally put a few on the hobby charger and see what the capacity is, but I have found that generally the ability to hold a charge is a pretty good predictor of which cells will also still hold most of their rated capacity.
I've salvaged a bunch of 18650's from dead laptop packs. In every single case an AW or TF flame out performs them hands down. Salvaged cells are good in a pinch, but do yourself a favor and invest in some good protected cells.
Just keep in mind that production year 2008 is Q for Sony and M for Sanyo, then look on your cell and count backwards or forward to your letter while each letter is a year.
mh i dont know what r1122 means. but its not the manufacturing code, because you see r1122 on very much newer batteries from sanyo. and on those newer batteries there isnt any manufacturing code anymore. the only thing i could find, is:
