[Optisolis/E17A/E21A] Jetbeam Jet-µ
293 posts / 0 new
moderator007
moderator007's picture
Last seen: 17 hours 51 min ago
I have seen the same thing testing batteries at higher currents. The warmer the battery the better it will perform.
If you run a capacity test on the same cell twice and don’t give the cell a rest after the first test after charging the cell, It’s warm from the test and charge. It will tend to have better performance on the second test with usually less voltage sag and higher current. I have noticed it most with the smaller cell sizes.
BlueSwordM
BlueSwordM's picture
Last seen: 42 min 36 sec ago
In all type of cells, being based on a specific chemistry, benefit from higher temperatures in terms on internal resistance along with capacity because of the faster ion movement permitted by higher temps. Although in terms of current provided, it obviously has its limit because of electrical conductivity dropping with temperature.
So don’t push it say above 40-45C, except for high discharge cells, for good cycle life obviously.
This can be used in a certain way to actually be beneficial though:
When discharging in cold weather, internal resistance is increased. However, heat dissipation is increased. So, as you discharge the cell in colder weather, performance actually gets better Smile
clemence
clemence's picture
Last seen: 2 weeks 20 hours ago
OK, the prototyping is final. Below are the runtimes for Jetusolis and JetuE21A compared to stock XPE2. All measured in cooled 25° condition to avoid fluctuation in battery capacity as encountered earlier,
I will post the beamshot with alternate optics later.
- Clemence
iamlucky13
Last seen: 28 min 45 sec ago
- Clemence
Those look good to me. Very reasonable compromise in output for the significant improvement in CRI.
Since the 5000K Optisolis uses a 420nm diode, compared to the more conventional 440nm diode in the warmer Optisolis variants, with a consequently higher forward voltage, I’m guessing the warmer versions will consequently run a little bit longer at the same current.
clemence
clemence's picture
UPDATE181218: Some pics and measurements
- Clemence
g_damian
g_damian's picture
Last seen: 1 hour 45 min ago
When will they be available to order?
Phlogiston
Phlogiston's picture
Last seen: 21 hours 24 min ago
Looks nice Thumbs Up
Do you have any 5° TIRs, by any chance?
clemence
clemence's picture
I’m getting it today
Only up to 10°. At very close range this 10° with its rectangular tight spill already creates some artifacts, the 5° will be worse I guess. The narrow spill is very useful in cases such as mouth or nostril inspection where you don’t want too much glare to the patient. I myself prefer the 20°. The stock optic has bad yellow tint shift ring around the hot spot.
- Clemence
twisted raven
Last seen: 5 sec ago
What are the CRI and CCTs of these E21A and Optisolis emitters?
clemence
clemence's picture
R9080 minimum for the E21A and way higher for the Optisolis. Judging by Maukka’s test results, its currently the highest CRI LED available today.
- Clemence
jon_slider
jon_slider's picture
Last seen: 41 sec ago
also check out the detailed info on his site, for example:
https://www.virence.com/product-page/nichia-nvsle21at-nvswe21at
Jerommel
Jerommel's picture
- Clemence
Wow.
Even better than Yuji D50 LEDs??
2Q19
clemence
clemence's picture
Phlogiston
- Clemence
Thank you!
I have tunnel vision, field of view well under 10°, so I’m always on the lookout for lights that put all the light where I can use it. 10° would still be pretty good, though Smile
Lightbringer
Lightbringer's picture
Last seen: 1 hour 26 min ago
Aspheric+spacer?
The reflector is H units high, so you can fix an aspheric lens H units above the LED to “zoom” it somewhat.
Problem is finding the right lens…
Jerommel
Jerommel's picture
clemence wrote:
!{width:80%}https://farm5.staticflickr.com/4876/46365904341_d2d77aafe1_o.jpg!
Ah... indeed..
Dang, i paid good money for a bunch of those Yuji's...
O well.. Smile
2Q19
Gunga
Gunga's picture
Last seen: 34 min 14 sec ago
So will these actually be sold? Looks very interesting.
clemence
clemence's picture
Yes they are. Supposed to start the production yesterday but I’m still sick right now.
- Clemence
Gunga
Gunga's picture
Oh sweet. That’s awesome!
Hope you feel better soon!
clemence
clemence's picture
UPDATE181221: Maukka calibrated Jetusolis
If you guys interested to make a calibrated light using this Jetusolis, you can ask Maukka and check this thread:
http://budgetlightforum.com/comment/1431561#comment-1431561
The pricing for Jetusolis:
1 – 3 pcs = $28,5/pc
4+ pcs = $27/pc
- Clemence
contactcr
Last seen: 14 min 20 sec ago
I dont see pricing or where to even purchase
clemence
clemence's picture
Sorry, forgot about that. The price:
- Jetusolis is $27 – 28,5 depends on quantity
I haven’t officially launch it to my store but you can fill the interest list in Maukka’s thread
- Clemence
contactcr
Damn Indonesia to Finland to US. Wonder if I will get it before the end of 2019.
If it makes sense you should ship as once big batch expedited to maukka
clemence
clemence's picture
Correct, that’s the idea hence Maukka’s interest list
maukka
maukka's picture
Last seen: 4 hours 51 min ago
Of course if you don’t need the data, just order from Clemence when he makes them publicly available in his store. No reason to include an extra step in that case.
DavidEF
DavidEF's picture
Last seen: 1 hour 16 min ago
Thanks for the clarification.
- The YKK Philosophy
Jerommel
Jerommel's picture
Hey Clemence,
Any chance of buying a couple of those 20° TIR optics from you?
It’s pretty hard to find something decent in that size via the normal pleb channels..
Or maybe you got them from Yajimei?
2Q19
clemence
clemence's picture
Jerommel wrote:
Hey Clemence,
All those TIR optic prices are all the same at $0,2/pc. Both types of the MCPCB price is $1,58. You can order them via the store soon (before Monday)
You might want to wait for the 30°optics next week, currently only few left. The vendor sent me wrong optics earlier.
FYI, they fits Fenix E05 too
- Clemence
Jerommel
Jerommel's picture
Great! Beer
Thanks. Thumbs Up
Yeah, 30° is usually the best for a TIR (i.m.o.).
2Q19
peabody
Last seen: 3 min 32 sec ago
So we keep ckecking Virence for the release of these?
