You just need a fine tip iron. Since not much current flows through these tiny resistors, you only have to add a tiny bit of solder to fix them into place. Scrape the metal areas on the driver. Add some flux if you have it. Hold the resistor in place with fine tipped tweezers or maybe a toothpick, whatever is handy. Get your iron hot, clean the tip, add a tiny bit of solder, then touch one side of the resistor and the driver at the same time for just a second. It should stick, then do the other side. If you attach it to the spring it may take longer to get the solder to flow on the spring.
You can buy these lighted tail cap kits for like $1.30 each *for S2 size lights. I’ve got a few sitting around that I need to play with.
You've motivated me to give it a try thanks. I have a fine tip ion and will do some practice runs and give it a go under my magnifying light. Curious to see if my hand is steady enough for that type of work.
Use lots of light so you can see what your doing. I use a headlamp.
I was just looking at some Hakko T18 tips and I see they make a needle tip which is superfine. I might try and pick one of these up. Seems good for SMD work.
That was one of the best tips ever to use a headlamp, it's going to make it way easier for me. I use them all the time in construction and it never occurred to me for soldering.
I put a 60° TIR lens in a Boruit D10. It gives me a very floody and smooth beam plus 5 well spaced brightness levels. It’s a T shaped light. The L shaped lights always make a weird shadow which bothers me.
I could use some help, but I’m sorely lacking on details…
I picked up an L6 from Banggood for a friend along with a couple 5000mAh Efest 26650’s. When it arrived it acted really strange (like an erratic buzzing strobe) and I came to the conclusion that a wire was barely shorting on the bottom of the reflector. I got that fixed and it was working great.
I handed it over to my buddy today and he went to use it tonight and it worked great for a couple minutes. Then he claimed it got stuck on strobe. He says it’s very consistent and bright, not the sporadic behavior I noticed before. Batteries are charged up and he says everything is tightened down.
I plan to meet up with him tomorrow to check it out. Any thoughts so I can hit the ground running? It all sounds pretty strange to me.
Any chance the white plastic centering ring was missing? Had one missing on one of my L6's. Also, I covered the + and - solder joints on the star with kapton tape just to make sure there would be no contact with the reflector to mess things up.
Thanks for the tips, guys. Unfortunately I don’t have any kapton right now, I really need to pick some up. I did ask him to try removing the reflector completely and he said that didn’t make any difference. I’ll see when I have it in my hands.
For the stock driver, does it memorize strobe? Or does it reset after a power disconnect?
Doesn't memorize strobe after power cut, it goes to the next highest setting before strobe was activated.
If it was on low, then strobe activated, then power cut, then power on again, it would be now at medium.
Could be a driver or side switch problem, or maybe it's doing the erratic strobe thing thinking battery is low as I know the L6 has a low battery warning. If that is the case, could be a loose retaining ring in the tail cap or the secret ring on the battery tube itself not being fully tightened and restricting current flow.
New Convoy L6 XHP70.2 (SMO) or Thorfire S70s (xhp 70, OP) ?
Who sees the best in the beam distance ? thorfire 680m (specs) = HEAD 74mm convoy old and new 200-500m (specs) = HEAD 75mm
I had thorphire s70s but did not see 680m. Otherwise I was very pleased. A very good flashlight.
SMO convoy l6 will have more throw depending on how hard both leds are driven. The claimed throw in meters is just a calculation. To really see something well lit most people half the calculated throw for real world throw.
The Convoy L6 XHP70.2 (SMO) is definitely going to have the better throw distance. My tests show an easy 60 meter gain by swapping the reflector from OP to SMO on a stock light.
The 680m spec is pure BS. So is the lumens on both lights. Unfortunately, I forgot to measure the stock throw on my S70S before I started modding it.
The older Convoy L6 XHP70 (OP) and the S70S XHP70 (OP) pretty much have the same stock throw distance of 480-500 meters.
The lumens on the S70S are about 2900 to 3000. The original Convoy lumens are a tad lower at 2800 to 2900.
So they are very similar, virtually identical, in their stock form. With the Convoy L6 using a 70.2 and a Smo reflector, it should have a nice increase in throw. At least 60 meters.
BTW, I did take a stock S70S and swap the driver to a FET design. This bumped up the lumens to about 4,700 and increased the throw to 707 meters. A very nice increase.
My L6 with FET driver, 70.2 (5,000 lumen) and SMO measures about 830 meters. Based on several other peoples measurements after slicing the dome off of the 70.2, I predict my light would extend its throw to about 1,100 meters.
I don’t like the UI or the crazy high parasitic drain on the stock S70S driver (or stock L6 UI for that matter) nor do I like the overall look of it or feel in my hand. I think the L6 is definitely the better light.
My measurements from around 10 Convoy L6 XHP70 OP version are between 3000-3400 lumens.
I also measured around 6-7 stock S70S and they are between 3700 and 4100 lumens.
So XHP led OP versions: L6 has better look and more grippier feel in hand, but Thorfire has better output and more accessories and better UI.
I did not measured L6 XHP70.2 yet.
Just my fully n dded two hotrods but that is not even close to stock.
Our integrating spheres don’t seem to be measuring the same. You’ve got the big round type integrating sphere, right? Maybe the tube type spheres don’t scale up well?
Did you measure about 4.6A to 5.1A on both stock lights depending on the battery?
