That makes sense, I guess I should contact Fireflies then.
Thanks for the fast response ToyKeeper .
[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
As you guys know, skylumen have two dead pl47. FYI
Any details posted about that somewhere?
It may or may not posted… I communicate with him on the Facebook messenger.
I bought the XPL Hi V2 3A 5000K Neutral White. I’ve been reading about some battery restrictions for the Nichia 219B. Other than some of the size issues are there any amp issues? Can I use an EFEST 35A for example?
Finally received my lights. After being held in my local postage service for a week.
When I unscrew the battery tube a little to lock out the light a very brief and tiny red flash occurs from something near the centre of the lens. Can anyone explain this phenomenon?
Had that same feeling too! Red led ?
Newlumen:As you guys know, skylumen have two dead pl47. FYI
I’m curious. All I’ve ever heard and read is that his stuff kicks butt and then takes names for more orders. Also the skies open, ethereal angelic-like beings are heard singing, and the dead are known to arise from their graves - besides just being an average legend. Other than that he must overall be a pretty good decent modder. I kinda surmise besides big time driver pro savvy he prolly gets uber top bins like you and I inhale and exhale. Butt IDK. I sorta envision him…
post #192
The red light in the center is a warning that the voltage is low.
It happens when unscrewing the light because, for a very brief moment, the voltage passes through the “low” range before it hits zero.
It also happens when the battery is genuinely low.
Nice feature!
I just got my pl47 219b. I am not happy with it. I put 10 amp 18650 and the light goes straight to blinking mode.
I can’t switch modes… it stay on low…
How can I reset to factory ramping mode?
did you tighten the rear cap well?
My other pl47 xpl hi 5000k is working fine…
This pl47 219b is no good… aux was off from the factory… i click 7 times to turn it on…
When i press the button, th aux will turn off… then the low mode came on. Then the light switch modes by itself…
Junk junk junk
mine had a low mode and it was blinking because it did not have good contact. I have to tighten the rear cap quite strongly. your apparently has a more serious problem.
Yes… i have tighten the tailcap good… the light start blinking every 10 seconds…
I will contact FF.
It gets brighter on its own. Wonder if it is in some kind of test mode. Maybe Toykeeper might know?
How do you guys deal with the warranty?? Do you send the defective light back to china??
From what I’ve read, seems like Jack will just send you a new one. You might have to show him a video to show how it’s defective.
Guys one question please
what's the difference between Anduril UI and Narsil UI please?
