Sofirn Q8 group buy (gb closed, but try PM to Sofirn for discount)
1244 posts / 0 new
teacher
teacher's picture
Last seen: 8 months 5 days ago
MRsDNF wrote:
You know this mod should have its own thread Dale. Smile
+1 .. It really should. . Thumbs Up . Wink
DB Custom
DB Custom's picture
Last seen: 21 hours 30 min ago
Ready for the new tubes/carriers any time now. Smile
Today I researched the specs on the Ledil Angie and Noctigon quad MCPCB, made sure what depth I’d need between the emitter shelf and lens. Then I went out and cut the shelf to the right depth. Recessed the lens shelf in the bezel so the 2.2mm UCLp will fit properly. Then I cut fins in the bulk of the body. This is the part I really have the most trouble with on this lathe, using the parting tool. But it was being nice today so I went ahead and got the big head ready for mounting emitters. I can use a drill press I have on the back porch to do the rest of the assembly once I get the remaining pieces.
This Sofirn Q8 is all primed and ready to become a monster. Wink
teacher
teacher's picture
/\ … Looking good Dale, real good!! . Thumbs Up
DB Custom
DB Custom's picture
I would like to shape the rear of this big head down towards the Q8, but I won’t do that until it’s running and shows me how it handles heat. No need to remove cooling mass if it is going to be needed, and it may well be that even this is not enough.
I’m getting a strong feeling that the cells won’t be able to supply the power I want, especially in the carriers. I will probably have to fortify those but it remains a question as to whether or not I’ll be able to feed all these emitters.
Edit: I might have to make a new battery tube to hold 4 21700 30T’s. Smile
JasonWW
JasonWW's picture
Last seen: 32 min 1 sec ago
Dale, are you going to screw down all the mcpcb’s to assure they all make good contact to the shelf?
DB Custom
DB Custom's picture
I don’t think so Jason, the aches and pains created thus far thoroughly convince me that drilling and tapping 10 small holes would not be in my best interest. I will use Arctic Alumina Thermal Adhesive and apply pressure while it cures, the lens will press down on the 5 pieces as well so I will use the lens in the mounting process and either a weight or my tabletop vice. I have the 3mm thick glass lens I can use, 95mm UCLp is on the way for the final. This should serve the purpose, will have to do.
Noctigon MCPCB’s and Optics have landed in Chicago, estimated delivery is Tuesday.
Need to get busy building the 4 Slave drivers and set that all up on the Master. Also need to drill for wires to run. About 10 hours in and plenty to do still…
JasonWW
JasonWW's picture
Adhesive should work, but I would not trust the glass to push down equally on all the lenses/mcpcb.
DB Custom
DB Custom's picture
This isn’t the first time I’ve done this Jason. Wink Not even only the tenth… I’ll figure it out, usually do somehow.
The driver, well, speaks for itself I reckon…
I have the 2 screws mounted to lock the new head in place, this is the 2 screws that formally went into the reflector so it wouldn’t rotate. Working on getting the central hole drilled for the wires to run up through. I swapped the MOSFET and 7135 chip on the original Q8 driver so all drivers have the same components power wise, the original driver will supply power directly to the SST-40 in the middle via both red and black wires as usual. There are 2 14 ga positive leads that will be shared between two quads, so two of the quad boards per 14 ga positive. Then each Slave driver has an 18 ga Teflon coated lead for the negative. I used 26 ga Teflon wires for the signal leads, green to the MOSFET and orange to the 7135.
Haven’t tested it more than to ensure Anduril is working, so there’s that still to do as well…
teacher
teacher's picture
Wow-zer!! Nice!!! Appreciate the update with pics. Thumbs Up
DB Custom
DB Custom's picture
25,426.5 lumens at start… 22,700 lumens at 30 seconds.
This one turned into quite a lot of work!
DB Custom
DB Custom's picture
See the stack of 16 Samsung 30Q’s that came today? Ready for those tubes/carriers… Wink
teacher
teacher's picture
Impressive, VERY IMPRESSIVE!! . Thumbs Up
Thanks for sharing Dale. Wink
DB Custom
DB Custom's picture
Still have some details to nail down, and there will eventually be a double carrier tube on it…
teacher
teacher's picture
I like it. I saw the video you posted on the other thread measuring the lumen output.
It’s a beast!! . Beer
JasonWW
JasonWW's picture
I want to see an outdoor video of it.
teacher
teacher's picture
/\ …… Me too!!
JasonWW
JasonWW's picture
I’m guessing the beam will look like a souped-up Astrolux MF01.
DB Custom
DB Custom's picture
I used to get really excited to see 12,000 on my meter, then later if it got up to 20,000 I was really impressed! This one? Over 70,000 on the meter! Gonna run out of meter soon at this rate!
Used it tonight walking the trash can the 300 yds down to the road, really like the beam on it, at much much lower than full onslaught mode of course. Very nice even for a general purpose walk, that double click to Turbo is silently lurking in the background, waiting to turn the sun back on… Big Smile Using it a a decent middle to well lit range for this walk it didn’t even begin to get warm. Pretty sure outside, in the cool of night, with some breeze, it should easily run the cells down without discomfort. At least in present 4 cell configuration.
teacher
teacher's picture
Pictures or it didn’t happen…… Silly .. Wink
Seriously, when you have time; give us a beam shot or two please.
DB Custom
DB Custom's picture
teacher
teacher's picture
Wow, thank you Dale…. very impressive!! . Thumbs Up
DarthnataS
I just wanted to say that I received my Q8 from Sofirn off of Amazon, and this light is amazing! It lights up across the street which is at least 600’. I don’t find that the light is too throwy at all, it just seems to light up the entire 4 acre yard. The light is very well made, with quality at least the equal of Olight or Fenix.
I wan’t to give a special thanks to Zoe at Sofirn. Excellent customer service. This won’t be my last light from them.
Barry0892
Barry0892's picture
Last seen: 47 min 34 sec ago
Sofirn will appreciate more if you write a review on amazon page. Big Smile
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
DavidEF
DavidEF's picture
Last seen: 2 days 7 hours ago
Is there any possibility that I could still get a discounted price? The last update in the OP, about contacting Sofirn to try to get a discount, was October 11.
- The YKK Philosophy
JasonWW
JasonWW's picture
Just send Sofirn a message asking about a discount price. It may be Monday before they answer. Actually, I don’t know how long it might take. They may be gone till mid January. All of China is basically closing for the holidays.
DavidEF
DavidEF's picture
Thanks Jason. Thumbs Up
Mtonne
Last seen: 1 day 6 hours ago
Received my Sofirn Q8 today and within six hours it was already saving my butt.
Surprising my son with a trampoline for Xmas. Got everything out and looked thru the instructions. What I thought would take an hour to assemble ended up taking 4.5 hrs with help from a buddy. The last 4 of said hours were in the dark. I put some flat top 30Qs in it (button tops yet to arrive), turned it on and stuck it it a nearby free. Instant flood light that ran the whole time. The freaking thing literally saved Xmas at my house. Tonight was my only chance to get the thing up before Christmas morning.
woodyt
Don’t know if too late but I’d like to get a code for one also if possible. Thanks
sbslider
sbslider's picture
Last seen: 5 hours 50 min ago
I know this doesn’t help you, but I will comment that Sofirn had a special earlier this month where they were giving 50% off a light purchased on amazon. I purchased a Q8 for a net of $30. I don’t post this to spite anyone, more as a comment to keep your eyes open for when they have another special deal like this. Mostly for DavidEF, who posted just a couple days after the special ended.
On a more positive note, I purchased a different light from Sofirn on their Aliexpress store in the past couple days, and they sent me a message saying they would be back on Jan 2. Hopefully you get a message back from them regarding a discount coupon in the next day or so.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
woodyt
Thanks slider
