Nice you started offering high-cri convoys. However most producers seem to implement the SST-20 or LH351D high-cri leds instead of the somewhat oldish 219C.
Imho the OP reflector should be by default in the S2+ instead of the SMO since the S2+ is an allrounder/EDC light, not a thrower.
Please consider using the well regarded and desired XPL HI 5D or 5A with a nice tint instead of the ugly and yellow XPL HI U6-4C.
Emisar sells the 5D with great success.
Maybe we should open a new thread with requests, to see what people like.
On this way Simon can see what might be a succesful lights.
We all love convoy, since it it is proven quality an its mod-ability friendlyness, with a bunch of spare parts to change the light to our wishes.
I would like for example a single cell light like a Emisar D4 from convoy, with Narsil UI but with a smooth Stainless steel bezel (like the Jaxman E2L.)
It would be nice to have the option for multi or single emitter with optics or reflector (like Emisar has multiple choices)
Or something like a XHP50 on a single cell from Convoy with a new sleek design.
For XP-L HI 5A/5D, I would like to mention this Cree code:
XPLAWT-H0-0000-000HU60E5
This is just one bin lower than the 70/75 CRI options of the same CCT, 5A/5D with this 80 CRI option could be nice.
For XP-L HI 3D/4A, I think, one of these codes would be the best:
XPLAWT-H0-0000-000LV20F4
XPLAWT-H0-0000-000LV20E4
This is a bit better with 75 CRI - the 70 CRI options are of the same performance bin, so this could be a nice option.
With these two options above, 3A/3B and 4C tints could be replaced.
Speaking about new flashlights, I think, a single (or double serial) 21700 flashlight with d = 22mm driver would be nice.
Thanks,i will consider to use SST20 or LH351D ,too
S2+ is not a thrower even installing SMO reflector,but the OP reflector can make the light spot even.
5D and 5A is a little redish ,i will try them
i’m ready to launch an new model ,single cell ,XHP50.2
it seems not meet your requirement,I can refer to your request and design an flashlight with side switch and stainless steel bezel and type-C port,
what battery are you ready to use?
I don’t find charging circuits in flashlights useful. Flashlights are bigger and less waterproof. It’s easier to swap a battery and continue using the flashlight.
