I checked my 2 more closely today….
- Fit n’ finish on both is very good
- Reflectors seem well done, both are what I would call Medium Orange Peel
- I really like the size of this single 26650 light. The size is a big plus as is the relatively cheap price for this quality light.
- Both have a greenish halo around the hot spot & that same greenish spot in the middle of the hot spot. Somewhat ugly if you get right down to it, especially indoors… outdoors is not so bad or as noticeable. To me anyway…
- The switches on both of mine are somewhat finicky.
Sometimes they will cycle through L > M > H and sometimes they won’t. It is almost as if the driver has to warm up a bit after sitting a while???I’ll have to check it out some more.
One unit is much worse than the other. This may well require attention…. we shall see though.Edit: This was ‘operator error’. The ‘short clicks’ need to be fast & crisp.
- The double click to Turbo must be extremely fast to work. This is not a complaint, just an observation.
- One unit was ordered as a ‘26650 Kit’. While I have not tested the capacity of the battery yet, it seems to be a decent battery.
- Both have Serial Numbers right under the warning word ‘HOT’ on the head.
That ‘be’ all for now….
