I'll take one!
i`ll take one !
Hank , whats the link to this LED / mcpcb please
Type in LED4POWER. Think they are on their home page.
Here is the code, we have also made some gasket for this particular LED
10fp: Hank Wang:After some more test, we decide not to provide the D1S+ due to the issues below:
But we will still offer this LED on the Noctigon MCPCB.
Regards,
HankHank , whats the link to this LED / mcpcb please
How to order? it’s not on intl-outdoor.com
Hank where is the CODE ?? i want to order one can`t see it on your site
I do not mean the discount code, but the
label code on the package, CSLNM1.TG LED in stock now.
Nice, I think people will be very interested in the gasket when buying this led. Will they be sold separately as well?
10fp:Hank where is the CODE ?? i want to order one can`t see it on your site
Are you planning to sell a version with a warmer color, some 5000K?
Hank can you make gasket for 7mm and 9mm hole reflector also? This is the two most common hole size.
Hank please put oslon white in the Meteor and D4S!
Does anybody know if i use a Sanyo GA in the D1S with oslon white, will it work?
With a flashlight that uses a direct driver like the D1S you need to add resistance, by using a high resistance battery (the GA is still too low resistance/high current perhaps a NCR18650B works) and using long thin led wires if you can get the driver out. If you are handy and smart enough to find a spot for it, you may be able to add an actual resistor somewhere in the current path. Unfortunately Hank’s springs are very low resitance, maybe swap the copper-alloy tail spring for a steel spring. Experiment, keep measuring current and see if you can get to 5A or lower.
I asked him refarding the d4s already. He said the beam doesnt look right. Would be awesome if he can get them in the meteor though. Love the focused beam.
Also Hank, please sell the oslon white centralizers on your store.
scr79423:Does anybody know if i use a Sanyo GA in the D1S with oslon white, will it work?
Like that you eliminate all the benefits of the low Vf of the White Flat 1mm².
are you going to add those gaskets for sale in your website as well ?
edit
ok you cann buy it with led and pcb.
Hank Wang:we have also made some gasket for this particular LED
edit
But for what reflector hole size? 7mm for D1S? Hank please make them for 9mm also!
Thank you Hank for making these available, placed an order along with some other goodies
Thanks Hank, for D1s + white flats + gaskets
Dave
