6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
You know what, there might have been some confusion about the chip orientation. I think it was Pin 2 after all and not 7.
I have got this driver working. I also lost the indicator light pad. Both mishaps where my fault and had nothing to do with the with the driver. I had the driver in a small vise when I was soldering the switch wires on, when I took the driver out of the vise the head of the light caught the vise, my solder joints held and the pad didn’t.
Thanks everyone that contributed to my success.
It would be interesting to install a driver waiting for Eagle Eyes X6R with the Narsil v.1.2 firmware and an E-switch
Is it possible ?
According to the hwdefs, TK’s 4-channel lightsaber driver has the switch on pin 7 :slight_smile:
as far as I have seen the X6R uses switch on the main board and another piggy back board for charging and AMCs
It may be possible to add one of my drivery, you may sacrifise the charging board, like here and here
if the driver cavity is deep enough yopu may use charging board as well
Some lights make good hosts, some don’t. Due to the switch, the X6R does not look like a good host light.
Shipping conditions in Germany changed
usually you could ship whatever you wants just needed to look to size and weight specs
for sending items you could simply make another stamp and declaration and envelope had not to be glued and it was even cheaper on size and weight compared to normal envelope
now they simply changed normal envelopes to papers only, so they can charge more on non business customers for a parcel instead raising the price from 3.2€ to 18€
and for sending items you need to make a business account with 200 national shipment per year minimum quantity
this would not apply to me
If they check with x-ray or so the stuff I sent last days may be returned
Look in to DHL eCommerce
I doubt I will ever get back to 4€ tracked and 25€ insured envelope
if they really filter non paper envelopes with drivers in them with x-ray I got literally no other option than to send by DHL (17€ untracked uninsured or 46€ tracked and insured)
The DHL ecommerce isnt the fast DHL. Its a different product which i assume would be cheaper but i couldnt find pricing without getting a business quote
yes you need 200 per year minimum national and 5 per quarter international
no way i get that many national as most is international
is it possible to make a FET+N+1 driver for a 2s2p configuration on a MF02S?
does not make sense, as the LED is 12V, it woulsd smoky any AMCs plus its not regulated
Buck driver with 4S carrier mod is the way to go, we got full output and regulation
Ahhh, the custom X6R driver exists - I've used them recently.
This is a triple stack from PD68, old but latest driver design. All my pics on this triple LED X6R mod here: photobucket.com EagleEyeX6R Triple
It's a great light now - triple 90 CRI XP-L2's, though I didn't get in an AUX LED - need to add that still.
Hi Lexel, could you build me a
DD+7135 for 2S/2P and XHP70.2 for my MT70?
Hi as I mentioned before the MT70 uses a 12V LED board, so you cant DD it from 2S/2P same with buck driver
the Carrier mod is needed in any case
I could build a modded AMC board with DD FET + small FET with resistor 2 channel, but rather prefer regulated Buck driver for it
This is the standard solution if you dont want to change LED board to 6V which on the other hand would mean limited current capabilities with buck as voltage is reduced
Sorry to hear about your shipping troubles Lexel. You do great work, please keep us updated if you come up with a better solution. I’ll still be buying from you even with the higher shipping. Totally worth it.
Shipping is still possible, but for bulkier better use new Item letter which got more expensive
Seems I can use international with 5 per quarter and no limit for my country but then its also more expensive than last year
So 3.8€ for >10mm untracked
6.8€
Oficially items are banned from. Ormal letters but I dont think flat drivers will cause issues as they can be handled by sorting machines
Is there any reasonable option for expedited shipping to US?
I could send DHL Express for about 40€
