only side switch ,no tail switch,right?
yes, floody,it couldnt be a thrower because the diameter of the head is not big
TIR optics is really even.
…and cheaper !
In Simon’s video here:
https://www.youtube.com/watch?v=Ju-jzbmNq00It appears the BD03 might have an e-switch in the tailcap due to the battery carrier device. Is this the case? If so, we could put a nice driver in this one.
it’s 1288 switch inside, my friend
This looks great. 21700 with Type-C recharge will be awesome! Can we request that the driver is separate from the USB C recharge so it can be replaced? I’m sure many people will like to mod this flashlight with spacer and quad emitters.
Also, would be nice if you can come out with a 21700 S2+.
Simon Mao:i’m ready to launch an new model ,single cell ,XHP50.2
it seems not meet your requirement,I can refer to your request and design an flashlight with side switch and stainless steel bezel and type-C port,
what battery are you ready to use?
Separating the type-c port and driver increases difficulty of flashlight assemblement and driver production.
i can ask driver manufacturer to produce several kinds of driver what you need.
21700 S2+ was added in my plan
Simon Mao: Ryzbor:Great to see you on BLF Simon!
Nice you started offering high-cri convoys. However most producers seem to implement the SST-20 or LH351D high-cri leds instead of the somewhat oldish 219C.
Imho the OP reflector should be by default in the S2+ instead of the SMO since the S2+ is an allrounder/EDC light, not a thrower.Please consider using the well regarded and desired XPL HI 5D or 5A with a nice tint instead of the ugly and yellow XPL HI U6-4C.
Emisar sells the 5D with great success.Thanks,i will consider to use SST20 or LH351D ,too
S2+ is not a thrower even installing SMO reflector,but the OP reflector can make the light spot even.
5D and 5A is a little redish ,i will try themTIR optics is really even.
…and cheaper !
yes, i agree
I love 30° pebbled TIRs in S2+ like “cigar” lights.
Even XP-L2 looks good with it.
“21700 S2+ was added in my plan”
That’s going to be awesome
That is great news! I think with the 21700 form factor, people will be buying the S2+ 21700 to mod with quad emitters and carclo quad optics like how everyone was modding the S2+ 18650 with triple emitters so I think we need at least 10A max mode. But that might be too much for the stock single emitter.
a s2+ with triple optics and 21700 would be really nice light.
This sounds like a really great plan.
Chatika vas Paus:Simon, what about L2 with side switch? Many users would be very happy.
Yes. Only side e-switch.
Since we’re using this as a Q&A thread…
Is it possible to put the Nichia emitter on other lights like the M2, Simon?
Will be throwier TIRs considered for newer Convoy flashlights?
There are a few very nice LEDIL TIR optics with bigger head diameter.
Hi,
Does a pocket clip come with the S2+?
Are the tint options 5700 & 4700 as in the thread title or 5700 & 4000 as on the website linked in the first post?
Regarding the UI, is direct access to low from off available only if memory is disabled or if it is the memorized mode?
What battery would you recommend for the S2+? I don’t have any 18650.
Thanks.
Hi,
Thanks.
Normally the lights come with pocket clip
About the UI, you can configure the modes you want according to the this diagram: http://i.imgur.com/jvx04IR.jpg
So, you can put it starting from moonlight, if memory is disabled! If memory is enabled (last mode memory), you can leave it in Moonlight before turning the light OFF and then it will start in Moonlight.
Taking into account the configuration of this flashlight (4*7135, and Nichia), I would recommend Panasonic NCR18650B (it is not a high drain battery, and has plenty capacity for longer runtimes).
Hope this helps!
Just to add: it’s much easier than it seems.
alex64:Hi, it’s possible to buy the Nichia version with S2+ Desert Tan model?
yes,and what driver and reflector?
Driver 7135x4 or 7135x6 (I don’t know which is best for Nichia) and OP reflector if is posible.
Thanks.
Why triple when the original S2+ can already accomodate triples? The S2+ 21700 should be sized to accommodate a Carclo 24mm diameter quad optic. Quad will provide a little extra output and efficiency over triple.
LightObsession:Hi,
Thanks.
So, you can put it starting from moonlight, if memory is disabled! If memory is enabled (last mode memory), you can leave it in Moonlight before turning the light OFF and then it will start in Moonlight.Taking into account the configuration of this flashlight (4*7135, and Nichia), I would recommend Panasonic NCR18650B (it is not a high drain battery, and has plenty capacity for longer runtimes).
Hope this helps!
Thanks for the info.
Too bad that one can’t have memory enabled and still have direct access to low without low being the last mode used.
Glad that it comes with a clip - none was mentioned at the website in the link in the first post.
I may end up getting one anyway in the not too distant future.
Any verification of the tint options?
