【convoy】H4 and B35AM options are updated
That is great news! I think with the 21700 form factor, people will be buying the S2+ 21700 to mod with quad emitters and carclo quad optics like how everyone was modding the S2+ 18650 with triple emitters so I think we need at least 10A max mode. But that might be too much for the stock single emitter.
a s2+ with triple optics and 21700 would be really nice light.
This sounds like a really great plan.
Yes. Only side e-switch.
Since we’re using this as a Q&A thread…
Is it possible to put the Nichia emitter on other lights like the M2, Simon?
Will be throwier TIRs considered for newer Convoy flashlights?
There are a few very nice LEDIL TIR optics with bigger head diameter.
Hi,
Does a pocket clip come with the S2+?
Are the tint options 5700 & 4700 as in the thread title or 5700 & 4000 as on the website linked in the first post?
Regarding the UI, is direct access to low from off available only if memory is disabled or if it is the memorized mode?
What battery would you recommend for the S2+? I don’t have any 18650.
Thanks.
Normally the lights come with pocket clip :wink:
About the UI, you can configure the modes you want according to the this diagram: http://i.imgur.com/jvx04IR.jpg
So, you can put it starting from moonlight, if memory is disabled! If memory is enabled (last mode memory), you can leave it in Moonlight before turning the light OFF and then it will start in Moonlight.
Taking into account the configuration of this flashlight (4*7135, and Nichia), I would recommend Panasonic NCR18650B (it is not a high drain battery, and has plenty capacity for longer runtimes).
Hope this helps!
Just to add: it’s much easier than it seems.
Driver 7135x4 or 7135x6 (I don’t know which is best for Nichia) and OP reflector if is posible.
Thanks.
Why triple when the original S2+ can already accomodate triples? The S2+ 21700 should be sized to accommodate a Carclo 24mm diameter quad optic. Quad will provide a little extra output and efficiency over triple.
Thanks for the info.
Too bad that one can’t have memory enabled and still have direct access to low without low being the last mode used.
Glad that it comes with a clip - none was mentioned at the website in the link in the first post.
I may end up getting one anyway in the not too distant future.
Any verification of the tint options?
The NCR18650GA/LG MJ1/Samsung 35E are at most about $1 expensive more than a NCR18650B (if not the same price) and surpass the later in both capacity and discharge rate. IMHO unless price is a prime concern (and you are buying many cells to offset the shipping costs) there is little reason to buy a NCR18650B nowadays.
Nice :wink: I don’t know or own the ones you mentioned, but I guess they must be taken into account then! I remember seeing the graphic for the Samsung 35E and indeed they are good! Thanks for “correcting” me on this :wink:
Please note that only the more luxurious versions (the ones with steel switches) come in in a nice gift box with a clip and luxurious lanyard.
The cheap rubber switch types come with a standard lanyard without clip in a flimsy cheap cardboard box
Okay, so the one linked in the first post doesn’t have a clip, since it’s got a rubber switch cover and the clip isn’t mentioned in the ad.
What clip would be recommended that Aliexpress offers?
Thanks
You’re right, no clip in the “normal” versions! Sorry, my mistake :person_facepalming:
High CRI emitter options, very nice to see Simon. Still, for driver I would prefer something regulated, PWM free. Stock configurations with LD-25 could be a nice idea, although I understand it increases cost a little bit. Or maybe not? It's a supply and demand thing, doesn't it?
Cheers ^:)
Of course it can installed in M2,too
I think reflector is better than TIR if you want the flashlight to be throwier one.
