MascaratumB:
LightObsession:
Hi,
Does a pocket clip come with the S2+?
Are the tint options 5700 & 4700 as in the thread title or 5700 & 4000 as on the website linked in the first post?
Regarding the UI, is direct access to low from off available only if memory is disabled or if it is the memorized mode?
What battery would you recommend for the S2+? I don’t have any 18650.
Thanks.
Normally the lights come with pocket clip
About the UI, you can configure the modes you want according to the this diagram: http://i.imgur.com/jvx04IR.jpg
So, you can put it starting from moonlight, if memory is disabled! If memory is enabled (last mode memory), you can leave it in Moonlight before turning the light OFF and then it will start in Moonlight.
Taking into account the configuration of this flashlight (4*7135, and Nichia), I would recommend Panasonic NCR18650B (it is not a high drain battery, and has plenty capacity for longer runtimes).
Hope this helps!
Thanks for the info.
Too bad that one can’t have memory enabled and still have direct access to low without low being the last mode used.
Glad that it comes with a clip - none was mentioned at the website in the link in the first post.
I may end up getting one anyway in the not too distant future.
Any verification of the tint options?
ggf31416
(ggf31416)
December 27, 2018, 8:20pm
64
MascaratumB:
The NCR18650GA/LG MJ1/Samsung 35E are at most about $1 expensive more than a NCR18650B (if not the same price) and surpass the later in both capacity and discharge rate. IMHO unless price is a prime concern (and you are buying many cells to offset the shipping costs) there is little reason to buy a NCR18650B nowadays.
Nice I don’t know or own the ones you mentioned, but I guess they must be taken into account then! I remember seeing the graphic for the Samsung 35E and indeed they are good! Thanks for “correcting” me on this
Yokiamy
(Yokiamy)
December 27, 2018, 9:23pm
66
Please note that only the more luxurious versions (the ones with steel switches) come in in a nice gift box with a clip and luxurious lanyard.
The cheap rubber switch types come with a standard lanyard without clip in a flimsy cheap cardboard box
Yokiamy:
Okay, so the one linked in the first post doesn’t have a clip, since it’s got a rubber switch cover and the clip isn’t mentioned in the ad.
What clip would be recommended that Aliexpress offers?
Thanks
MascaratumB
(MascaratumB)
December 27, 2018, 10:24pm
68
Yokiamy:
You’re right, no clip in the “normal” versions! Sorry, my mistake :person_facepalming:
Barkuti
(Barkuti)
December 27, 2018, 11:27pm
69
High CRI emitter options, very nice to see Simon. Still, for driver I would prefer something regulated, PWM free. Stock configurations with LD-25 could be a nice idea, although I understand it increases cost a little bit. Or maybe not? It's a supply and demand thing, doesn't it?
Cheers ^:)
Simon_Mao
(Simon Mao)
December 28, 2018, 1:16am
70
Since we’re using this as a Q&A thread…
Is it possible to put the Nichia emitter on other lights like the M2, Simon?
Of course it can installed in M2,too
Simon_Mao
(Simon Mao)
December 28, 2018, 1:21am
71
I think reflector is better than TIR if you want the flashlight to be throwier one.
Simon_Mao
(Simon Mao)
December 28, 2018, 1:26am
72
LightObsession:
Hi,
Thanks.
1.pocket clip is not included.
2.I dont understand the second question.sorry.
3.You can active the memory or disable the memory.If the memory is disabled,flashlight enters into the first mode when you turn it on.
4.S2+ only runs on 18650 lithium battery .What kind of battery do you use usually?
Simon_Mao
(Simon Mao)
December 28, 2018, 1:28am
73
Take your time ,pls tell me when you confirm the configuration, I will add link in my store,
BlueSwordM
(BlueSwordM)
December 28, 2018, 1:31am
74
@LightObsession , I would recommend the Samsung 35E for maximum capacity and still good power output with more powerful lights:
Simon_Mao
(Simon Mao)
December 28, 2018, 1:34am
75
carclo is expensive and not easy to be bought in China,i want to do a little change with S2+ 21700 to adapt following quad optic.
Simon_Mao
(Simon Mao)
December 28, 2018, 1:40am
76
Barkuti:
High CRI emitter options, very nice to see Simon. Still, for driver I would prefer something regulated, PWM free. Stock configurations with LD-25 could be a nice idea, although I understand it increases cost a little bit. Or maybe not? It’s a supply and demand thing, doesn’t it?
Cheers :partying_face:
Yes,I can install LD25. i can sell this version to buyers if they ask me to do this customization
Simon_Mao
(Simon Mao)
December 28, 2018, 2:07am
78
LightObsession:
Thanks.
Is there a clip that you would recommend for this light?
Your first post says the tint options are 5700 and 4700. The ad at Aliexpress gives the choice of 5700 and 4000. Which is correct?
I don’t have any 18650 batteries, so I would have to buy at least one, if I bought this light.
Thanks.
1.following two clips are all suitable
2. It’s my mistake, it should be 4000K , I will change the title,
SKV89
(SKV89)
December 28, 2018, 10:15pm
80
Since you are just designing the host to accommodate a quad optic instead of making a quad version of the S2+ 21700, you can just design it around a Carclo optic. https://www.mouser.com/datasheet/2/454/10622_iss1_140509-1276368.pdf
The optic you show don’t have legs. When you twist the threaded pill into the head, the optic might shear off the emitters. But I guess if you make the head accomodate 24mm dia., it will work with Carclo quad.
And this is really great news. Looking forward to this and hopefully a copper version in the future.
johnkey68
(johnkey68)
December 28, 2018, 8:45am
81
Simon_Mao
(Simon Mao)
December 28, 2018, 8:46am
82
SKV89:
Since you are just designing the host to accommodate a quad optic instead of making a quad version of the S2+ 21700, you can just design it around a Carclo optic. file:///C:/Users/dAbOMb/Downloads/2D%20Customer%20Drawing%20(PDF).pdf
uh,is it folder path of your PC?
i know this lens has no legs.I will try other method to cope with this situation.
