BlueSwordM
(BlueSwordM)
December 28, 2018, 1:31am
74
@LightObsession , I would recommend the Samsung 35E for maximum capacity and still good power output with more powerful lights:
Simon_Mao
(Simon Mao)
December 28, 2018, 1:34am
75
carclo is expensive and not easy to be bought in China,i want to do a little change with S2+ 21700 to adapt following quad optic.
Simon_Mao
(Simon Mao)
December 28, 2018, 1:40am
76
Barkuti:
High CRI emitter options, very nice to see Simon. Still, for driver I would prefer something regulated, PWM free. Stock configurations with LD-25 could be a nice idea, although I understand it increases cost a little bit. Or maybe not? It’s a supply and demand thing, doesn’t it?
Cheers :partying_face:
Yes,I can install LD25. i can sell this version to buyers if they ask me to do this customization
Simon_Mao
(Simon Mao)
December 28, 2018, 2:07am
78
LightObsession:
Thanks.
Is there a clip that you would recommend for this light?
Your first post says the tint options are 5700 and 4700. The ad at Aliexpress gives the choice of 5700 and 4000. Which is correct?
I don’t have any 18650 batteries, so I would have to buy at least one, if I bought this light.
Thanks.
1.following two clips are all suitable
2. It’s my mistake, it should be 4000K , I will change the title,
SKV89
(SKV89)
December 28, 2018, 10:15pm
80
Since you are just designing the host to accommodate a quad optic instead of making a quad version of the S2+ 21700, you can just design it around a Carclo optic. https://www.mouser.com/datasheet/2/454/10622_iss1_140509-1276368.pdf
The optic you show don’t have legs. When you twist the threaded pill into the head, the optic might shear off the emitters. But I guess if you make the head accomodate 24mm dia., it will work with Carclo quad.
And this is really great news. Looking forward to this and hopefully a copper version in the future.
johnkey68
(johnkey68)
December 28, 2018, 8:45am
81
Simon_Mao
(Simon Mao)
December 28, 2018, 8:46am
82
SKV89:
Since you are just designing the host to accommodate a quad optic instead of making a quad version of the S2+ 21700, you can just design it around a Carclo optic. file:///C:/Users/dAbOMb/Downloads/2D%20Customer%20Drawing%20(PDF).pdf
uh,is it folder path of your PC?
i know this lens has no legs.I will try other method to cope with this situation.
Geuzzz
(Geuzzz)
December 28, 2018, 8:52am
83
Great to see you here listening to the community Simon!
I was afraid you were getting behind on the newer flashlight developments, but I see you won’t let that happen.
Barkuti
(Barkuti)
December 28, 2018, 10:19am
85
Simon said “carclo is expensive and not easy to be bought in China”, dear Carclo lovers . This means it is unrealistical for him to design his flashlights around Carclo optics. Maybe you could ask him to choose some alternative optics manufacturer making Carclo compatible stuff.
Cheers ^:)
johnkey68
(johnkey68)
December 28, 2018, 10:50am
86
[/quote]
That’s an M2.
[/quote]
So confused. Too lazy to watch your collection
Jack_Kellar
(Jack Kellar)
December 28, 2018, 11:14am
87
This is an M1:
Anodized aluminium bezel, wider and more conical head, deeper fins, and the body is knurled.
I do want an M2 for myself tho Eventually, I’ll have it.
Jerommel
(Jerommel)
December 28, 2018, 2:26pm
88
Good idea!
The LD25 could use better mode spacing though…
Low is very low and medium is a little high…
AlexLED
(AlexLED)
December 28, 2018, 3:19pm
89
Geuzzz:
+1 !!!
Great to have you here, Simon !
The colored bodies are nice, but the high-CRI are even nicer !
And, most important, especially the high-CRI put you into the flashlight leaders ! I really hope the market will honor the better light quality over merely higher numbers for the lumens !
SKV89
(SKV89)
December 28, 2018, 10:16pm
91
Simon, here’s a Carclo quad optic cut sheet I found. You can also buy them from Intl-outdoor.com as they are shipped from China.
Jerommel
(Jerommel)
December 28, 2018, 11:50pm
92
O wow!
Thanks!
I thought it only worked on the older version.
Simon_Mao
(Simon Mao)
December 30, 2018, 1:25am
93
Geuzzz:
Yes, I am already behind, I want to catch up.
