ALL batteries will perform poorly in cold weather, regardless of whether they are lithium, Alkaline, Zinc or lead-acid. In fact, a lithium battery will still outperform a comparably-sized Alkaline or lead-acid when the temperature drops. As a result the battery will warm up internally and gain enough “juice” to run when loaded. I have had a 18650 light stored in the center console of my truck now for the last 4 years, and even during –30 Celsius winters it worked fine. Its not a big enough concern to have a heater-tube for the cells, as 80% + will use the lantern in summer, indoors, or at least stored indoors in warm temps.
Agree that also reduce the temperature of LED/head section.
One thing though:
NEVER CHARGE LITHIUM ION CELLS (18650s/21700s/14500s/18350s) below 0C.
Otherwise, they will degrade permanently.
I forgot to mention that charging cold LiIon cells is bad for them. (meaning any heat tube wont work if the lantern has been off & stored in a cold area with low batteries.
Yeah forgot too honestly about what Lexel implemented in the form of a temperature charging cutoff at 0C.
Storing (or using) LiIon cells in cold temps is fine, its just they don’t like to be charged when really cold. (I would warm them up to room temperature first before charging them.
I’m interested in one as well
Thanks!
Looks very sweet! Please add me to the interest list.
If this ever happens… I am interested!
Please add to interested list x1
I added to the charging circuit as described in the datasheet a NTC and 2 resistors to set low and high temperature
as the prototypes get build by Sofirn this needs to be tested as well
I’m interested in two
Thanks
I’m interested in one piece.
Thank you for your great job.
Please add me to the list for one.
im definitely interested, please add me to the list
Ok, time for another update to the interest list in the OP. The next 10 are:
1142 Vumnoo
1143 DunchBlaster
1144 tronx
1145 lotrbfme
1146 Freedom
1147 WeeG
1148 WeeG
1149 WolfiCZ
1150 nordlicht
1151 nick779
The master interest list can be viewed anytime:
interest list sorted by entry number
I hope Sofirn will also offer suitable high capacity batteries to be shipped with the lanterns as a bundle. This option will be very important for those of us who have great difficulties ordering batteries due to battery shipping restrictions. It is much easier to ship the batteries inside the light.
Please make this happen. Many thanks.
I’m in for two!
Please put me down for two.
@ tindrum42, back in post 1550 you requested 4 lights, so presently you have numbers 792-795 on the interest list.
Do you want 2 more, for a total of 6?
