Since this is all about cosmetics you will just have to spend the money for the look you want it sounds like.
For the prices you are looking at spending you might be able to find a pre-made unit with 10-15A of current. You can search ebay for used units for example although more then 10A is hard to find.
Using a bench power supply to power another bench power supply is not a very good idea as the ripple and voltage spikes of each unit could easily interfere and cause issues ranging from small to major. It is simply a recipe for problems unless you get quality units, in which case you are ruining a good power supply to DIY it.
For reference my entire setup costs around $50-$60 for 15A of current IIRC.
After a lot of looking, I found a pretty decent metal case for only $34 shipped from the USA. It’s a bit larger than I need, but no big deal. It will fit a 240 x 125 x 65 48V 10A psu no problem. Maybe I’ll give it nice coat of off-white paint.
Now to hunt up some nice front and rear connectors for power and leads, etc…
Do you think I can use these to test for over discharge protection in lights (reduce voltage and see when it shuts off)? I use one in the lab but should get one at home too.
Yes, it can be used for this, although the relatively high ripple voltage on the higher current models can cause some false readings for things like LVP. My older/lower powered DP3005 has lower ripple and works better for this kind of thing if I have issues with the DPS5015.
I bought the DPS5020 some time ago. Because the case i want to use is out of stock at the moment i am using a old Car battery charger case. For the input i first used a car battery. Now i use a 60v 480W PSU. I also ordered a few extra parts. But i am waiting for BG to get the case back in stock (https://eu.banggood.com/Wholesale-Warehouse-250x190x110mm-Blue-Metal-Electronic-Enclosures-DIY-Power-Junction-Box-wp-Eu-1067251.html?rmmds=category#).
With all the little extras i have planed there will be not much space left inside. But if i count evrything together i have spend ~120-130€.
But i have a Bench PSU with a lot of output if i need it. And if i check the available Bench PSU that i can buy for this amount of money i get maybe half the output with less options.
When everything is ready I can switch from the internal PSU to external input (when i am on the way and only have a battery for power). I added a second display for input Voltage /current and Power. I know that i can see the input voltage on the DPS5020 but i find it more convenient to see total power draw. . . on a second display. Also i can see input voltage on the second display before i use a switch to power on the DPS5020. So i can be sure not to have to much input voltage (the second display can measure DC voltage up to 100V). A few switches, terminals for the output and a bigger fan will also be added. And with the option to connect the PSU to my PC i have everything i need. But i really would like to see the logging funktion in the PC software.
Would be a really nice feature to have when testing LEDs. But i think this is somerhing many people have mentioned before.
Here is how I made case for my DPH5005. It’s just generic project case.
I use old PC power supply to power it.
There is 12V, 5V and 3.3V output in front with voltmeter and ammeter and also it’s possible to power DPH5005 form rear 5.5x2.5 or banana socket.
I just have to label it.
Sorry for bad pictures but I’m having some construction works right now and it’s chaos here…
I don’t think I have actually ever heard in run yet. Both fans are Temp controlled.
One is being controlled from the DPS5015, the other (case fan) is being controlled by the power supply. The fan was already in the power supply case.
I simply removed the power supply case leaving the bottom that the board is mounted to and mounted the power supply in the blue enclosure using stand offs.
This is the 1000 watt 60v 17a model, it’s almost as big as the enclosure. Page Not Found - Aliexpress.com
Took a piece of aluminum sheet that came off the power supply case and cut it to fit the DPS5015 board. Bent a 90 degree bend in the edge of the aluminum sheet for the DPS and screwed that to a big aluminum heat sink in the back of the power supply spanning the DPS over top of the power supply. Quite a bit of work but this size power supply in this case the room is limited and I tried to make the most of what I had.
I purchased a 1/8” aluminum sheet from ebay and cut to size and drilled my holes.
I didn’t really like the thin front panel it had and I ended up using the front panel to mount the fan on the left side where the air slot holes were. I drilled some new air holes for the fan and mounted it. I didn’t want to have to fight with the fan ever time I decide to take the case off so I cut the case top and made it removable without having to mess with the fan. Just loosen four screws and its off.
I got a few more upgrades to do once the parts get here. I want to be able to measure the actual voltage at the load instead of using a DMM.
Waiting on a DVM to install in the enclosure and a fused switch. Doesn’t look like a professional lab power supply but it works great.
I’m trying to think of a reason to get a 1000W psu, but I’m coming up empty.
A 480W (60v x 8A) seems adequate for me (testing LEDs like the xhp70.2 and automotive stuff). It should give the full 20A up to about 20v and still go up to 50v at lesser amps if I need it to.
What are you guys using the bigger wattage psu for?
I think they mean that if you try to apply voltage to the output it will short circuit which is not surprising.
I know I have charged many batteries with my DPS without an issue but the other DP version had to have a diode inline to do this. My guess is that they now how the diode built in but if you try to apply too much reverse power it will naturally blow the diode.
I mostly went with it because there wasn’t a huge price difference and if I ever needed it, it be there.
I also thought it might come in handy doing anodizing of aluminum and titanium if I ever wanted to try that again.
Buy to what you intend to use it for, I just didn’t want to some day need the extra power and have to buy a second PSU for that purpose.
