Freeme, I would like the code for banggood. Thanks.
i would like the code for ff site. i tried one already but that one didnt work.
same here. code for the FF site did not work. Ordered an bare aluminium Nichia 219b with blue aux emitters for the full price. I did not plan to buy another light today, lol.
Hi there, Freeme send me a code for BG.
thanks
Please send code for bg, thanks.
Can anyone comment on battery choice for the 219B option E07? Is it still best to stay with a 10 A battery like the Samsung 50E as was recommended for the 219B version of the PL47 or do the extra emitters actually need a higher max Amp battery to get the best turbo output without overdriving the 219B’s?
2.5A per emitter is about the absolute max you’d ever want to drive a 219B (and even that is really pushing it IMO). I chose to run NCR18650Bs in my PL47 because just because a cell is rated for a continuous drain doesn’t mean that’s the max current a FET will pull from it as I understand things.
Thanks BurningPlayd0h! Since the Samsung 50E have a Max Continuous Discharge Current Rating of 9.8A, but the Manufacturer Rated Max Discharge Current (not continuous) is 14.7A, I guess I am safe at turbo for short durations on my E07. I will avoid turbo on my PL47/Samsung 50E combo and continue to look for a safer 21700. Don’t want those 219Bs to start going purple on me! In the meantime, I am trying to find those four - NCR18650Bs I bought a while ago… :person_facepalming:
Reserved.
Fireflies has extended their code today.
I am in overseas right now. I will resume to ask all your requests from Jan 7(Mon) onwards.
Wish you all a Happy and Amazing New Year ahead!!!
What are the color aux on the Banggood site? I see no option for that.
Also can I get a code please?
Thanks
freeme - I’d like the E07 code please. Thanks!
I would like the code as well. Thanks
cod please, ty
Banggood code please!
Received my Nichia 219B today.
One of the legs on the optic is broken off because they used that hole for a screw:
I was planning to use a Samsung 50E, but it appears to be too long. After watching M4D M4X’s video I did not want to risk denting it by tightening the cap, so I used a Samsung 30Q instead. I will try the Samsung 40T with the XPL HI unit that should be arriving later this week.
LG M50 works fine and NCR21700A button top works fine too. I doubt the 50E is any longer.
50E fits just fine in E07. It’s the PL47 that is a real tight fit, but 1-2 mm copper washer in tailcap of PL47 allows 50E to work without having to tighten down hard.
The clear un anodized does look amazing and scratches probably will not show bad.
banggood code please
