Eizfan IMR18650 2500mAh (Black-purple) 2018
Official specifications:
Capacity: 2500mAh
Nominal voltage: 3.70V
Standard charge: 1250mA, 4.20V, 50mA cut-off
Fast charge: 4000mA, 4.20V, 100mA cut-off
Maximum charge voltage: 4.20V
Maximum charge current: 4000mA
Standard discharge: 500mA
End voltage (cut-off): 2.5V
Maximum continuous discharge current: 40A
Weight: Max 49.0g
Operating temperature: Charge: 0°C ~ 50°C, Discharge: –20°C ~ 75°C
Storage temperature: 1 month: -°C ~ 60°C, 3 months: –20°C ~ 45°C, 1 year: –20°C ~ 20°C
This is a high current 18650 battery with moderate capacity.
Nice graphic on the box, it shows the key specifications .
The discharge curves matches nicely and the battery handles up to 20A without much capacity loss
Conclusion
This looks like a good high current cells.
Notes and links
The batteries was supplied by Eizfan (Efan) for review.
Compare to 18650 and other batteries
