I did it all up on a PC but 90% of the time I use my tablet and that's a pita to do anything other than read on. I'm waiting on a Intl-outdoor drop-in for my L2T so I'll do a beam comparison then hopefully, they should be very similar but in a lovely compact P60 :)
Thanks BetweenRides, as you can see not much difference but i was interested how it would turn out.
I was just playing with my Fluke 123, connected directly to a XR-E to see if i could measure the flicker induced by the driver at lower modes (refered to by most on here as PWM)
Here are the results with the light details photoshopped onto the display:
As you can see the sample rate and scales were altered to best suit, i am not 100% about the readings and if anyone has advise please feel free to add. It seems to add up tho, the 980 has by far the worst PWM, closely followed by the 3T6, the XinTD is almost not visible. I tested my Crelant 7G5 but could not measure or see PWM(low is not very low tho), the same with the cheapo DX 5 Mode XM-L 501b!
also the nangj has great pwm..great driver..the 980l has the same driver as the uf 3 mode drop-in found at manafont..it's bad pwm, but a nangj can fix it also if it bothers you..luckily for me i'm not highly succeptible to pwm and wouldn't even know to look for it if it wasn't for this site lol..damn you all! ;)
Good job and this looks like a great flashlight, especially for the money.
I keep my eye out for XinTD reviews to see if the quality I experienced is consistent across models. For example; an UltraFire MCU-C88 or the UF- 980L are both top quality pieces but the UltraFire WF-502B is not. (at least the few I've seen)
This XinTD C8 looks exactly like a Palight and any number of other C8s. Which is not necessarily a bad thing but other XinTD designs appear to be more exclusive to the brand. (if it is a brand)
I noticed that the XinTD C8 looked more like a generic C8 with the exterior build quality as opposed to the XinTD that you reviewed, which looks top notch quality. I have all the UFs you mention and that is exactly my experience aswell, it seems the 502 gives the other UFs a bad taint, they really are rather good quality.
Perhaps my five stars are generous given the blemishes but for the money I think it truly is the best you can buy.
I am still a new (budget) flashaholic and jumped straight in for the powerhouses with a triple XM-L and then super throwers such as my Crelant 7G5 and SF MPP1, Im glad I own these but they have allowed me to appreciate just how well rounded this light is, if I was to own one light now, at present this would be it! The king may not reign long for me tho, if the Intl-outdoor dropin combines with my SF L2T to create what I hope it will.
I believe they were talking about the XinTD because it is the only one I know that has the screw in reflector. I tried it myself before and did not notice much difference either.
OK following some questions about the PMW results i achieved here are some more (on low). As you can see the results match others now but also it has shown me how easy it is to get differing results. The PWM is complicated and contains different frequencies/amplitudes thus differing sample rates give different results, perhaps a cheaper meter is easier as shown by the 179 results?
Note the zoomed in waveform on the 123 on the last pic, it is mainly out of shot and i forgot to get a pic of it but at that sample rate the Hz was recorded as different dispite being exactly the same, bar the sample rate. I think it measures the frequency of the content of the 'chunks' (want of a better word lol) in the top pic.
My XIN TD C8 appears to be perfect in fit and finish; no flaws noted. Still the best $32 I have spent on a flashlight. If it would only run on 2 x Cr123 as well as 1 X 18650, it might be the best light on the market up to $50.
Can't say about Xin TD. but my C8 and UF-2100 with Nanjg 105C AMC7135*8, 2.8A installed run on 2xCR123a 3.0V very good, even Uf-2100 runs on Hi (but very! hot). Effeciency of the driver is only about 65-70% (30% is converted to heat of the driver :( ) with high voltage, but AMC7135 is rated to work up to 7V peak. None died yet.
How how many hours have you run 2xCR123A in the C8 and the UF-2100? And could you estimate how much time the flashlights were on at a time on High mode.
Your efficiency estimations look very good compared to other which have tested 56-70%.
Efficiency is not my own measurements. Once I saw an AMC7135 specs table or something like that and just remembered that it is most efficient at 3.9V - 90% and worst at 6V - about 65%.
