What did you mod today?
9507 posts / 0 new
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 4 weeks ago
It’s not, it’s one of my own designs. It may be a direct fit though, what’s the diameter of the gt mini driver?
Tom E
Tom E's picture
Last seen: 3 hours 52 min ago
Nice CK! I did mod a bunch of these lights, and have still maybe 1/2 dozen more to mod. I searched and searched, found active sources for a while - GearBest then even Amazon. Best price was maybe $9, but typically $11-$12. I added an AUX/switch LED but using a light pipe next to the switch.
Is this your OSHPark link for this driver? https://oshpark.com/shared_projects/8SacSyZ1
The light is a ZY-T11 clone. This is what I did on an earlier one:
This is the driver with the AUX LED:
This is what it looks like assembled:
The exact light pipe I used:
I prefer having the light by the switch.
Let me know if that's the right link - would love to use these drivers, makes the mod much easier. Does it use the stock switch or do you replace it?
Btw, with these switches I always add epoxy support on the backside because I've seen a few of these switch types broken, or even just bent back. The bent back ones sometimes don't fail, just makes it harder to click.
Ohh, also, why are you using R1/R2? I think Anduril has support for them but it takes to parasitic drain. We eliminated using them a while back, but maybe you find them more reliable?
komeko
komeko's picture
Last seen: 1 week 3 days ago
I suggested subtitles for the driver. I am looking for a driver for the substitution in Lumintop sdmini. As for size, I have to measure.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 3 hours 12 min ago
GT mini driver has about 22.2mm (±0.1)
Geuzzz
Geuzzz's picture
Last seen: 33 min 26 sec ago
djozz wrote:
Djozz’s First Build.
..of 2019
I swapped the leds in my modded F3X. It had a tint mix of XM-L2 leds that put out 2700 lumen and worked very well but I have other lights in that lumen class now that have better tint than this 73 CRI light. So now it houses 3× 400nm 5050 Epileds leds that together draw 8.6 A. This is serious output that together with yellow glasses shows a lot of dirt in my kitchen (did you know that boiled peas are bright red?).
Actually I like the size and form of the F3X a bit too much for making it into such a niche-light, if new high CRI 5050 leds may hit the market some day (SST-40? Innocent ) it is time for another led-swap.
!{width:80%}https://farm5.staticflickr.com/4913/45837537824_875c8e2a37_b.jpg!
Verry nice Djozz! And I also have some lights ready for some new hcri 5050s let’s hope it happens some day.
DB Custom
DB Custom's picture
Last seen: 1 month 1 day ago
Green leaves on a plant also fluoresce red under the UV, FWIW… or at least my Red Savina Habanero plant does so.
Cereal_killer
@Tom_E yep that’s the one. I love your light pipe solution, much more elegant then me shoehorning top hats in there lol. I just used 5mm led’s mainly to fill the holes from the charger port / charger port rubber cover, had those holes not been there I likely would have forgone an aux LED all together but your version is awesome (and probably way more efficient with the SMD LED)!
I really like the light since switch orientation is so easy to figure out blind cause of the body shape, no fumbling it around in hand trying to find it by feel and no actual need for the aux led’s (but they’re still cool as hell), it just falls into your hand orientated right cause of the scalloped part of the head.
About the voltage divider, when I designed these a few months ago I hadn’t yet really looked into the FW to understand it could measure voltage directly so I just made the driver an exact clone of the gt_mini (hints why the resistors don’t follow the typical TA / DEL naming convention, i.e. the vdivode is actually R4/R5 on these, not R1/R2). Measured standby current when running both the 5mm white led’s on high is only 3uA so while im not to concerned about it IRL I’ll definitely look into that for future builds. Is it a FW change or do I just physically remove the voltage divider and FW automatically knows to read voltage from pin 8 internally when it doesn’t see anything on pin 7? It probably helps the resistors are 910k/300k so it’s much lower draw than the typical 19k/4.7k pair would cause.
Oh one final note: the MCU pad is that of a tiny13 so you need to do the leg bending trick but you can still fash it with an SOIC8 clip afterwards, I didn’t have an 85 part and was lazy when I did the layout, if you’re not a fan of that trick LMK and I’ll swap it for an 85 pad (I have one now) and re-upload it to oshpark before you order (there’s plenty of room on this board for the 85 pad).
The switch is one I sourced but I bet the stock one fits, looks just like it. If you try it and the stock switch doesn’t fit LMK, I ordered 40 of ‘em so I can stick a couple in a envelope for ya if need be.
Btw thanks for knowing what to call it (zy-t11 clone), now I just gotta source one more for me to build myself!
Tom E
Tom E's picture
Thanx CK! Actually I got a couple different types of these switches, so let me try mine first, or re-use the stock one - I need to figure it out, but first I need to order a bunch of these boards!
I agree - this is a nice little light for cheap. For me though, the Lumintop SD Mini is "the" light in this form factor - moddable, smaller, light weight, great reflector, excellent finish, quality threads, quality lens, switch w/LEDs, deep pocket clip, decent price, etc. Of course they dropped it now (sure, get rid of a good thing??), but might still be available though probably pricey.
The modded SD Mini is still in my top 3 of preferred EDC's.
This is an old GB listing (not available): https://us.gearbest.com/led-flashlights/pp_71296.html?wid=1433363
This light was sold under various names and lettering, all ZY-T11 clones though, made better than the original w/alum reflector: https://us.gearbest.com/led-flashlights/pp_71296.html?wid=1433363
On Amazon and I think BG they were sold under the MECO brand. Amazon price was $9.75 in June 2015.
nick779
nick779's picture
Today I finished up this old ultrafire revamp.
Sliced SST-20, FET+1 driver running anduril and a super cool AUX led setup.
33,200kcd & 1030 lumens, I was sad it didn’t quite hit my goal of 40kcd.
Oh I dig it. Thats awesome.
That UV mod is pretty nice too. I broke down and ordered one of the cheapie 50+ UV LED versions to track some rodents that found their way into out house…. Couldnt wait for an S2+ shipped from China.
contactcr
Last seen: 4 hours 33 min ago
Last MZ for a while..
25 degree TIR
kiriba-ru copper single
H17Fx driver
I think this TIR is probably the most narrow that could be used with the MZ without a donut. I’m sure anything wider or more diffused would be even better but I’d rather use a LH351D/219C/XP-L for anything wider so I opted not to.
My first time using kiriba-ru’s copper single and it’s great as always. Machining is nice, threads fit perfect. Thin ring is buttery smooth
Also first time using H17Fx. I will probably use this again when i’m too impatient to wait for Lexel Smile
kikkoman
kikkoman's picture
A quick 30 minute job:
The old Astrolux E01 got a Luxeon V2 “upgrade”. It had a 90CRI LH351D before, which had good output but was a bit too floody for my taste even with a shaved emitter. Current is set at 3.05A on turbo, 1.05A regular max IIRC.
I tried something new: I shaved the Luxeon very close to the phosphor, ground the slice marks with 1000grit paper and sealed everything with a blob of LOCA, which formed a very shallow dome (maybe 0.8 mm high). Nice and shiny. (Forgot to take a picture from the side.)
This does not significantly increase the apparent die size (and may or may not help with lumen loss) Grad
Looks better in actual life than in this picture.
Scallywag
Scallywag's picture
Last seen: 2 hours 3 min ago
Not today, but recently: I finally replaced the Nichias in my D4 with a quad-Luxeon V board from Led4Power. The tint is fantastic (and none of the green my Nichias had), but I may have underestimated the low vF of the Luxeon Vs. The light is fantastically bright, but typically steps down after about seven seconds on max, with a fresh battery. I may also have to re-calibrate the thermal throttling because it gets to the point of being nearly painful to hold, even outdoors in winter...
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
contactcr
Scallywag wrote:
Not today, but recently: I finally replaced the Nichias in my D4 with a quad-Luxeon V board from Led4Power. The tint is fantastic (and none of the green my Nichias had), but I may have underestimated the low vF of the Luxeon Vs. The light is fantastically bright, but typically steps down after about seven seconds on max, with a fresh battery. I may also have to re-calibrate the thermal throttling because it gets to the point of being nearly painful to hold, even outdoors in winter…
Not sure if you are interested in flashing new Anduril firmware but ToyKeeper has some builds for the D4 that step down more aggressively here
djozz
djozz's picture
Last seen: 8 hours 44 min ago
@Scallywag, I did that (but reflowed the V’s on the stock board) and those 7 seconds are over 5000 lumen. You must love that! Big Smile
staticx57
Last seen: 1 day 6 hours ago
Got my HQ flashing key working
vwpieces
vwpieces's picture
Last seen: 1 hour 40 min ago
Cool staticx57, no more disassembly for flashing.
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 3 days ago
You can’t imagine what I started today Big Smile Actually started two mods at the same time. They will be long projects. One involves 3D printing and the other will have lots of lumens. Maybe not Acebeam X70 lot or not even Imalent MS12 but very close Smile I will make a full build thread of both when finished. And video.
zeroflow
Tried to mod a Convoy M1 with a Luxeon MZ – modded a Luxeon MZ from white to blue instead…
For everyone else here who also did a simmilar build – how did you manage soldering?
The DTP board is pretty hard to solder and the reflector of the M1 does not leave a lot of space for a sloppy soldering job…
CRX
CRX's picture
Last seen: 1 day 20 hours ago
I had a spare Panasonic NCR18500B and a cutting of titanium tube left over so made an optional extension piece for the CRX CuTi Zoomie Osram KW CSLNM1.TG.
Redlyne22
Redlyne22's picture
Last seen: 3 weeks 6 days ago
I have to ask, what kind of cell phone did u use to snap this pic?
BTW………
Impressive build and impressive #s
pilotdog68 wrote:
Just got done stacking a bleeder resistor for my B158 build. Not too bad for a cell-phone camera, eh?
Sometimes being a newb is the best part of a hobbie
Tom E
Tom E's picture
 I dunno where you found that post but PD68 hasn't been on in 3 months.
Ohhh - just found it, 3 years ago, post #19.
HONDARIDER
HONDARIDER's picture
I reflowed an 3500K XHP50.2 in one of my Sofirn SP33’s. I think the original tint is in the 5700 to 6000k range. Probably should have used a 4000k but this one was pretty nice.
pc_light
pc_light's picture
Last seen: 7 hours 3 min ago
Managed to open my Olight S1 Mini Baton (yeah the new ones with recessed blue ring Sad ) without toooo much pain and swapped the cool XM-L2 for a hi-CRI LH351D 5000K.
Here’re the inside works, with replacement board.
The original MCPCB (far right in photo) was smaller (~14mm) and thinner (~0.5mm), so I re-sized a 16mm x 1.5mm copper DTP (far left in photo), to fit (final in center in photo) Sad
In my excitment to finish before dinner I closed it up before taking a pic Facepalm and I didn’t want to open it again.
But FWIW, here’s the beamshot of XM-L2 Before (on photo left) and LH351D After (on photo right) The ever so slight green is gone and in it’s place is a whole lotta hi-CRI goodness.
Smile
Seeking the light.
EasyB
Nice job shaping the MCPCB to fit. I find that sort of filing and sanding work to be the most satisfying. Thumbs Up
pc_light
pc_light's picture
Yeah, it’s the kind of mindless task that you can do while watching TV or just want to zone out with some soft music.
Seeking the light.
contactcr
The BLF X5 was before my time but I did get one to make up for lost time. It stayed stock for about 2 days.
Old:
X5 w/ stock XP-L HI
26.5Kcd
New:
X5 w/ White Flat
BeCu driver spring
bypassed tail
69.5Kcd
Tail measured just barely above 5 amps w/ a Vapcell 14500. I didnt do any focusing and didn’t bother changing the stock centering ring since the MCPCB and reflector both screw in and the width of the gasket seemed close enough for now. Beam actually has a good tight spot as is.
staticx57
More adventures with the HarleyQuinn flashing key. The partially assembled driver is now running Anduril. Specifically the tint mixing (Lantern) branch Evil
jon_slider
jon_slider's picture
Last seen: 2 hours 53 min ago
Smile
wow!
I will take it Smile
djozz
djozz's picture
Old:
X5 w/ stock XP-L HI
26.5Kcd
New:
X5 w/ White Flat
BeCu driver spring
bypassed tail
69.5Kcd
That is a satisfying mod Thumbs Up , it takes the X5 to a new level that was not achievable at the time.
contactcr
Today’s mod was one of the more tricky ones for me but turned out well.
Got a Sunwayman V11R during the random eBay deal a few months ago that like 30+ of us jumped on Smile
Thanks toddcshoe for that deal thread and moderator007 for documenting his previous mods on this one..
Broke this free with the underside of my huge gaming mousepad, I think it was red loctite. Now I have a cramp in my finger. Only managed one small scuff on the ano that you can see in the bottom right piece.
Original ~14mm MCPCB and XM-L U2, bye Felicia
Seeing how much I have to take off my 16mm XP board, aside from filing a few 20mm triple boards for the E2L I have never done this before.
The only grinder I have, it’s made for sharpening knives. 120 coarse belt never gets used on knives anyways, lets try..
Ugly, but it gets the job done. LH351D 4000K 90CRI, GET TO THE COPPAH
Hey, it works. Glad I saved this one. It was from a failed re-flow attempt on a Q8 where I killed 2/4 LEDs with turbo. These were first group buy 4K which I really like the tint of, glad she lives to see another day.
The super low moon this light is sometimes known for looks neat.
Beam is good
I left out the metal washer/spacer thing so I could tighten the head and get the slop out of the variable ring. Thanks moderator007. It’s possible to over tighten it now but it wont be an issue, easy to adjust.
Random XP centering ring from Kaidomain was a perfect fit.
I ended up thinning the MCPCB too but I wish now that I hadn’t. I’m sure it’s not flat/level on the bottom but hopefully it’s close enough to make a good heat path. At least we are using copper now..
