you need a larger area to test in!
uh ,it’s hard to find an open land without lights here.
Most of the Chinese live in high-rise buildings, and the villas with large lawns are extravagant to us. :cry:
You could light from one of those high buildings and light to another, as long as you use fixed camera exposure settings I see no problems in doing so with the light not white out at too high exposure
Adding the distance from google maps for example
Simon Mao: saypat:you need a larger area to test in!
Most of the Chinese live in high-rise buildings, and the villas with large lawns are extravagant to us. :cry:You could light from one of those high buildings and light to another, as long as you use fixed camera exposure settings I see no problems in doing so with the light not white out at too high exposure
yes ,i understand.
and i saw many posts on forum doing review as you said.
But there is no such place in the environment around me.
It’s better that if some BLFer can help me :laughing: My video is just a preliminary demonstration
Are these available to order? I may purchase one and give it a go.
Neil
Simon do you have any plane to make L2 with XHP35 ?
Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
Thanks for video. I have been thinking of building this light myself. Any information on your build?
Simon is the owner of convoy. This light will be for sale soon.
Unlikely, as the XHP35 is only available in a 12V configuration, which would require the use of a boost driver. The XHP50 and XHP70 are also available in 6V configurations, which is what Simon is using here. Powering a 6V emitter with two cells in series is relatively straightforward. Developing a 12V boost driver would be considerably more difficult.
yes, i will get the XHP35 driver sample for L2 several days later
but the max output current is 1000mA,
is it too low?
i supply driver ,too
i know some BLFers already have L2 flashlight,they may DIY it themselves
i dont have 26mm DTP copper board
it seems that 25mm is regular size ,i can get some from manufacturer
Satan@103TFS:Simon do you have any plane to make L2 with XHP35 ?
i will supply XHP35 driver for L2 flashlight soon
You can give 2000mA to the XHP35 and it will good. Maybe measure heat and add a timed 5 minute stepdown on turbo.
pennzy:Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
Thanks, 25 mm would be good. I will message you on your AliExpress store.
Edit : I don’t see 5000k at your site. Not available?
Simon Mao: pennzy:Simon , do you sell the XHP 50.2 NW on a 26 mm board in your store?
it seems that 25mm is regular size ,i can get some from manufacturerThanks, 25 mm would be good. I will message you on your AliExpress store.
no 5000K in stock presently ,i will order some if you need it ,my email is 468924022@qq.com
is it too low?
Good news but 1000mA is quite low I would like to get 2000mA .
i will get some 25mm xhp50 DTP board samples tomorrow
Simon, is there any chance to get the Convoy L6 tail cap / tail part as spare part?
It would be great to use it for high current purposes on other flashlights.
I plan to make a considerable purchase order on your webshop and this would be the icing of the cake. :LOVE:
Thank you.
I plan to make a considerable purchase order on your web shop and this would be the icing of the cake. :heart_eyes:
Thank you.
Are you just talking about the inside switch
