“REVIEW”: RovyVon E300S – 2000 lumens – (Rect)Angle Light – 3*XPG3 [PIC HEAVY] - ***MODED WITH XP-L LED ***
Yup, very off, and I didn’t see it :person_facepalming:
I didn’t test it myself, but zeroair did and it is consistent ti the specs (RovyVon E300S Angel Eyes Flashlight Review - ZeroAir Reviews).
Turbo steps down to 350 lumens and High to 250 lumens!!
Unfortunately I have no accurate ways to measure lumens, only time for step down :zipper_mouth_face:
Edit: I misread your question!! On the 500 lumens level I don’t know! I may try to test that tomorrow :wink:
Thank you
So, today I tried a little test with my luxmeter, with the E300s on Medium Mode (500 lumens).
These are only numbers to “measure” the eventual decrease of output, please don’t take them as scientific measurements.
Some seconds after starting: 375 lux
After 7 Minutes: 353 lux
So, there is no major stepdown on Medium mode.
Also, the surface and the optic/LEDs area was about 32ºC !
I hope this helps answering the question that I misread yesterday :person_facepalming:
Thanks :+1:
Thank you. That is really good, I may have to get one of these.
Thanks CRX! :beer:
I guess this reminds your SL build(s) a lot! With all the differences it has of course :face_with_monocle:
Yeah, or the mini monolith I made a while ago :slight_smile:
Hum, I guess I missed that one :open_mouth:
Nice light! How “mini” is it? :wink:
60mm x 25mm x 12mm :wink:
Sweet! :wink: I had to measure this E300s to get a notion of how small it is!! :person_facepalming:
BTW, look where I ended up just by searching “mini monolith” :
The BLF Modding Links Thread. Looking for a mod that’s been done at BLF? Try here for a link. , by Old-Lumens
:star:
:+1:
Just notice the E300s fits the On The Road pouch :smiley:
I believe it also fits Convoy holsters (the ones for the 18350 versions), but can’t confirm at the moment!
Anyway, it is a good and not very bulky way to protect if from scratches or other hits :smiley:
EDIT (later this day :wink: ) :
Convoy holsters work perfectly with this light :wink: And still have more room to a second light, in the side!! :smiley:
As I mentioned on my review, this Rovyvon E300s flashlight was a good candidate for an LED change, due to the tint shift on this light produced by the XP-G3 Leds.
Last friday I received some XP-L Leds ordered from kiriba-ru, and performed that modification.
NOTE: this is not a easy mod, specially for people that have not so good skills - as myself :exclamation: - on soldering and opening/closing flashlights. The E300s is somehow complex to open and close without major damages and for some seconds I thought I would lose the most expensive light I have. So, careful if you decide to got for a mod!
There is a rubber “cover” all around the top of the flashlight, to protect from water infiltration. It was hard to get this out and almost worse to get it back to place again!
To access the “pill” and leds, unscrew the top screws on the outside, remove the cover, and unscrew the 3 screws holding the “board”.
To remove the “pill, we have to unscrew the bezel from teh outside. Due to the o-rings and the friction caused by them and the optics, it is very likely that the optics and leds will turn inside. It led my black wire to de-solder so I have to put new wires (22AWG). Thick wires will difficult our life when putting things back together to assemble the light again.
I also broke the black wire coming from the battery while trying to put it together, but it was an easy fix!
The only thing I couldn’t put back together was a sealing ring that was placed between the “pill” and the host (below the bezel). So I improvised and put between the bezel and the host, from the outside. It will work :slight_smile:
About the optic, as you know the XP-L HD leds are taller than XP-G3 and XP-G2, so I had to modify the optic according to this suggestion . It was not difficult but it was hard to make it fit evenly (it can be noticed in the photo). Still, it doesn’t produce artifacts on the beam! :+1:
Las but not least, the beam. Before (XP-G3 CW ) >>>>> After (XP-L V6 3D). During the weekend I will try to take some outdoor beamshots to see the range it will throw!
I can’t portray how “white” it is now, due to the effects produced by the cellphone and the storage loss of quality! Still, it doesn’t have any shift and despite the issues I had modding the optics, it has no artifacts! It is a wider beam now, much floodier than it was, but the XP-L Leds would produce that any way, more than the XP-G3!
I am happy now with this new light colour :wink:
Well done. Would have been even better if you had documented the modding process :-)
Thanks mate :wink:
Well, you mean documenting as in filming or taking photos?
Believe me, I was much more worried about not ruining the flashlight than filming it! :smiley:
You can take a read at zeroair review (RovyVon E300S Angel Eyes Flashlight Review – ZeroAir Reviews) it helped me to get into the light :wink:
Still the process was like:
1 - taking the screws out on the head)
2 - take the back cover (complicated but it didn’t damage much the sealing rubber that covers that part)
3 - trying to unscrew the bezel out, while holding the brass pill, without damaging the wires (it didn’t happen, as one got cut…)
4 - after the bezel was unscrewed:
a) take the pill out
b) unsolder the remaining wire from the emitter plate
c) unsolder both wires from the “driver”
d) replace the original LEDs for the new ones (with “helping hands”, solder iron, some soldering flux and a swab with alcohol to clean the mess :stuck_out_tongue: )
5 - after the new LEDs were in place:
a) solder the wires emitter plate (I rather not call it MCPCB as it is not…)
b) get the new - thicker - wires through the small pill holes, without damaging them
c) put some thermal paste between the plate and the pill
d) cut some Glow-In-The-Dark tape to put inside the pill
e) set the plate in place and…put the optics above the LEDS
6 - After I realized the optic has small diameter holes…I had to pick the dremmel with a round file head and slightly open the optics holes to make the LEDs fit more or less fine. Was not very difficult, but took some time to make them look “similar” (I only noticed that when I switched the light ON)
7 - With the optics and the emitters in place:
a) solder the wires to the “driver”
b) try to screw the bezel in without twisting and breaking the wires (as the pill rotates at the same time! This was one of the hardest parts, as the whole driver+pill had to be lifted up several times due to the friction in the rotation process! This was when a wire from the battery broke/unsoldered…)
c) put the back cover in place again, without severing the sealing rubber
d) put the head screws back in place!
Ahh, and during the process, I was always checking if when pressed the light would get ON :stuck_out_tongue: I didn’t want to go through the dismantling process again :stuck_out_tongue:
Sorry for not having documented it…it took me HOURS from begining to the end, with some drawbacks and much learning :wink:
Hope this written explanation may work as a documentary, somehow :+1:
Thanks for reading :beer:
After modding this light with the XP-L leds I didn’t put some photos to show how it performed. So here are some photos of it!
It became more floody, but the colour is much more pleasant even outside!
Comparison:
BEFORE (XP-G3) >>>>>> AFTER (XP-L HD)
And some more photos :wink:
Overall I’m happy with it as it is :slight_smile:
Very nice work, MascaratumB! :+1:
After some recent lights purchases, I don’t need another EDC… but the E300S has been tugging at me. I like this form factor, especially the concept of being able to clip this to a shirt pocket and have forward facing light. I’m encouraged now that it comes with a Nichia 219C option. I like this emitter on the A8.
After the XM-L emitter swap, your beam tint became noticeably warmer. I think it’s worth the trade-off on reduced output, given the form factor of the light. Btw, I’m guessing you don’t see PWM, as I’d asked someone else about that—they could detect it on the A8 but not on the E300S.
Ya, nice work. Even though I’m a CW fan and going by your photos, your mod made for a nicer beam.
Thanks xevious :wink:
This is a very nice light! I guess that the unusual shape of it has a different appeal :wink:
The UI is also quite good (for my taste and despite some things I would change) and it is very well built!
I also think the beam improved (specially the tint and the absence of shift) despite it lost some throw capability! I don’t mind that :wink:
BTW, it was XP-L , not XML :slight_smile: Those would not fit at all under that optic :smiley:
Nop, no PWM. Here’s a gif from post #1 juts above the LEDs:
So it doesn’t do what the A8s do ! Fortunately :smiley:
Thanks Gebe! Hum, I guess that if it was a different type of CW emitter, like XPL-HI or some XP-G2, I wouldn’t change it. But XP-G3 produces that yellowish/greenish shift that annoys! So I guess this is a better one too :partying_face:
Sorry for my very late reply, MascaratumB . Somehow I didn’t catch the reply in my subscription list. I appreciate your response. I had ended up getting an Aurora A8, which I enjoy. However, the noticeable PWM at low levels has tended to annoy me. The effect isn’t the worst I’ve seen, but none of the other lights I own exhibit this effect… which makes it stand out more. I’m glad to hear the E300S doesn’t have visible PWM.
I’m wondering about the optic. Is it a 20mm size? There are a number of variations in optics available today and it’s interesting to consider an optic swap. The difficulty you faced in disassembly is a bit unsettling, though. Especially where that top seal is concerned. It does sound like it’s necessary to do it, though, to keep the pill from moving when rotating the outer bezel for access to the optic.
