Nice folks, very nice! Making the wait for my clear ano with blue/purple and SST-20 95 CRI that much harder to deal with …
Hope they do my aux lights like yours contactcr, really looks good! I think I asked for purple on the outside and the inner ring ice blue, can’t remember exactly, but yours really does “shine!”
Edit: Looked up my order and see that I ordered 5000K SST-20’s, also while I did ask for blue and purple aux I didn’t specify the arrangement, so I guess I have a mystery package coming.
Made of 6063 aluminum alloy and 304 stainless steel
Body color: Matt Black , Gun Grey and Desert Yellow
HAIII Anodising Surface Finish
1x 21700 / 18650
25 degree angle TRI lens 98% AR coating glass lens
Digital current regulation on lower brightness
IPX6 waterproof
with Aux leds ; with switch leds
Size: 112mm(L )x 37.5mm(Head) x 26mm(Body)
Net Weight: 125 gram
It was cold outside, so I really didn’t hang out very long to find out. I would guess I was outside for at least 3 or 4 minutes, but it was 25ºF outside. No stepdown and the light warm but not hot
I'm still surprised it could even hold it that long considering it's size even with the cooler weather. I was expecting you to say something like 20 - 30 seconds.
Anything over 30 seconds is a winner to me in that size category. Not sure if it will make a huge difference but I did order mine with a 40T instead of the 30T.
joechina, the actions part of the manual is critical, needs to be front and forward so it’s the first thing you refer to before digging into the UI… without knowing the actions the UI is confusing, understand how to get there and everything is easy.
I know Dale. It’s the not pretty version.
Others have the line description on the bottom or lower right. I think with so much different lines I guess a user searches for the explanation.
I made three versions, this is the 90% where I pushed things around and with the most free space.
The other two are a 90% and a 95% version where I moved nothing.
We both don’t know how much space the misses needs.
I lost track at the moment of the changes in Andúril, but the not pushed ones should be good for 7th click and a bit of text.
(It reminds me a bit at Narsil: Boy the cheat sheet is so packed, no way to add more stuff. And the next week Tom E had new features. Ok, I must push stuff around)
Also the lines for Hold, 3 fast clicks and other actions need probably a bigger spacing.
On A4 paper size its ok, but manufacturers print normally in a much smaller size.
I haven’t made print out in A5
A option for the “3 fast clicks”-line could be
