Maybe it was more like 2 or 3 minutes. It wasn’t long though. I only had a tee shirt and jeans on
It’s easy to miss the step down without a meter. It probably did begin to ramp down before that
Anything over 30 seconds is a winner to me in that size category. Not sure if it will make a huge difference but I did order mine with a 40T instead of the 30T.
Thanks robert. Nice beamshot. I am waiting for my e07 xpl 6500k…
I ordered both 5000k and 6500k. Will be interesting which one I like more.
Here is a nice comparison of the D4S between SST-20 6.500K and XP-L 6.500K.
While the SST-20 tends to have a green tint shift at lower currents the XP-L HI has no tint shift on all current levels.
That SST-20 looks a yucky green!!
Waiting for my E07 with XPL HI 4,000K.
Reading this thread is making me drool!
That green is enough to keep me away from the SST-20, not very appealing at all.
joechina, the actions part of the manual is critical, needs to be front and forward so it’s the first thing you refer to before digging into the UI… without knowing the actions the UI is confusing, understand how to get there and everything is easy.
I know Dale. It’s the not pretty version.
Others have the line description on the bottom or lower right. I think with so much different lines I guess a user searches for the explanation.
I made three versions, this is the 90% where I pushed things around and with the most free space.
The other two are a 90% and a 95% version where I moved nothing.
We both don’t know how much space the misses needs.
I lost track at the moment of the changes in Andúril, but the not pushed ones should be good for 7th click and a bit of text.
(It reminds me a bit at Narsil: Boy the cheat sheet is so packed, no way to add more stuff. And the next week Tom E had new features. Ok, I must push stuff around)
Also the lines for Hold, 3 fast clicks and other actions need probably a bigger spacing.
On A4 paper size its ok, but manufacturers print normally in a much smaller size.
I haven’t made print out in A5
A option for the “3 fast clicks”-line could be
few more beamshots while the neighbours are sleeping hahah
just a quick photo snaps so dont expect too much
Thanks for the pictures! If you order the blue aux leds, do the button leds always remain purple?
Man do I want the clear ano E07!
Ah, but joe, I HAVE been speaking with her… the chart needs space in certain area’s for the addition of new functions… not necessarily a new block but more info in some of the old blocks. And only some lights that use Anduril would require this information, so it’s a toss up as to whether or not to add it in. Mostly it’s the aux led’s of a couple of manufacturer’s lights, not really applying to the normal version we flash.
Gonna have to be a couple of versions of the manual I think, one expanded for the auxiliary lights and the other not.
TK has her own methodology, someone else writing the manual the language seems off… probably best to let her do it so the speak reads true to form for the Author.
Just got mine, nichia, blue/purp, gray. (Fyi: My order was placed on nov 28)
This is a really pretty light. Next to my zebra light 60whatever 3 plus thingy my current, er, which is to say former edc, it looks like jewelry. MAN-jewelry.
I was a bit leary this past month about whether or not it would pocket edc well…but it is really smaller than expected, i think it will be fine in my pocket.
Pretty psyched.
I will post a pic in a bit with some former edc’s for size comparison for those interested.
What a pretty light. It’s just so handsome. Seriously. Nicest looking torch in my collection, easily. I dont collect—i use—so most of my lights are pretty utilitarian. So, those with fancy copper, heat treated titanium art projects may be less impressed. But i’m impressed, and i am not easily impressed. I am also—relieved, that it seems alot smaller than i thought it would be.
Pix in a bit.
Yes!
Realized after ordering blue aux.
I hope the mismatch isn’t too annoying…
current, er, which is to say former edc, it looks like jewelry. MAN-jewelry.I was a bit leary this past month about whether or not it would pocket edc well…but it is really smaller than expected, i think it will be fine in my pocket.
Pretty psyched.
Pix in a bit.
Congratulations! Would love to see your ZL SC600 in the comparison pic. :+1:
E07 SIZE COMPARISON WITH SOME CURRENT AND FORMER EDC’S
Wow. Doing pictures is hard. I think i got it worked out.
Unfortunately, i do not see the pic when i am in edit pane so i cant do a relevant comment, description. I.e. whats in the picture. So if you want that follow the link.
Link to description, if curious: Fireflies E07 size comps with some former/current edc's+. My lights get used. I shrink tube the caps so i can hold light with my teeth. And i shrink tube the clips because i wear them on my belt alot, so clip doesnt pop off. - Album on Imgur
Fyi. My lights get used. I put shrink tubing on the caps so i can hold with my teeth. And i put shrink tubing on the clips because i wear the lights alot on my belt and without the shrink wrap the clips tend to pop off. Thats whats on the lights that looks like tape. Its tooth protection. Oh, and sometimes i use heat shrink wine cork covers. Their slimmer.
Eagtac 18650 uv
Eagtac 16340
Pl47
Zebralight sc600fdiii+ 18650
Nitecore mh20 18650
Tn40s 4x18650
Lumintop sdmini/mh20 18650
Acebeam ec50ii 26650
Nitecore srt6 18650
Wow! There’s a man who uses his lights. Noticed some V54s. What’s your CPF screen name?
