What tester did you get? I used the Lii-500 until learning it wasn’t testing properly on every cell. It gives a rough approximation.
I recently received the West Mountain Radio - CBA IV and it’s excellent.
I used to think my Samsung INR18650-30Q’s were fake on the Lii-500 as it was reading 2840mAh at 500mA discharge. Tried it on the CBA and it’s 3027mAh at 600mA & 2968mAh at 10A. Big difference
Yes, their 4000mah 21700 is really top notch and high drain.
I don’t know much about their 18650 cells, but they are definitely not rewrapped name brand units.
Their black 3000mah 18650 seems to be really good. It’s a high drain cell “close” to a Samsung 30Q, but not one. DB Custom got really high output and amps from it.
So I only know about their black 3000mah, black 4000mah and black 26650. All the other versions I don’t know anything about except they are low cost.
Illumn is mainly a USA seller. What country are you in? Have you checked with NKON? Do Banggood or Gearbest ship to your country?
That is more voltage sag than I expected. So not quite as good as a 30Q. I wonder if it is still the same battery that DB Custom tested almost a year ago.
I have 4 of the Sofirn 21700’s and although they seem to be decent cells, they under perform. Fully charged, I put one in my FF E07 and turbo mode didn’t seem that great. Put a Samsung 30Q in, and turbo was noticeably brighter. In other words, they can’t handle the amp draw. Tried with all 4 of the 21700’s, same result. They act like a 10A cell. Ordered some Samsung 30T’s for the E07 instead.
I use the 14500 batteries of Sofirn and never had a problem. Capacity is as advertised (900mAh, measured several times), but I guess they are not High-drain cells (at least not as EFEST)! Also note that they are shorter than other 14500s!
They blew away the 30Q in my C8F. 11.5A and 3330lm compared to the 30Q’s 9A and 2900lm. The 30T performed about the same as the Sofirn 4000mah with 11.5A and 1160lm. (The 30T should show its extra muscle at higher amp draws)
I just don’t see how it’s possible a 30Q could actually outperform the Sofirn 21700.
Capacity is just one aspect of the battery. The black 18650 3000mah have always been accurate for capacity. It seems to be a bit lacking as far as internal resistance and voltage sag, though. It looks like the 30Q definitely beats it in those regards.
Back when DB tested them the performance was so close to a 30Q he thought that’s what they were, just rewrapped. Their amp draw and output matched the 30Q exactly. The one tested above shows a bit below the 30Q at least as far as a 5A load is concerned. I’m wondering if Sofirn switched to a different battery or a different chemical mix in the last 6 months or so.
I found one interesting thing when charging the 21700. If I use a Samsung Quick Charger (micro USB), then the cell charges to more than 4.5v!!! I tried it with the supplied kit charger and also with an Xstar MC1 ANT. However if I use a non quick charge (slower) microusb charger, then the cell charges correctly to 4.2v. I hope thee is no major damage done to my battery with one off excess charge!
Whaaaat? The chargers are supposed to be designed to terminate at 4.2 volts. I’m not sure how a battery can cause an overcharge. Undercharge, yeah, but not overcharge. Sounds freaky.
Yes, even I was a bit puzzled by that. I dont think its an issue with the battery, probably these MC1 types chargers are not smart enough and the Samsung Quick Charge Adapter messes up their calculations and it overcharges the battery. I could replicate it but I dont want to do that as I am afraid that it’ll damage the cell.
All cells loose capacity the more you recharge it. It varies from cell to cell. This info is usually found in the battery documentation.
Here’s the info on the Samsung 35E as an example.
So you lose 40% of the capacity after 500 recharge cycles. Even the batteries I charge the most are still only once a week. It would take me 9.6 years to get to this.
I don’t really pay this much attention. If I wear out a battery I’ll replace it. I’m sure we will have all kinds of better batteries in the coming years. The batteries that I very seldom use and recharge might last me decades. I guess that’s a good thing? I don’t really care. Just my opinion.
I’m not talking about proper lifespan, from a good cell, I’m talking about inferior cells getting nowhere near that 500, 300, or 100 cycles that the Big 5 test to.
I could rattle off well regarded cells that I’ve used over the past 7 years, Soshine being one brand, that died quick (<1 year/30 cycle) deaths with proper handling and charging.
Sure, I’m only out a few bucks and I don’t care about cells dying from a long, hard life, but there are cells out there that initially test well, that have no longevity within their stated parameters, so that’s a component to be considered and unfortunately people like HKJ and Mooch can’t go back 2 years later and retest their ‘patients,’ so we’re left with a big ‘?’ for anything other than the Big 5, who have a proven track record.
Personally, I treat cells/batteries like I do gun my barrels, in that the more I shoot, the closer I am to having to rebarrel the weapon, so I’m not some miser looking to stretch things out for decades.
