I know Dale. It’s the not pretty version.
Others have the line description on the bottom or lower right. I think with so much different lines I guess a user searches for the explanation.
I made three versions, this is the 90% where I pushed things around and with the most free space.
The other two are a 90% and a 95% version where I moved nothing.
We both don’t know how much space the misses needs.
I lost track at the moment of the changes in Andúril, but the not pushed ones should be good for 7th click and a bit of text.
(It reminds me a bit at Narsil: Boy the cheat sheet is so packed, no way to add more stuff. And the next week Tom E had new features. Ok, I must push stuff around)
Also the lines for Hold, 3 fast clicks and other actions need probably a bigger spacing.
On A4 paper size its ok, but manufacturers print normally in a much smaller size.
I haven’t made print out in A5
A option for the “3 fast clicks”-line could be
Ah, but joe, I HAVE been speaking with her… the chart needs space in certain area’s for the addition of new functions… not necessarily a new block but more info in some of the old blocks. And only some lights that use Anduril would require this information, so it’s a toss up as to whether or not to add it in. Mostly it’s the aux led’s of a couple of manufacturer’s lights, not really applying to the normal version we flash.
Gonna have to be a couple of versions of the manual I think, one expanded for the auxiliary lights and the other not.
TK has her own methodology, someone else writing the manual the language seems off… probably best to let her do it so the speak reads true to form for the Author.
Just got mine, nichia, blue/purp, gray. (Fyi: My order was placed on nov 28)
This is a really pretty light. Next to my zebra light 60whatever 3 plus thingy my current, er, which is to say former edc, it looks like jewelry. MAN-jewelry.
I was a bit leary this past month about whether or not it would pocket edc well…but it is really smaller than expected, i think it will be fine in my pocket.
Pretty psyched.
I will post a pic in a bit with some former edc’s for size comparison for those interested.
What a pretty light. It’s just so handsome. Seriously. Nicest looking torch in my collection, easily. I dont collect—i use—so most of my lights are pretty utilitarian. So, those with fancy copper, heat treated titanium art projects may be less impressed. But i’m impressed, and i am not easily impressed. I am also—relieved, that it seems alot smaller than i thought it would be.
E07 SIZE COMPARISON WITH SOME CURRENT AND FORMER EDC’S
Wow. Doing pictures is hard. I think i got it worked out. Unfortunately, i do not see the pic when i am in edit pane so i cant do a relevant comment, description. I.e. whats in the picture. So if you want that follow the link.
Fyi. My lights get used. I put shrink tubing on the caps so i can hold with my teeth. And i put shrink tubing on the clips because i wear the lights alot on my belt and without the shrink wrap the clips tend to pop off. Thats whats on the lights that looks like tape. Its tooth protection. Oh, and sometimes i use heat shrink wine cork covers. Their slimmer.
I prefer working at nite, so i use my lites a little bit.
Names the same over yonder but i dont do the comments much—unless i am on the hunt for a new lite. Been excited about 21700s, so i have been here alot lately—following fireflies. I will hang for a bit longer to see what they come up with next then i wont be back till i get the itch again.
I did not do an extensive search on the chinese sites (I would worry about correct calibrations with unknown brands) but I’m afraid that these devices do not come cheap at all, I have not seen anything under $1200 yet.
Ha. Been chewing the nicotine gum every waking hour since 2002, so maybe.
I edc’d that acebeam 26650 ec50 for a couple 6 months, that one in the teeth was pretty heavy.
The e07 is a feather compared to that giant honkin thing.
Years ago it was the srt6, thats alot heavier than the e07 as well.
Fwiw, its not like its in my teeth for days. Usually an inspection event of some sort where i need to be handsfree is when it happens. Nonetheless, i had to start wrapping the ends cause i was cracking my teeth on the bare metal.
Edit: before i broke my heal last year i used to take the dogs out and always carried a 2x18650 thrower of one sort or another. In fact, I think it was an olight triton from like 10 or so, years ago was the reason i started wrapping the ends.
I passed the information about this issue on to the german TLF. There were two people who had the same issue.
Im interested though: Would you confront Fireflies or your dealer with this issue if it happened? Or are you good with it as long as it works as intended?
Ahh, so that’s what the tape is on them for. Nice edc collection. Mine is ordered from nealsgadgets. Raw color purple aux with xpl hi 5000k. Can’t wait
If you got it glued and have no intention of opening it you should just not even look or worry. No point.
On another topic, this is my first 219B and I dont entirely see the appeal.
On most modes the tint is very nice but on turbo it’s SO much more pink than every other mode. I understand people like that but the fact it changes so much on turbo makes it annoying to me. If it was that shade of pink through the whole ramp it would be one thing but having it change so much on turbo makes me wonder why anyone puts these in anything other than a linear driver light.
