Another (probably stupid) question: If I add multiple items to my shopping cart and choose "ePacket" as shipping method it looks as if I am being charged for shipping cost for each item again and again. In the end this adds up to quite a big amount of shipping cost. Is this correct this way or am I overlooking something and it can be corrected later on before I actually pay with PayPal?
the amount should be $93.29,
$93.29*85%=$79.3
if you pay for your order on aliexpress, i will adjust the amount to reduce the repeated shipping cost.
if you transfer money to me via paypal ,you can leave me your paypal account, i will send payment request
I made 541 kcd with CSLNM1.TG in L6
But it is not very easy to focus good and I needed to leave centering ring out so forr mass production it is a pain to set up those leds focus properly.
They need to make a new reflector because the current need to sit directly on MCPCB and I needed to gring the reflector bottom to clear wires. Or need to use bigger MCPCB also. It is very picky about reflector height. If you are 0,1mm higher or lower with reflector than perfect you easily loose 50-100 kcd.
An xhp35 L6 with full function side switch and anduril would be amazing! Please use some kind of ramping e switch action if possible. Also, don’t overlook the low-lumen modes. I love the low on my L6, and think a lower moonlight and firefly set of modes could be useful, especially for using while eyes are dark adapted. It could run forever at one or even ten lumens! I would keep the forward clicky tail switch, but make sure it can be turned on and off with the side switch. The tail switch could be used for signaling, tactical uses, and lock out. A high cri option, like 90+ would be sweet too. Whatever you come up with, I’m in!
