Sorry, no measurements, but enough of a difference to notice in walks down the driveway. Both are 5500 cells. IR is about twice the Shockli if you can believe the charger.
I contacted Sofirns battery store (E-Battery store) and they told me they don’t carry a 5500mah 26650 even though there are tons of pictures and such. They said they are all 5000mah. This is quite confusing. I may need to ask Tracy at Sofirn if she knows what the situation is.
Tracy has told me their 26650 does not pull a lot of amps with a FET driver. In the SP70 prototype (70.2, FET driver and 2 x batteries) their 26650 performed about the same as a pair of Panasonic NCR18650B. That’s an old cell from 2012. So we know they aren’t good for high drain usage.
The Shockli 5500mah is quite new and is a top rate battery. I would expect it to be better than the Sofirn 26650, but not by much as far as the SP33 is concerned. It might have higher voltage sag causing the SP33 to loose turbo sooner, maybe?
The question is, is there a big enough difference in performance to justify the higher cost of the Shockli 5500mah?
Your forgetting that the E07 pulls about 20A while your C8F and PL47 pull about 10A, roughly. I got the same results as you.
What RobertB is saying is that at the higher amp draws (the 20A range), the Sofirn 4000mah seems to be having difficulty while the 30Q keeps pulling strong. It seems strange to me, but I suppose it’s possible.
Some scientific testing of the Sofirn 4000mah is needed.
Just like Tepco got warned that the tsunami barriers at Fukushima where subpar and not high enough and there a fairly high chance i think it was a 20% chance of 30+ foot wave hitting Fukushima. Low and behold look at it now. Cited twice on two different occasion from different reports and urged to be prepared but money wins all the time.
Now look the clean up cost plus lose of lives and lively hoods ruined.
It looks like many chineese battery sellers or budled batteries are in the last months replacing original SDI or Sony cells with some doubtful cheap cells with just a lot worse internal resistance
and Liitokala and other Aliexpress selllers are even faking the original labels and sell for the same price as original cells
I doubt this will pay out in the long run, they simply gamble with their reputation and will loose over time
I’ve ordered from Sofirn a number of times by now. I cannot order bare batteries from them (bare batteries not allowed to be shipped to my country), so the Sofirn batteries are always ordered only with the Sofirn flashlights.
I have had several Sofirn 18650s by now. The earliest one was the red one (looks like “UltraFire” wrapping), followed by the black wrapper — the black wrapped Sofirn seems to be the current wrapper for the 18650s, and indicates 3000mAh (I’ve ordered a lower Sofirn flashlight model which came with 2200mAh 18650 though, but that is another subject…)
(these are only about the capacity test, didn’t do much IR testing, but )
Sofirn “3000mAh” 18650 (red wrapper, and black wrapper)
-The earliest Sofirn 3000mAh 18650 (red wrapper, or the black wrapper — these 18650s are likely 6 or more months ago) — when I first tested their capacity with my MC3000 (–0.50A discharge to 2.50v), I only got around 2700+ mAh for all of them. (so these are actually a bit lower than their 3000mAh label)
-But the newer Sofirn 3000mAh 18650 (same black wrapping) from more recent order (around 2 months or so ago) — testing their capacity, I’m consistently getting 3000+ mAh capacity (same –0.50A discharge to 2.50v). (they are now correctly labeled)
Sofirn “2800mAh” blue/black-wrapping protected 18650
-The blue/black-wrapped Sofirn 2800mAh protected 18650 are protected batteries, which trip at around 6 amps.
I only got a few of these (I think they were all from around 6 or so months ago) - their tested capacity were 2700-2800mAh, so they are “correctly” labeled.
Sofirn 900mAh 14500:
- now these seem to have several batches too.
- as mentioned above, some of them (the earlier models, as in 6 months or so ago) are quite short in physical length — they are a bit shorter than Eneloop AA NiMh batteries.
- tested capacity are between 800-900mah
the newer batch appears to be a bit longer now (similar size to other common unprotected 14500s, not “a bit shorter” anymore), tested capacity seems to still be around 800-900mAh
Been a few months. Any more data on the Sofirn 5000/5500 26650? I would imagine a lot of BLFers have a few now. Max amp draw? Don’t see a HKJ test yet.
