ENDED.
Interested please
Those are good, low IR, high drain cells. They are rewrapped Lishen LR2170SA. HKJ has reviewed them.
They are the normal length, so there should not be any issues in fitting.
@JasonWW - Thanks for the info
I can now buy them with confidence !
I’ll just use 18650s until the 21700s get here
Order placed for 1 CW. Thanks so much.
Thanks Freeme. I finally ordered a CW just because. I usually order CW for shooter and NW for flood. I won’t use this much except to impress friends but features, size and price with code is great I think.
Got my cool white version today. Kinda disappointed so far. Maybe tonight when I can go outside in the dark my impression will be better.
There is a hot spot in the middle of a large white blur of light, it looks like a large square corona with a brighter round spot in the middle. Ramping is good going down but ramping up is fast. It’s like 3 steps just blended together sort of. It takes 2 seconds to ramp up and 4 or 5 to ramp down. The light feels good in the hand, just wish the ramping were better at this point. I will add to this tonight after it gets dark.
Interested
Received my CW version on 1/3/19…it took about a month to the US once shipped. I like it very much, thanks Freeme!
At first I couldn’t find the 21700 adapter and figured it didn’t ship with the flashlight. I then tried to insert a 21700 battery and it stuck out an extra 1” preventing the cap from getting anywhere near the battery tube thread. I looked down the battery tube and noticed that the battery contact seemed to be a little high. I unscrewed the battery tube from the head and discovered the 21700 adapter sitting at the bottom of the tube.
Unlike the full sleeve 21700 adapter I have from another flashlight, the adapter that comes with the FT02 is about 1” long and has a battery contact built in.
Interested
Got my CW in the morning… my DHL payed Driver ringing early… :sunglasses:
Feels valuable, well-made. Also fits in the niteize on the belt …
What I notice the side switching has no LED lighting in green … Is that the intention ?? Or a production error …Hmm…
I mean like the GT Mini show up light on every click… :frowning:
The charging socket wobbles too,this is a no go i´ll not use it…
Im not happy… at all…
What exactly do you mean? There is no switch light at all?
This light has nothing to do with the GT Mini. It’s completely different.
The 1st Pic show a light in the Switch…
I know that the GT mini is totally different, my statement was purely on the side switch.
I certainly do not tackle your skills, but not be so harshly.
If the photos do not convey an actual bid of the purchased product, you do not need them to post.
But thanks for your reminder …
I’m still not understanding what you’re saying about your light. Does your side switch light turn on sometimes or does it not turn on at all? Does it flicker?
A question for all owners of this light, does it have a lighted side switch or no?
If you not understand, im not sure youre the right adress to comment my Poste…
My FT02 switch have no light at ALL!
I did not understand because you were not clear.
It seems like your switch light is broken. You can see that the green light works in this video.
So the picture in post 1 is correct.
I am in. i would like one
I just received my NW version and wanted to check what everyone gets at the bottom of the ramp. My understanding was the lowest output was 1 lumen but I get a much higher figure.
I would estimate around 100 lumens is the lowest output. Did the specs change?
I believe bottom of the ramp is different from the lowest output. To get the lowest output, or moonlight, you have to start with a light off and then press and hold the switch. Then you release the switch as soon as the light turns on.
I received the FT02 (4000k version) that I bought for a friend. Some quick impressions:
*the flashlight looks and feels nice and high-class, the reflector looks really smooth.
*the tint of the hotspot is really good. Although it is above the BBL at lower modes (right on the BBL at max), it does not look like that, it is not green or ugly at all.
*the ramping works pretty nice, the lowest mode I measured at 24 lumen when cold, 29 lumen when the light is warmed up. Long press from off does not give a lower mode than that.
*the switch leds do indicate things when you press the switch but I have no idea what. When the switch is not operated the switch leds do not light, wether the flashlight on or off. I will look into the manual what it does do.
*at max I measured 1780 lumen (on a 30T, but a lower drain battery, or half-full gives the same output, and it is pretty steady). This is lower than specified, I expected that the neutral tinted led has somewhat lower output but 19% lower is a bit more than the difference between a cool and neutral (71CRI) led.
*at max I measured 140 kcd, again lower than expected.
Overall this seems a very nice and balanced flashlight, still have to measure current but it does not become hot fast at all.
The rated output of 2200 was always fantasy. 1780 lumen is really good.
