How trustworthy are Sofirn batteries?
147 posts / 0 new
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 9 hours 23 min ago
teacher wrote:
hank wrote:
I worry about China’s “good enough” nuclear power plant expansion.
Yep, that could have a real bad outcome….. Facepalm !{width:75%}https://s.yimg.com/lo/api/res/1.2/VrGprqFgQVWGjJS3eP_HBA—~B/YXBwaWQ9eW...!
Just like Tepco got warned that the tsunami barriers at Fukushima where subpar and not high enough and there a fairly high chance i think it was a 20% chance of 30+ foot wave hitting Fukushima. Low and behold look at it now. Cited twice on two different occasion from different reports and urged to be prepared but money wins all the time.
Now look the clean up cost plus lose of lives and lively hoods ruined.
teacher
teacher's picture
Yep, they certainly ‘pooped in their bowl of Cheerios’ on that one. Facepalm . And then had to eat them with a Big Spoon….. Sad
Lexel
Lexel's picture
Last seen: 4 hours 31 min ago
It looks like many chineese battery sellers or budled batteries are in the last months replacing original SDI or Sony cells with some doubtful cheap cells with just a lot worse internal resistance
and Liitokala and other Aliexpress selllers are even faking the original labels and sell for the same price as original cells
I doubt this will pay out in the long run, they simply gamble with their reputation and will loose over time
hank
hank's picture
Last seen: 14 hours 4 min ago
Ah, no. That’s not how fission plants fail. But you knew that.
d_t_a
Last seen: 4 hours 18 min ago
JasonWW wrote:
Brainsick67 wrote:
They are good to me..tested like 4 of the 3000mAh ones, and they ALL came to 3,000mAh or a tad more.
Capacity is just one aspect of the battery. The black 18650 3000mah have always been accurate for capacity. It seems to be a bit lacking as far as internal resistance and voltage sag, though. It looks like the 30Q definitely beats it in those regards.
Back when DB tested them the performance was so close to a 30Q he thought that’s what they were, just rewrapped. Their amp draw and output matched the 30Q exactly. The one tested above shows a bit below the 30Q at least as far as a 5A load is concerned. I’m wondering if Sofirn switched to a different battery or a different chemical mix in the last 6 months or so.
I’ve ordered from Sofirn a number of times by now. I cannot order bare batteries from them (bare batteries not allowed to be shipped to my country), so the Sofirn batteries are always ordered only with the Sofirn flashlights.
I have had several Sofirn 18650s by now. The earliest one was the red one (looks like “UltraFire” wrapping), followed by the black wrapper — the black wrapped Sofirn seems to be the current wrapper for the 18650s, and indicates 3000mAh (I’ve ordered a lower Sofirn flashlight model which came with 2200mAh 18650 though, but that is another subject..)
(these are only about the capacity test, didn’t do much IR testing, but )
Sofirn “3000mAh” 18650 (red wrapper, and black wrapper)
-The earliest Sofirn 3000mAh 18650 (red wrapper, or the black wrapper — these 18650s are likely 6 or more months ago) — when I first tested their capacity with my MC3000 (-0.50A discharge to 2.50v), I only got around 2700+ mAh for all of them. (so these are actually a bit lower than their 3000mAh label)
-But the newer Sofirn 3000mAh 18650 (same black wrapping) from more recent order (around 2 months or so ago) — testing their capacity, I’m consistently getting 3000+ mAh capacity (same -0.50A discharge to 2.50v). (they are now correctly labeled)
Sofirn “2800mAh” blue/black-wrapping protected 18650
-The blue/black-wrapped Sofirn 2800mAh protected 18650 are protected batteries, which trip at around 6 amps.
I only got a few of these (I think they were all from around 6 or so months ago) – their tested capacity were 2700-2800mAh, so they are “correctly” labeled.
Sofirn 900mAh 14500:
- now these seem to have several batches too.
- as mentioned above, some of them (the earlier models, as in 6 months or so ago) are quite short in physical length — they are a bit shorter than Eneloop AA NiMh batteries.
- tested capacity are between 800-900mah
- the newer batch appears to be a bit longer now (similar size to other common unprotected 14500s, not “a bit shorter” anymore), tested capacity seems to still be around 800-900mAh
JasonWW
JasonWW's picture
Last seen: 1 hour 26 min ago
I asked Tracy at Sofirn if she could explain the capacity of their 26650 cells. Some are sold as 5000mah and some are sold as 5500mah.
Sofirn wrote:
Hello.  The service is correct. Sorry for the confusion that we have caused. As the battery capacity between 5000mah -5500mah, so some we lable 5000 and some we lable 5500. Actually the two label batteris are the same one. Thank you. Tracy
Click this to go to signature links.
peg matite
peg matite's picture
Last seen: 59 min 51 sec ago
Been a few months. Any more data on the Sofirn 5000/5500 26650? I would imagine a lot of BLFers have a few now. Max amp draw? Don’t see a HKJ test yet.
Funtastic
Funtastic's picture
Last seen: 1 day 5 hours ago
I have a few but they are for sale with the flashlights so don’t really want to test for maximum discharge current.
I have 21pcs of the new high drain 26650’s that should arrive within a week I’ll be giving a good test.
The Sofirn 14500’s are decent at up to 3A
Texas Ace Lumen Tube calibrated with maukka lights
Funtastic
Funtastic's picture
The Sofirn 26650 High Drain are good for just over 10A. Not sure why Sofirn rates them at 25A for Continuous Discharge Current.
Up to 10A they perform as good as a Samsung 30Q
I didn’t expect 25A for 5000mAh capacity. I’m quite happy with their performance
I’ll update with my tests tomorrow
Funtastic
Funtastic's picture
Turns out the battery wasn’t in my clamp correctly for the 15A test.
I’ll perform a 20A test tomorrow and post results but 15A is looking like it’s close to it’s limit.
The 26650 HD is only 4500mAh, not the stated 5000mAh.
mortuus
mortuus's picture
Last seen: 2 hours 36 min ago
they should stop mis-label the batteries capacity, even if they perform ok there are far better options to get today.
...where Frugal meets with Flashlight!
Funtastic
Funtastic's picture
Not when it comes down to getting it bundled with a flashlight for so cheap. This is convenient for the countries that can’t get cells shipped by themselves.
To import 100pcs of 18680’s into New Zealand shipping alone costs $120+ USD, whereas it’s free shipping when in a flashlight. Even 10pcs costs $30 USD
I’ll upload my graph tomorrow.
Sofirn 26650 High Drain is only a 15A cell for max continuous discharge current. 20A was far too high. It could be that the added button top is increasing resistance thus causing higher voltage drop than without it
BlueSwordM
BlueSwordM's picture
Last seen: 53 min 28 sec ago
@Funtastic, have you ever heard of Queen Batteries?
https://queenbattery.aliexpress.com/store/1332380
They are 100% legit.
Funtastic
Funtastic's picture
Thanks Blue but I always buy in bulk from Lucky Electronic Store
Very expensive shipping to New Zealand via USPS is the only option available right now. There was a cheaper option until some idiot tried to import a gun.
As you can see on the below graph that 20A is too high
JasonWW
JasonWW's picture
I’m sorry, but I don’t see temperatures anywhere on your graph. Are you saying it exceeded 80°C during the 20 amp test?
Funtastic
Funtastic's picture
There’s too much voltage drop on the 20A to be of much use. Sofirn don’t give a data sheet with a max temp so I didn’t want to risk it. 20A reached 70 degrees.
This test on the Samsung 25R shows that the 30A is too high and it’s similar to the 20A curve of the Sofirn. I’m kind of new to judging discharge curves but it looks too high.
EDIT: I don’t know why I can’t link that page but select and search via google and it’ll come up
JasonWW
JasonWW's picture
I always though maximum discharge rates where based on temperature. Cells tend to vary in max temp with some at 70°C and some at 80°C. If it did not exceed 70, then it might be fine at 20A continous. I'm not familiar enough with discharge curves to know what's considered usable or not usable.
HKJ's links uses spaces which require the advanced post editor to post them.
The above link
Funtastic
Funtastic's picture
Well if that’s the case I’d rate it at 20A continuous.
Thank you for helping with the link, I was confused why it wouldn’t work.
I’ll flick Mooch a message via facebook and ask what he thinks
JasonWW
JasonWW's picture
Let's compare it to a Liitokala Black 5000mah which is okay at 20A continous, but got too hot at 30A continous.
Hmmm, looks pretty hard to compare. 20A of the Sofirn HD does look slightly worse than the 20A on the Liitokala.
It's definitely better than the regular Sofirn 26650 cells, but neither are close to the mighty Golisi 4300.
Edit, here is the discharge curve of the Samsung 25R from the link above. I'm not sure how comparable it is to the Sofirn HD, though.
Funtastic
Funtastic's picture
Thanks for that Jason. It gave me a boost to try the 25A test,
20A at 64 degrees
25A at 70
Even though it didn’t hit the 80 degrees temp I don’t think it’s handling the 25A current well at all.
Keep in mind that my CBA has a voltage drop of 0.03V at 20A & 0.04V at 25A so it’s not spot on but works well enough to show performance
Funtastic
Funtastic's picture
Just realized I need to run a capacity test at 0.2C (1A)
JasonWW
JasonWW's picture
20A at 64 degrees
25A at 70
Yeah, at 25A you can see it sag and then as it heats up the voltage rises back up. That and the big loss of capacity says 25A continous is not so good. I’m surprised the temperature didn’t go higher.
I know HKJ is on this forum, I wonder what he would think of these discharge curves.
Funtastic
Funtastic's picture
Mooch:
Voltage sag and voltage recovery during a discharge is important to watch for in addition to temperature.
Ultra high capacity cells run tens of degrees C cooler at their ratings versus high performance cells.
Multiple cycles at its rating to look for obvious damage often needs to be done also.
Temp cannot be used on its own to set a rating.
Higher IR cells can show greater dips at the start too, at their rating.
JasonWW
JasonWW's picture
I have noticed that Mooch and HKJ don’t always agree on the Continous Discharge Rate of the same cell so it makes sense that it is somewhat subjective.
I think I would say the Sofirn HD cell is not good for 25A continous due to it’s big loss of capacity and the dip and recover in voltage.
Maybe 20A CDR is more accurate, but still not quite as good as the Liitokala black or cyan 5000mah (which is 20A CDR).
It’s definitely better than the Sofirn non-HD battery, though. I don’t think anyone has done discharge tests on it like above, but it’s reduced lumens tells me they are not high current at all.
Funtastic
Funtastic's picture
I do have a few of the regular Sofirn 26650’s 5500mAh that I’ll test. It’ll be interesting to see the difference.
Ran a capacity test at 0.2C which would be 4800mAh if taken to 2.5v. I stopped discharging lower than 2.8v due to damaging some cells.
Funtastic
Funtastic's picture
I wonder if I should start my own thread and list results for each
JasonWW
JasonWW's picture
Sofirn told me these HD cells were 4800mah, but they advertise them as 5000mah. Weird.
New threads sounds like a good idea. Add links here so we can find them. Thumbs Up
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 8 hours 40 min ago
I ran this 5500 cell down in an Sp33 to 2.8V and let it rest so it rebounded to 3V. I recharged it at 1 A.
Sofirn 5500
Funtastic
Funtastic's picture
Some of that capacity would be resistance/heat though so it’s not what’s actually gone into the battery. I’ve had an Ultrafire 18650 show 7000mAh while charging lol. Chargers that measure mAh are useful but a discharge test is needed to determine exactly what the true amount is.
amishbill
amishbill's picture
Last seen: 1 week 6 days ago
wstrachan wrote:
My only experience with sofirn cells are one supplied with their lights and they have performed well.
FWIW – I just got two Sofirn light kits with their own branded batteries. One was a 21700 and the other an 18650. First thing, I rand them through a normal test cycle in a Zanflare analyzing charger. Both tested well past100mah over their ratings.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
