Yeah Djozz I may have a problem shipping those out of the country. I will PM you if I can get approval.
Sure, no hurry, I see it as a lucky opportunity if you succeed
If you do no torture test on this LED I may buy it after you are finished
LOL, such an expensive led is not going to be torture-tested for sure , but I will not sell what I have not payed for, sounds not very fair to Scientist.
Thanks for the testing djozz.
Is the new led on the left hand side still dirty in the last picture?
No, it is the cleaned one , probably it will not influence performance but the silicon has some pits here and there.
Probably not the correct place to ask this question, but was wonderingâŚ
Convoy sells the Convoy S2 with LG UV LED. I wonder if that Convoy S2 uses the older LG or the newer LG UV365 LED?
Thanks again Djozz for the testing!! Djozz-mW...that's funny :D
I can Pay Scientist
Thanks for the test, djozz.
Looking at if from the other direction it means the radiant output at 3.7 V is not 1070 djozz-mW (at 0.8 A) but 2100 djozz-mW (at 2 A).
That is a huge difference.
This is probably hijacking your thread a little, but the knowledgeable folks who I have conversed with over the centuries are here, and the topic is UV LEDs.
Despite all the recent claims of 4 watt, 5 watt, overdriven, turbo Convoys (7135 drivers), I believe there ainât no such animal. The engineers in our fluorescent mineral group have watched the ridiculous power claims climb over the past three years with amazement At the power levels folks are claiming today these little lights should literally be burning your hands. They arenât - this blog post explains why, all comments welcome: Convoy false power claims
dude the 7135 is a linear regulator
Sure is, but I donât understand your point
I'm not sure what you're getting at. You may be correct regarding the high Vf of the UV LEDs preventing high output on the UV Convoy, but the Convoy hosts are capable of dissipating over 7W of heat. I've personally run a Convoy on a fresh cell for hours at approximately 2A. Not much sag on that cell, but I'll be generous and assumed 2A * 3.5V for the power dissipation. For short periods, they handle significantly higher power well - not just the stock 2.8A that the white Convoy's come equipped for, but so-called hot-rodded Convoys can pull currents in the high teens.
Even your own chart shows the Convoy doing 3 Watts at 3.9V, which could be sustained for a while before the battery got that low - definitely more than just a few minutes.
700mA is very little current, it wonât burn your hands (but it could damage the Nichia LED if the heat transfer to the star and pill is not good enough as that LED is quite small, the LG LED can handle more current but has more visible light). Even 1400mA shouldnât get too hot. 2100mA (6x7135) and 2800mA (8x7135) can indeed get quite hot to painful levels if left unattended. There was a temperature test of the 8x7135 driver: How hot does an S2+ get at 2.75A? Comparing an anodised Convoy S2+ with a fluorescent yellow powdercoated Convoy S2+
I guess that a 4.35V cell like the LG ICR18650E1 would be better for extended usage of the Nichia version.
Edit: you are making your claims based on a âtypicalâ 2200mAh cell. Nowadays 2200mAh would be either an obsolete or cheap cell, or a cell optimized for very high current for power tools or vaping (20A-30A) rather than capacity, not a typical 18650 cell. A modern cell 4.2V cell like the NCR18650GA can keep the voltage much better. In fact a 4.35v cell isnât a large improvement over the 18650GA. From HKJâs battery comparator :
It means a 7135 based driver will maintain a constant current until it canât sustain it anymore. So a 1x7135 (standard bin 350mA) driver will maintain 350mA , nothing more, nothing less until 3.6V ish, and shortly after that turn off. It will not dim from 4.2 down to 3.6 unless you apply PWM.
Not too worried about heat, just driving voltage. But that said, UV LEDs are much more sensitive to heat - just look at any graph, derating starts at 40c on most of them. Of course hobbyists can do all kinds of neat things, drive them harder, etc. But production flashlights to the masses, probably a bad practice.
As far as voltage goes, drop below 4 volts and the current to the average UV LED drops drastically. 3.7v (rating for lithiums) and it really sucks.
Donât think so. The driver just goes into direct drive mode. The LED will light (in the case of an LG or Nichia LED) as long as the battery voltage is high enough >3.0V~, but will progressively become very dim as the voltage drops from 3.9v to 3.0v (or so). PWM another story, Iâm talking about single mode drivers, no smarts. edit - keep in mind that UV LEDs expect ~4.0v
and Iâll repeat, 7135âs are not direct drive
Maybe a little better but according to the graphs it still drops below 4.0v pretty quick it seems. But in our market we have a bunch of people who have no clue about batteries and buy them off Ebay, your local vape shop, Amazon, etc. No idea what theyâre gonna get (except the cheapest). In fact, folks selling Convoys to the mineral market on Ebay and at shows are including really junk batteries.
Iâll dig into the one you linked to see if we can get a little better run time - thx for the link. But sadly, wonât help the general population.
