Honestly I think a good manual should be readable and usable in color AND black and white. I don’t see a reason for two different version when all it takes to make it b/w friendly is probably just some different line pattern.
Study the manual at BLF, Every day until the light arrives. You might need the manual for 10 minutes if you need to set the thermal config. By the time you do that it will be second nature. Anduril is very smooth.
I’ll take another 3 (6 total) if the price remains reasonably consistent with the initial estimate. I’d be happy to buy them without LEDs if the XP-L version is the only initial offering. Still waiting to hear whether a good tint bin of LH351D was secured.
Provide a .pdf color version that can be downloaded/printed and, to keep cost down, ship with the black and white version…… or make your own color version with photoshop……. that being said, this should be far down the list of priorities.
joechina did most of the work for making the UI diagram more black-and-white printer friendly. I’ve been meaning to merge his changes for a while, but I keep getting distracted…
Anyway, here’s an updated diagram which uses two parallel lines for the green / double-click actions. Also, click the image for a much larger version for printing purposes.
Mostly, yes. I just needed to make the 1-click black lines and the 2-click green lines more visually distinct in ways which are visible on a black-and-white laser printer.
