Bingo, I was starting to think I was loosing my mind.
Yes, that should work well in black and white. I find it odd that people are having trouble understanding Anduril. I true believe anyone will have this mastered by the time they drain there first cell.
I like the look but the only disappointing thing to me is the clip isn’t very deep carry. Hopefully there will be an alternative or aftermarket option.
I tinkerd with the UI graphic a while ago with double lines for the green stuff.
I also did a few scaled down versions too because Toykeeper said she has no more space. A 95% and two in 90% and mailed TK.
Maybe use one of those? My experience with manufacturers is, regardless if the first run of documentations is full colour, there is always an idiot in the company who change them to black and white in order to save money. (And scales them down also)
Edit:
Ups,
I should read first the whole thread. TK posted it
@Toykeeper
It looks good!
It seems you redid your version or?
With your own character with no whitespace left and right, but only a few pixels wide to get smooth curves in tight radiuses?
Or why has a “=” a bend?
Everything I write here is only a suggestion, please choose only what you like.
In the later versions I have an additional line in the top left corner as a clue for the user.
Is it intentional that the double lines (text) goes into the arrowheads? Guess Yes.
(Otherwise you must lower the text under the path.)
And you have a uniform lenght of green line in the arrow heads. Do you use the heads as starting point for the char? Nice idea.
Hey, you can place a white snow flake as first char to have it the arrow head, so it is more distinguishable to the black lines
When printed small the double lines are also tough. One option is to up the char size or to use other chars.
Maybe ╳ U+2573 is a better option?
And the line for other actions can also blur when printed small. That is a normal inkscape line style of I remember correctly. A bit fatter would be good.
The text in Lockout is too low contrast, depending how they print. Please use a bright grey or white
I would also brighten up the dark lower part of the ramp box.
or lay under the arrow head a white shape so it has a fine white line. The same for the dashed floor line part which is in the box
The red background in the temp check bubble can print in grey. A white outline on the text keep it readable under every circumstance.
A few other line stiles I came up with
(I don’t know if all the Unicode characters show up in the browser)
Other options from Unicode Boxdrawing are:
(haven’t tested how bendy they are)
╩ U+2569 and ╦ U+2566 ╩╦╩╦
╬ U+256C ╬╬╬╬╬╬
╫ U+256B ╫╫╫╫╫╫
╳ U+2573 ╳╳╳╳╳╳
╳ U+2573 and space ╳╳ ╳╳ ╳╳ ╳╳
Other options from Blockelements are:
▚ U+259A ▚▚▚▚▚▚▚▚
▁ U+2581 and ▔ U+2594 ▔▁▔▁▔▁▔▁
Other misc stuff
▰ U+25B0 and ▱ U+25B1 ▰▱▰▱▰
• • • • • • • • • Bullets and Space
══☠═══☠═══☠══ Dangerline
══:snowman_with_snow:══:snowman_with_snow:══:snowman_with_snow: Winterline
❆ U+2746 ❆❆❆❆❆❆❆ Line of snow (maybe illigal in some countries)
Have you noticed the reduced versions I mailed? You never talked back:
I also did a few scaled down versions too because you said you have no more space. A 95% and two in 90% and mailed it.
My experience with manufacturers is, regardless if the first run of documentations is full colour, there is always an idiot in the company who change them later to black and white in order to save money. (And scales them down also)
On the Fireflies E07 thread
is an example of the version with the most white space
Why is everyone always fixing at stuff that ain’t broke?
Joe, the chart you linked there has no thermal or beacon configuration instructions. Just saying. Edit: Ah, found them in the box, nevermind… going to make coffee now… (the bad memory thing, resist change, get confused if everything isn’t in it’s spot… been doing Anduril too long already)
