I bought an S2R Baton II and a keychain flashlight for my girlfriend. We both like what we got. Then I placed 3 more orders with Olight during the Black Friday sale. I had to fight to get tracking numbers for those orders. I’m actually STILL awaiting delivery of one of those shipments from Black Friday. Their customer service is slow to respond if they respond at all. I seem to have an issue with my S2R Baton II not remembering the last used setting before being powered off. I emailed them weeks ago and I still haven’t received a response. I would strongly advise against buying anything from Olight until they get their act together. Like I said great products, but the company is silent when you need them to stand behind the products.
The BORUiT RJ-020 is my go to, ir on/off is really useful when working with mucky hands etc, pretty wide beam and well bright enough for any of my needs. I believe it is moddable if required, may be tricky though.
I have an Armytek from about 3-4 years ago and it has been my go to headlamp until the on/off switch started messing up. I can’t turn my headlamp on/off or higher/lower at times. I also have the boruit, skillhunt and rei spot headlamp which are all just ok.
I’ve got a number of Boruit RJ02s. Cheap enough I figured I’d get a bunch and treat them as “disposable”, but the first/only one I’ve been beating on alllllll this time is still chugging away just fine.
Easy to swap 20mm TIR lenses if you want narrower/wider, too. About 10sec-15sec to do, too.
I second that vote. Very nice little boruit light. $11, built in charging. I would usually say Boruit is junk and 99/100 I’d be right. This is a great light.
When shoppig for it, you must search the model as Boruit EHL0628 because the others that are very similar dont compare.
You might consider the E-16 if you wear a ball cap. I just picked one up and some rechargable 16340’s for mine. I s a great little light that I will use for hunting/fishing.
If you are looking for something more trditional the Fenix Hl50 is another candidate. HL50
The HL50 is a nice light weight headlamp that is great for around the house. The downside to the HL50 is that it it only runs on disposables Cr123Aor AA batteries. If you buy the 123’s in bulk you can get them for a $1.50 or so.
Don’t loan out the Fenix HL50. You won’t get it back. lol I loaned mine to my brother for a hunt a few years back and I still haven’t gotten it back even after a few reminders.
WOWTAC A2S Comes with 18650 battery that has a USB plug in the side of it for recharging. Also comes with the USB cable. Five levels from firefly to 1100 lumen. Easy to use. Waterproof. $30 delivered.
I just can’t get over the fact that the Wowtac looks cheap especially with that dollar store push button cover on the end. No issues with the push button?
The button is loud, almost like a reverse click. But I have not had any issues with it. Its main job is bench work, modding other lights.
Without the DC/fix it is on the spotty side. Here is a list of my current head lamps.
Armytek Wizard Pro Mag Charger
Skilhunt H03 driver modded.
Nitecore NU 30 DC-fix
Wowtac A2 driver and DC-fix.
The Wizard and the Skilhunt are flood.
The Nitcore and the Wowtac are spottier.
I don’t think you can go wrong with any lights mentioned in this thread.
Just pick your beam, tint and UI.
What I don’t like about the Wowtac is the switch location. I prefer Armtek or Skilhunt as I can have the button down on the left, or up on the right.
The Wowtac end button, I have to hold the light while pushing in to keep it from moving on my head. Not that big of an issue as bench work it stays at a level most of the time.
I have gotten use to it. But it might be an issue for you.
I would second the Skilhunt H03 in neutral tint. I have it and it’s very flexible…has magnet in tailcap for hanging it as well. Modes are very customizable….very similar to Zebralight UI…can barely light up your immediate area or a fairly large area at distance….your choice. IMHO, very smooth, floody beam. Plus, with the included clip, you can wear it on your shirt/jacket as a forward looking light if needed. (same for H15 below).
I also have the Skilhunt H15, which is the AA/14500 version. I like it a lot too…nice that you can switch over to regular AA’s in a pinch. But, I usually go for the H03 because it is BARELY bigger than the H15 and of course has longer runtimes with 18650’s.
I use my RJ-02 as a work lamp just like the OP wants to.
It’s great at that and since it’s the cheapest of great options - that’s what I recommend.
I changed the lens to a wider one though.
I ordered the Skiohunt H03 RC direct. Still waiting for a tracking number. Emailed them today.
I also ordered an Xtar Dragon VP4 Plus charger and some KeepPower 3500mAh Sanyo NCR18650GA batteries from Illumn. I have to say I’ll never order from Illumn again. I spent over $100 and they shipped my stuff in a thin FedEx envelope that offers zero protection. The charger box is beat up. It even looks like it has been opened. That may be from the less than soft ride to my house. I suggest you avoid this place!
